ALUMINUM PROCESSING NEWS
Aluminum Extruder Expands Nitriding Capabilities
Marcin Stokłosa
Project Manager
Nitrex Poland
LinkedIn.com
HTD Size-PR LogoQatar Aluminium Extrusion Co. (Qalex) recently received a nitriding system. The aluminum profiles manufacturer wanted to equip a second extrusion plant with an independent nitriding furnace to save on handling, processing time, and costs associated with having to transport extrusion dies back and forth from its first factory for nitriding work.
The client chose a compact system from Nitrex, an international provider in surface treatment with North American locations. The model NXK-1015 furnace is equipped with process technology designed for nitriding extrusion dies.
Marcin Stokłosa, project manager at Nitrex Poland, said, "Qalex was . . . very pleased with our technical support and spare parts accessibility. What they ordered is an exact copy of the first Nitrex installation – an identical configuration with the same furnace model, size and process technology."
Installation and startup were completed in January 2022.
Aluminum Extruder Expands Nitriding Capabilities Read More »
VIVA ALUMINIUM SYSTEMS Acquires Turnkey System for Nitriding
HTD Size-PR LogoVIVA ALUMINIUM SYSTEMS – a Vias Group member – has recently acquired a turnkey system for nitriding extrusion dies after experiencing heightened demands for its extrusion profiles.
Marcin Stokłosa
Project Manager
Nitrex Poland
Photo Credit: LinkedIn.com
With these demands from the industrial and construction markets, VIVA decided to expand its manufacturing capacity, installing an additional extrusion press and nitriding equipment. The new pit furnace has an effective work zone of 39" diameter by 59" high (1000 x 1500 mm) with the capacity to nitride a 4400 lbs. (2000 kg) load. The Nitreg® process technology adapts to the application requirements, achieving a high throughput per extrusion run and scoring a high number of runs per treated die, which in turn optimizes tool life and lowers tooling cost for a faster return on investment.
"We are delighted to do business with VIVA again," states Marcin Stoklosa, product manager at Nitrex. "Fostering customer loyalty is a top priority at Nitrex and key to building an ongoing partnership for future growth."
VIVA ALUMINIUM SYSTEMS Acquires Turnkey System for Nitriding Read More »
ELLWOOD Aluminum Acquires 200,000-Lb. Batch Homogenizing Furnace
ELLWOOD Aluminum, an Ohio-based manufacturer of aluminum products, recently acquired a 200,000-lb. batch homogenizing furnace to complete the Phase 2 expansion of their plant in Hubbard, OH.
Gillespie & Powers, Inc., a family-owned supplier based in St. Louis, MO, will deliver the furnace to be operational in July 2022. The furnace, the second of its kind at ELLWOOD Aluminum, will be used for manufacturing large diameter aluminum ingots and billets, as well as rectangular slabs and cast plates.
ELLWOOD Aluminum Acquires 200,000-Lb. Batch Homogenizing Furnace Read More »
ELVIAL Increases Heat Treat Capabilities for Aluminum Products
Marcin Stokłosa
Project Manager
Nitrex Poland
LinkedIn.com
HTD Size-PR LogoELVIAL S.A.,a large aluminum extrusion company in Greece, has purchased an aluminum extruder furnace to meet needs created by their plant's expansion and increasing manufacturing capacity.
"This additional NX-815 E furnace [. . .] will help increase the production of building materials by the company," says Marcin Stokłosa, project manager at Nitrex. "The first furnace has been operational since 2016."
The NX-815 E is a retort furnace used for extrusion. It operates with NX connect software, and uses the NITREG-C (nitrocarburizing) and NITREG (gas nitriding) technologies for dies extrusion. The order also included a lifting device. All processes for this furnace are compliant to AMS 2759/10.
An ELVIAL representative cited good equipment, technology and service to explain why ELVIAL chose to do business with the supplier this second time.
heat treat buyers guideLooking for Endothermic generators? See listings for equipment and services in the Heat Treat Buyers Guide
ELVIAL Increases Heat Treat Capabilities for Aluminum Products Read More »
Automotive Heat Treater To Receive Vacuum Aluminum Brazing Furnace
HTD Size-PR LogoA manufacturer in the automotive industry has placed an order for a large-capacity, high vacuum furnace, equipped with a cooling station to increase the performance of the system. This furnace will complete their new production plant and aid in vacuum aluminum brazing various components.
Maciej Korecki
Vice President, Business Segment Vacuum Heat Treatment Furnaces
SECO/WARWICK
(source: SECO/WARWICK)
SECO/WARWICK, the sister company of North American manufacturer SECO/VACUUM, provided the furnace to the automotive manufacturer of engines, filters, electric equipment, and cooling systems. For this project, the client required that the vacuum furnace have automatic loading and transportation of parts, as well as an increase in precise control of temperature uniformity and distribution.
"The equipment [. . .] has been installed in a new production plant that will significantly improve the capacity of the entire group," explains Maciej Korecki, vice president of the Business Segment of Vacuum Heat Treatment Furnaces at SECO/WARWICK. "A key to success in this project was the huge trust displayed by our partner and close cooperation at the design stage."
heat treat buyers guideLooking for vacuum aluminum brazing furnaces? See listings for services and products in the Heat Treat Buyers Guide
Automotive Heat Treater To Receive Vacuum Aluminum Brazing Furnace Read More »
Where is Aluminum Headed?
