ALUMINUM PROCESSING NEWS
High-Purity Alumina Calcining Processes Support Expansion
One of North America’s leading producers of ultra-high-purity alumina and associated products recently boosted its advanced manufacturing operations with a 50m-long electric tunnel kiln. This installation will support the company’s expansion into the production of a variety of high specification lines.
Alberto Cantú Br<> Vice President of Sales
NUTEC Bickley
The calcination kiln, which was broken down into modules and transported by NUTEC Bickley, has an operating temperature of 2190°F (1200°C) and maximum temperature of 2460°F (1350°C) and processes the material in saggars sitting in six-high stacks that are loaded on to 33 cars. With a firing cycle of 23.6 hours, approximately 5000kg of calcined material is processed each day. In addition, special provisions to prevent equipment wear due to chemical attack that follows degassing of hydrochloric acid during the alumina heating process has been designed by NUTEC Bickley.
“The nature of the material being processed means that tight tolerances and demanding specifications have had to be met,” said Alberto Cantú, vice-president of ceramics at NUTEC Bickley. “[This] demonstrates once again how, when all necessary design parameters are in place, electric heating in continuous kilns can deliver for a wide range of manufacturing processes.”
The use of electric heating is increasingly in demand. Extremely tight thermal control is necessary in the kiln chamber, operating under an oxidizing atmosphere, and this particular kiln has 14 automatic control zones for heating, plus two automatic zones for cooling. To ensure maximum flexibility and management of the temperature profile, the control systems are arranged so that the exhaust, heating zones, and cooling zones are all independently regulated.
The heating system comprises a combination of silicon carbide and metal alloy elements. These hang down vertically through the roof and are sited on either side of the load, with distribution configured to deliver a well-balanced temperature uniformity throughout the kiln. The electrical connection design means that elements can be replaced while the furnace is at operating temperature.
Hot gases are drawn towards the kiln entrance and are evacuated from the tunnel through exhaust ports positioned in the kiln sidewalls, via the exhaust fan. Cooling is achieved by direct air movement in the cooling zones. The temperature set points from the cooling zones are controlled automatically with cooling nozzles positioned to blow a stream of cold air above and below the load setting. The kiln walls use lightweight insulation for rapid thermal response and fuel economy, with the lining rated for use up to 2350ºF (1290°C). The roof is lined with high thermal efficiency ceramic fiber system, and the roof insulation combines modules of polycrystalline fiber and zirconia grade fiber.
Kiln car operation is based on a semi-continuous feed electromechanical pusher with push speed adjustment. The push speed is configurable by selecting the appropriate firing schedule at the kiln control panel. A vestibule arrangement serves to reduce exchange of air and gases between the factory and the kiln. When a car is being introduced into the kiln, the door at the entry end opens, while the door at the kiln entrance is closed.
The vestibule has two sections: the first accommodates a single car and is separated by two vertical lift doors to separate the factory’s atmosphere from the kiln atmosphere. This is managed by installing an exhaust hood which is connected to the entry exhaust fan, thus ensuring a negative pressure in the vestibule to avoid any gases from the kiln from leaving the chamber. The second section functions as a transition from the vestibule door sections to the kiln’s pusher.
High-Purity Alumina Calcining Processes Support Expansion Read More »
CAB Capabilities Expanded for Heat Exchanger Manufacturer
An aluminum heat exchanger manufacturer specializing in the production of heat exchangers recently expanded its production capabilities with a semi-continuous furnace for controlled atmosphere brazing (CAB) aluminum components. The system for semi-continuous operation, based on the cycle multi-stage division, is designed to increase the efficiency and quality of the heat exchangers with ribbed plate construction.
Piotr Skarbiński
SECO/WARWICK
SECO/WARWICK provided this CAB system, often chosen by the HVAC industry and manufacturers of car parts, for the industrial production of heat exchangers. The semi-continuous operation mode ensures uniform heating of elements even with above-average dimensions.
“The key advantages of this solution includes higher hourly efficiency — modern brazing technology ensures shorter production cycle time; stable and repeatable quality — the advanced brazing atmosphere control system minimizes the risk of defects, guarantees faster maintenance as well as no production downtime. . . . The semi-continuous CAB system is popular because it allows users to realize a reduction in costs while producing atmosphere brazing with exceptional quality control,” said Piotr Skarbiński, vice president of Aluminum Process and CAB Business Segment in the SECO/WARWICK Group. “We supply solutions to many companies in Asia, and a large part of the contracts are the result of recommendations we receive from our customers.”
