Aluminum Parts Manufacturer Increases Capacity with Melting Furnace
A melting and holding furnace with a preheat hearth and a maximum temperature rating of 1,450°F (788°C) has been shipped to a manufacturer to increase capacity for processing aluminum parts.
Lindberg/MPH announced the shipment of a gas-fired reverberatory aluminum melting and holding furnace with a total holding capacity of 85,000 lbs based on 155 lbs per cubic ft. of molten aluminum and a melt rate of 10,000 pounds per hour. A full width vertically rising air operated door provides access to load the preheat hearth and a full width cleanout door at the rear allows for unloading.
Kelley Shreve
General Manager
Lindberg/MPH
Source: Lindberg/MPH
This melting furnace is designed with an elevated base and bottom mounted magnetic stirring mechanism. An air pressure pump well for dispensing molten aluminum provides the operator with greater ease of use and allows the unit to stand idle over long periods of time such as weekends without having a large temperature differential between the pumper and the furnace.
“This aluminum melting furnace design provides maximum melting efficiency and large capacity. The customer supplied magnetic stirring mechanism helps reduce damaging oxide growth,” said Kelley Shreve, general manager at Lindberg/MPH.