Source: heatprocessing
Today's shared content is provided by the global information partnership between leading European heat treat news provider heatprocessing and the team at Heat Treat Today.
It may be starting in Europe, but through "free and fair-trade", increasing aluminum use may find its way around the world. On September 28th and 29th, engineers and business advocates gathered at the ALUMINUM Business Summit to discuss mobility, digitization, sustainability, and the market development of steel. This article, written by Dr. Gerd Götz, Director General at European Aluminium, is a preview to the discussions that took place.
"Aluminium is a sustainable material essential to Europe’s green transition. It is used in solar panels, wind turbines, electric vehicles, transmission cables for renewable electricity, etc. The endless recyclability of aluminium further contributes to decarbonization and the circular economy."
Read this article and others in the magazine at: The FREE Edition of heatprocessing's 2-3 2021
Where is Aluminum Headed? Read More »
Alugen Aluminum Brings Manufacturing Operations In-House
Alugen Aluminium, a Turkish aluminum extrusion company, recently expanded their production capabilities with a high-performance compact nitriding/nitrocarburizing system. This system will allow the company to bring all manufacturing operations in-house for more optimal work-planning and quality control.
"In partnering with Nitrex," says Özcan Sürücü, die shop manager at Alugen Aluminium, "we [Alugen] have become self-sufficient from an operational point of view, no longer relying on external contractors to fill this work gap. This allows for more effective planning and ensures that all projects, whether big or small, are done on time and on budget."
Özcan Sürücü, Die Shop Manager, Alugen Aluminium
(Source: Nitrex.com)
The decision to bring nitriding operations in-house with Nitrex's multipurpose batch-type furnace was based on improved quality consistency and cost-effectiveness of Alugen's gas nitriding processes. With the company expanding over the years in order to meet demand, this recent addition to Alugen's manufacturing process has enabled them to meet customer requests to "mix special dies with regular production dies for a faster turnaround of product-specific production plan," according to Marcin Stoklosa, project manager at Nitrex Poland.
(photo source: Alugen Aluminum website)
(photo source: Nitrex website)
Alugen Aluminum Brings Manufacturing Operations In-House Read More »
Youngstown Tool & Die Purchases Vacuum Heat Treat Furnace
Youngstown Tool & Die (YTD), an Ohio manufacturer of aluminum extrusion dies, upgrades its in-house atmosphere heat treatment capabilities with the purchase of two high-pressure gas quench (HPGQ) furnaces. The decision to buy stems from the manufacturer’s plans to expand within their community.
Dave Mrdjenovic, General Manager, Youngstown Tool & Die (photo source: Youngstown Tool & Die)
“Our expansion,” said Dave Mrdjenovic, General Manager at YTD, “has been facilitated by a localized government development program to expand employment and business development in our area, so we are moving quickly to take advantage of the program. Upgrading our existing atmosphere furnaces to high pressure gas quench vacuum furnaces will significantly improve our performance as we grow.”
The two Vector® HPGQ furnaces were provided by SECO/VACUUM (a SECO/WARWICK Group company).These furnaces are designed for the heat treatment of dies in all types of applications, such as stamping, molding, and extrusion as well as for other uses. Because Vector’s HPGQ system cools dense masses both evenly and quickly without distortion, die quality and consistency are improved compared to the more historically used atmosphere heat treatment methods. These furnaces create a bright and clean final product.
Vector Furnace (photo source: SECO/WARWICK Group)
Youngstown Tool & Die Purchases Vacuum Heat Treat Furnace Read More »
Leading Automotive Tier 1 Supplier Orders Eight Custom Furnaces
A leading tier 1 automotive supplier recently placed a large order for eight (8) custom designed walk-in ovens for aluminum aging of automotive parts with furnace manufacturer DELTA H.
(source: DELTA H)
The ovens will be qualified at class 2 (+/-10°F) and feature all necessary performance requirements for compliance to CQI-9 and AMS2750E specifications. DELTA H collaborated with the customer for 6 months on the design and approval phase.
All 8 ovens will be commissioned in late summer 2020.
(source: Erik Mclean/DELTA H)
Leading Automotive Tier 1 Supplier Orders Eight Custom Furnaces Read More »
Auto Industry Receives Rapid Furnace from North American Manufacturer
A research organization recently awarded a contract to a North American furnace manufacturer for the supply of a rapid-heating furnace to be used for product development of lightweight hot-stamped and formed aluminum automotive components. This organization will integrate the aluminum-sheet heating furnace with existing equipment to support both automotive manufacturers and Tier 1 suppliers throughout North America.
(source: Can-Eng)
Can-Eng Furnaces International Ltd., of Niagara Falls, Ontario, was chosen for this project because it has significant experience in the development of lightweight, thin-walled automotive structural components. Can-Eng provided the customer with a unique rapid-heating furnace system that offers significant reduction in floor space requirements, flexibility for processing a wide range of product sizes, and the flexible operating temperatures required for various stamped and formed products. The system will be fully integrated with flexible robotic handling and material handling automation.
(source: Fred Anyona on Unsplash)
Auto Industry Receives Rapid Furnace from North American Manufacturer Read More »