The CAB line includes a drying furnace, an inlet purging chamber, a patented heating and brazing chamber, an intermediate cooling chamber with an air jacket and a direct final cooling chamber. The product moves between stages in a horizontal position based on a continuously adjustable cycle time, depending on the load’s type and configuration. The semi-continuous operation mode ensures that even large-sized heat exchangers will be heated evenly during the correct process time.
CAB Capabilities Expanded for Heat Exchanger Manufacturer Read More »
Manufacturer Expands Aluminum Heat Treat Capabilities
A provider in the power solutions industry has enhanced its operations with a heat treat drop-bottom furnace for the solution heat treatment of aluminum castings. This installation will increase the company’s production capabilities, with the furnace having a load setting of 48 in (123 cm) wide x 36 in (91 cm) high x 141 in (358 cm) long.
The furnace, the fifth designed and manufactured by NUTEC Bickley, has a single temperature control zone, typically operating at 1000°F (573°C), with a maximum of 1075°F (580°C). The load setting will accommodate up to three baskets, equivalent to around 3600 lb (1635 kg) of aluminum parts per cycle. The furnace has been customized to be indirect gas-fired using radiant tube burners. Additionally, the project incorporates a motorized quench tank, rails, movement system, and load/unload platform with elevator device.
Arturo Arechavaleta
Vice President, Metal Furnaces
NUTEC Bickley
“Efficient and effective solution heat treatment is a vital part of the aluminum casting process,” said Arturo Arechavaleta, vice-president of Metal Furnaces at NUTEC Bickley. “Without the sort of advanced system that we have custom-designed, volume production of high-quality aluminum parts is not feasible. We’re proud to have played an important role in this technology partnership.”
The indirect gas firing is via single centrifugal recirculation that produces a vertical flow pattern. Heating is achieved with four radiant tube burners that have individual flame safety devices. The burner system incorporates a motorized control butterfly valve, and the gas flow is controlled by proportional ratio regulators. This design, with its baffle arrangement, delivers an even flow pattern, providing excellent temperature distribution and control in the furnace’s load chamber and high-efficiency heat recirculation (convection) horizontally across the aluminum castings. Excellent temperature uniformity was always considered an important parameter, and this has been shown to be ±5.4°F (±3°C) under full test in the provider’s manufacturing facility.
In order to maintain excellent thermal efficiency in operation, the furnace walls are fully lined using ultra large proprietary ceramic fiber modules. Their configuration and fixing provide for excellent insulation and long life coupled with low maintenance. The insulation layer is 6 in (150 mm) thick and has a density of 12 lb/ft3 (192 kg/m3).
The installation will see the drop-bottom furnace itself stationary — in a fixed elevated position — with the quench tank and loading car moving to accommodate baskets at the selected position. The furnace has a single, pneumatically operated horizontal slide door. For these particular aluminum castings, the company will employ a motorized water quench system provided by NUTEC Bickley, as well as its rails included leveling and installation. The tank has been designed to accept a full load of pieces within the work basket when the furnace is positioned vertically above it.
Press releases are available in their original form here.
Manufacturer Expands Aluminum Heat Treat Capabilities Read More »
Retech Expands with ReMelt Scientific
Retech, which provides advanced technologies for melting and refining reactive and refractory metals, has acquired ReMelt Scientific, broadening the capabilities for the vacuum and aluminum melting divisions of the SECO/WARWICK company. The two companies have been working alongside one another for decades on a less formal basis offering consulting, collaborating and subcontracting services. This acquisition formalizes that partnership.
Earl Good
Managing Director
Retech
ReMelt Scientific, based in Canton, Ohio, specializes in material handling and waste processing equipment for ultra-pure remelt of recycled tailings, scrap, and revert. This acquisition brings an advanced technology experience under one umbrella for clients of Retech’s innovative vacuum metallurgy solutions.
