3 Heat Treat Furnaces for Annealing Aluminum
Jupiter Aluminum Industries (JUPALCO), a newly established aluminum factory which will be part of the Jupiter Group in India, has ordered three furnaces for annealing aluminum coils from a heat treat furnace manufacturer with North American locations.
The equipment ordered by the Jupiter Group from SECO/WARWICK includes three Vortex® 2.0 furnaces for aluminum annealing, two cooling chambers, and one loader. A system configured in this way will ensure the optimal production volume of the Indian rolling mill.
The aim of JUPALCO’s new plant will be to achieve the highest level of domestic aluminum production in history and to create an ecosystem of comprehensive aluminum-based solutions. This is the first cooperation between SECO/WARWICK and the Jupiter Group.
The three Vortex furnaces are effective systems for annealing aluminum coils. In the Vortex 2.0 version, a system of straight nozzles has increased the heat transfer efficiency. The systems key feature is the increased heat transfer coefficient, achieved by directing high-velocity air to both sides of the coil. This allows air to flow over the coil edges, not just through its outer layer.
Piotr Skarbiński, Vice President of (Source: secowarwick.com)
With the use of patented air flow technology, the aluminum coil annealing systems operate with process cycles that are significantly shorter. This in turn ensures energy savings, increased efficiency, and improved surface quality of the finished coils.
“In the case of coil annealing,” commented Piotr Skarbiński, VP of the CAB and Aluminum Products Segment at the SECO/WARWICK Group, “the challenge is to optimize the process by reducing the cycle time as much as possible while maintaining the desired metallurgical properties throughout the entire load.”
The Jupiter Group plans to recycle over 50,000 tons of aluminum scrap every year once fully operational. This scrap will come from both in-house and customer scrap, purchased scrap, and recycled cans/foils etc. The new rolling mill in India will help the Group expand its footprint in the aluminum industry and produce Made in India products which will be known for its quality and reliable products and services.
“Since the 1990’s,” says Mr. Sandeep Bajaj, CMD of Jupiter Aluminum Industries, JUPALCO, “the Jupiter Group processes aluminum as a partner of the converting and packaging industries. Ecology is an important value for us. It is included in our mission, just like our Partner’s. The rolling mill in India will be one of the most modern facilities of this type in this region, which is why we are equipping it with the best solutions available on the market.”