“I think ReMelt is a valuable acquisition and it seems to fit well with the Retech portfolio and the SECO/WARWICK Group business overall,” said Earl Good, managing director of Retech
Sławomir Woźniak
President & CEO
SECO/WARWICK Group
The acquisition will allow the SECO subsidiary to offer more comprehensive solutions in the vacuum metallurgy segment. Vacuum metallurgy, which involves the melting and refining of metals in a controlled atmosphere, is critical for producing high-purity metals and alloys used in various high-tech applications. Aluminum melting is a complex process that requires precise control and advanced technology to ensure the production of high-quality aluminum products. ReMelt’s knowledge in aluminum waste processing and material handling will enable its new parent company to offer state-of-the-art aluminum melting solutions that meet the industry’s stringent demands.
“While ReMelt will join the Retech division, they really are an asset to the whole Group and our worldwide operations as a whole”, said Sławomir Woźniak, CEO of SECO/WARWICK Group.
Retech Expands with ReMelt Scientific Read More »
Aero/Auto Aluminum Manufacturer Expands Heat Treatment
Taiwan Hodaka Technology, an aerospace and automotive manufacturer, extends its market reach by adding an aluminum aging furnace to its heat treatment capabilities. The furnace, which is designed for aging using T77 technology, will allow the company to meet the highest safety and strength standards.
This is the first transaction between Taiwan Hodaka Technology, which is involved in the design and processing of parts made of aluminum alloys, and SECO/WARWICK. The furnace operates in the temperature range from 176° to 428°F (80° to 220°C) with a temperature uniformity in the last heating phase, of ±47.4°F (3°C) in accordance with the AMS 2750 standard.
“The solution supplied by SECO/WARWICK will allow us to enter a new market segment. We are a partner for many key players in the aviation industry. The T77 aluminum aging furnace will enable us to serve customer requirements even better. At the same time, the new technology will support our commitment to reducing our impact on the environment,” said Dr. Sam Chiang, vice president for R&D at Taiwan Hodaka Technology Co. Ltd.
Tomasz Kaczmarczyk, Sales Manager of the Aluminum Process and CAB Furnaces Teams, SECO/WARWICK
For heat treated alloys (2xxx, 6xxx and 7xxx series), the letter T and one or more digits are used after the alloy series symbol. The first digit is the most important, as it indicates the type of heat treatment applied to the alloy, while the remaining digits (if provided) indicate heat treatment variants or their modifications. The 7000 series of aluminum alloys have the highest strength of all other aluminum alloy series and are commonly used in aviation since they are held to the highest safety and strength standards.
“T7 denotes the process of solution heat treatment and artificial aging to an overaged state to obtain specific properties, e.g. increased corrosion resistance,” said Tomasz Kaczmarczyk, sales manager of the Aluminum Process and CAB Furnaces Team at SECO/WARWICK. “Sometimes, in addition to the digit denoting the standard heat treatment, an additional digit is used to denote modifications to the given treatment or stress relief procedures. For example, for 7xxx alloys, the symbol T77 denotes retrogression and re-aging. The use of this process improves the alloy’s corrosion resistance, which is so crucial in the production of aircraft parts. The applied technology will allow Taiwan Hodaka Technology to produce high-quality profiles used in the aviation industry in accordance with the AMS standard.”
Piotr Skarbiński
SECO/WARWICK
“The furnace on order equipped with electric heating will process 1500 kg of aluminum profiles with a maximum length of 5500 mm. This is a two-zone solution with a total heating power of 420 kW. The solution for aluminum aging, powered by electric heaters, eliminates the problem of CO2 emissions and is in line with the ecological trend increasingly common in heavy industry,” said Piotr Skarbiński, vice president of the CAB and aluminum products segment at SECO/WARWICK.
The furnace will be used at the company’s newly built plant in Taiwan.
The project partner was PEERENERGY, which offers thermal process consulting, project management, and equipment supply for the aerospace, military equipment, and semiconductor industries.
Aero/Auto Aluminum Manufacturer Expands Heat Treatment Read More »
Automotive Radiator Manufacturer Bolsters Aluminum Brazing Capacity
A car radiator manufacturer has expanded its heat treatment capacity with an EV/CAB line adapted for the production of oversized battery coolers. The aluminum brazing furnace facilitates the ability to make quick modifications and switch from gas to electric heating in order to meet climate change challenges.
Piotr Skarbiński
SECO/WARWICK
Source: LinkedIn
SECO/WARWICK designed the CAB line with temperature uniformity across the entire belt width in order to accommodate the size specifications of the battery coolers.
“This order is for an aluminum brazing furnace adapted to the production of oversized battery coolers,” said Piotr Skarbiński, vice president of the aluminum and CAB product segment at SECO/WARWICK. “The EV/CAB line with a belt width of 2100 mm (6.89 ft) is designed to produce oversized battery coolers. It consists of a preheating and main heating chamber, a radiation brazing furnace, an air jacket cooling chamber, a final cooling chamber and a control system.”
Automotive Radiator Manufacturer Bolsters Aluminum Brazing Capacity Read More »
News From Abroad: Looking Forward to Production Efficiency, Sustainability
Today’s News from Abroad installment examines strategies global manufacturers are investigating and enacting to move the industry toward the next generation of production efficiency and sustainability through decisive equipment investments, cooperative research efforts, and innovative processing breakthroughs.
Heat Treat Today partners with two international publications to deliver the latest news, tech tips, and cutting-edge articles that will serve our audience — manufacturers with in-house heat treat. heat processing, a Vulkan-Verlag GmbH publication, serves mostly the European and Asian heat treat markets, and Furnaces International, a Quartz Business Media publication, primarily serves the English-speaking globe.
Extruder Expands Production With Additional Homogenization Line
Continuous homogenization furnace installed at Exlabesa at its A Coruña plant
Source: SMS Group
“The recently commissioned state-of-the-art melting furnace is specifically designed to produce recycled billets from post-consumer aluminum scrap that has reached the end of its life cycle. The subsequent expansion of the foundry, which focuses on Hertwich’s new continuous homogenization plant, will once again significantly increase the capacity for processing new scrap. This makes Exlabesa less dependent on the procurement of primary aluminium and at the same time conserves resources. These investments underline Exlabesa’s commitment to greater sustainability and the reduction of CO2 emissions by promoting a cleaner and more efficient industry based on the principles of the circular economy.”
READ MORE: “Exlabesa expands aluminium recycling capacities with additional continuous homogenisation plant from Hertwich Engineering” – at heat-processing.com
Breakthrough: World’s first successful industrial-scale hydrogen Casting
First successful industrial-scale production of aluminium slab using hydrogen combustion explores the performance of hydrogen as a substitute for natural gas at an industrial scale
Source: Unsplash
“Constellium announced the successful completion of its first industrial-scale hydrogen casting at C-TEC, Constellium’s primary R&D center. This casting was performed in a 12-ton furnace following strict internal procedures. . . . ‘The 12-ton aluminium slab produced using hydrogen will be further processed at our Neuf-Brisach site in France for use in electric vehicles. This milestone is significant in our roadmap towards decarbonising our industrial activities, as we have begun exploring the performance of hydrogen as a substitute for natural gas at an industrial scale, provided that hydrogen is green, more accessible, and cost-effective for industrial applications.’”
READ MORE: “World’s First Successful Industrial-Scale Production of Aluminium Slab Using Hydrogen Combustion” at furnaces-international.com
New Production Line Moves Steelmaker Closer to Next Generation
Curved section of Primetals Technologies’ Stelmor Conveyor for future in-line direct solution treatment (DST) processing
Source: Primetals
“A further benefit for Yantai Walsin was the fact that the bar-in-coil outlet realizes in-line quenching for austenitic and ferritic stainless products, leading to a reduction of subsequent post-processing annealing. Moreover, Primetals Technologies has designed the equipment to accommodate a future addition of an in-line solution for the direct treatment of wire rod products, which also reduces subsequent post-processing annealing. For bar products, the producer now uses a rapid transfer system to slow cooling bins for martensitic grades.”
READ MORE: “Primetals Technologies Awarded FAC for Yantai Walsin’s Stainless Steel Combination Mill” at heat-processing.com.
Toward Climate-Neutral Steel Production: Replacing Blast Furnace With Direct Reduction Plant
Dr. Heike Denecke-Arnold (left), Chief Operations Officer Executive Board of thyssenkrupp Steel Europe AG, and Gretta Stephens, Chief Executive for Climate Change and Sustainability at BlueScope Steel (right)
Source: thyssenkrupp
“thyssenkrupp expands its research activities in the field of CO2 low-carbon steel production in cooperation with BlueScope Steel. At the heart of this collaboration are the smelting units, which are a central component of the first transformation step towards climate-neutral steel production: the replacement of the first blast furnace with a direct reduction plant (DR plant) with downstream smelters. . . . As part of the research cooperation with BlueScope Steel, which is scheduled to run for four years, the process understanding and plant management are to be optimized in the run-up to the commissioning of the smelter. These include electrode management, furnace operation, process parameters, refractory material and maintenance.”
READ MORE: “Cooperation on low-CO2 steel production” at heat-processing.com.
News From Abroad: Looking Forward to Production Efficiency, Sustainability Read More »
Aluminum Parts Manufacturer Increases Capacity with Melting Furnace
A melting and holding furnace with a preheat hearth and a maximum temperature rating of 1,450°F (788°C) has been shipped to a manufacturer to increase capacity for processing aluminum parts.
Lindberg/MPH announced the shipment of a gas-fired reverberatory aluminum melting and holding furnace with a total holding capacity of 85,000 lbs based on 155 lbs per cubic ft. of molten aluminum and a melt rate of 10,000 pounds per hour. A full width vertically rising air operated door provides access to load the preheat hearth and a full width cleanout door at the rear allows for unloading.
Kelley Shreve
General Manager
Lindberg/MPH
Source: Lindberg/MPH
This melting furnace is designed with an elevated base and bottom mounted magnetic stirring mechanism. An air pressure pump well for dispensing molten aluminum provides the operator with greater ease of use and allows the unit to stand idle over long periods of time such as weekends without having a large temperature differential between the pumper and the furnace.
“This aluminum melting furnace design provides maximum melting efficiency and large capacity. The customer supplied magnetic stirring mechanism helps reduce damaging oxide growth,” said Kelley Shreve, general manager at Lindberg/MPH.
Aluminum Parts Manufacturer Increases Capacity with Melting Furnace Read More »
man and women right of image, bg: EBNER Group text with colorful image; left image of furnace
EBNER Group Extends Heat Treatment Reach with Stake in Furnace Manufacturer
EBNER Group, a global provider of heat treatment solutions, melting, and casting for the aluminum industry has increased its stake in a furnace manufacturer, including annealing furnaces. GNA alutech inc. produces aluminum melting and holding furnaces, homogenizing and annealing furnaces, and cathode sealing equipment.
white male, blue suit jacket, blue shirt, dark hair, dark bg
Robert Ebner
CEO, EBNER Group
Source: EBNER Group
“We are excited to announce the full acquisition of GNA alutech inc. and would like to thank GNA’s founder, Ted Phenix, for his vision and leadership in building GNA into a successful company over 41 years. Over the last 5 years I was always impressed by the deep understanding and knowledge Ted was able to share with customers. Our strong professional developed to a strong personal friendship,” said Robert Ebner, CEO of EBNER Group.
EBNER Group provides heat treatment solutions for the aluminum industry with the companies EBNER, ETS, EED, Gautschi, TPS, Hazelett, HPI, and GNA, increasing its stake in the latter to 100%. The acquisition marks the culmination of a five-year partnership between EBNER and Ted Phenix, which began with EBNER Group acquiring a majority stake in GNA in 2019.
The leadership of GNA has been placed in the hands of Kaleb Wright, president of business development, and Chantal Coupal, president of operations.
Pictured: Chantal Coupal, president of operations of GNA alutech, and Kaleb Wright, president of business development of GNA alutech
EBNER Group Extends Heat Treatment Reach with Stake in Furnace Manufacturer Read More »
Gray drop bottom furnace bg with headshot male, dark hair, white shirt
Aerospace Heat Treating Upgrades Capacity with Drop Bottom Furnace
An electrically heated drop bottom furnace with a traveling quench tank and a maintenance platform has been shipped to an aerospace company for the solution heat treatment
Mike Grande
Wisconsin Oven Corporation
Source: Wisconsin Oven Corporation
of aluminum parts.
Wisconsin Oven designed the drop bottom furnace with sufficient capacity to heat 600 pounds of aluminum per load and provide a quench delay that does not exceed 5 seconds. The system also includes a slow drop speed program to be used for heating applications that do not require a quench.
“This drop bottom furnace was designed with a 5 second quench delay, and a temperature uniformity of +/- 5°F at the set points 850°F and 1,100°F. In addition, the system was tested to be in compliance with AMS2750F, Class 1 furnaces and instrumentation Type C prior to shipment from our manufacturing facility,” said Mike Grande, vice president of sales at Wisconsin Oven.
Aerospace Heat Treating Upgrades Capacity with Drop Bottom Furnace Read More »
