ANNEALING NEWS
2 Horizontal Quench Systems Expand Semiconductor Operations
Two electrically heated horizontal quench systems have been shipped to a supplier for the semiconductor industry. The systems will be used for the annealing and rapid cooling of various high purity alloy parts.
The operating procedure for each horizontal quench system from Wisconsin Oven includes loading the product on a work grid located on the loading platform. Once the load is lifted into place, a pusher/extractor mechanism located at the front of the quench tank moves the load onto the quench lift platform, then the furnace pusher/extractor mechanism pulls the load into the furnace for annealing.
After completing the heating cycle, the vertical lift door opens, the furnace pusher/extractor transfers the load onto the quench lift platform, and the load is lowered into the water quench tank. After the load has sufficiently cooled, the quench lift is raised, and the front mounted pusher/extractor mechanism pulls the load back onto the scissor lift. While the load is pulled onto the scissor lift, a blow off system removes the majority of the water from the load.
See below to watch a video of this system in operation.
https://www.youtube.com/embed/U64eD4tpPBE?si=W3EU1y_7gANzYMyZ
2 Horizontal Quench Systems Expand Semiconductor Operations Read More »
Exothermic Atmosphere Generator Supplied to Skana Aluminum
Skana Aluminum Company in Manitowoc, Wisconsin, has recently been supplied with an Exogas™ exothermic atmosphere generator.
The atmosphere generator from SECO/WARWICK USA, an American SECO/WARWICK Group subsidiary, provides an indirect-chilled exothermic atmosphere for annealing, brazing, normalizing, drawing, and tempering.
Says Marcus Lord, managing director of SECO/WARWICK USA, “At 30,000 CFH, it is one of the largest atmosphere generator units we’ve made to date. It should be plenty large enough to meet the exothermic atmosphere needs of the multiple processes within the Skana plant.”
Skana has also placed an order with the furnace supplier for a smaller atmospheric gas drier for use elsewhere in the plant.
Exothermic Atmosphere Generator Supplied to Skana Aluminum Read More »
Vacu-Braze recently installed a new water quenching furnace in their Quakertown, PA, facility. This acquisition will allow for the expansion of capabilities to include rapid quenching of specialty aerospace materials such as steels or titanium.
The new furnace from Lucifer Furnaces, measuring 45.5”x29.5”x28,” contains argon and nitrogen atmosphere capabilities which allow for processing in a protective atmosphere even at high temperatures while maintaining AMS 2750 compliant uniformity. The pyrometry team at Vacu-Braze was able to achieve Class 2 pyrometry, opening up more available processes such as annealing, austenitizing, normalizing, stress relieving, solution treating, and tempering.
"Lucifer Furnaces was selected for the order," commented Jerry Novak, process engineer at Vacu-Braze, "[as their furnaces] are locally made and could be custom designed for the application. They are built in Eastern Pennsylvania to our desired specifications. Vacu-Braze is always happy to partner with companies that manufacture quality equipment and products in the USA."
The heat treat company also noted that this piece of equipment expands their services to existing clients while providing processes for new clients.
Vacu-Braze Receives New Quenching Furnace for Specialty Aerospace Materials Read More »
ThermTech Expands in Wisconsin
A heat treat company based in Waukesha, WI, has expanded with a 95,000 square foot building in New Berlin, WI. The New Berlin facility is seven miles from their Travis Road campus.
Steve Wiberg and Mary Wiberg Springer, owners of ThermTech, share that the plant’s square footage will be 270,000. The new space will be used for the company’s expansion. The new facility will allow the heat treater to continue to meet their clients’ needs as they expand their core offerings: hardening, tempering, surface heat treatment, carburizing, vacuum treatments, annealing, press quenching, austempering, and aluminum heat treatment.
ThermTech Expands in Wisconsin Read More »
3 Heat Treat Rod Overbend Furnaces Shipped
Three electrically heated RO pit furnaces with air-cooled fans have been shipped from Riverside, MI. The furnaces will be used for heat treating various steel components.
“These pit furnaces are designed for a nitrogen atmosphere,” commented Kelley Shreve, general manager at Lindberg/MPH. “They have been designed to utilize three independent heating zones for optimal temperature uniformity and meet AMS 2750G Class 3.”
These heat treating pit furnaces from  have a maximum temperature rating of 2,000°F and are designed to handle a wide range of part sizes. Two of the units have work chamber dimensions of 28″ x 36” and a maximum gross workload of 2,000 lbs. each. The third furnace has work chamber dimensions of 60” x 109” and a maximum gross workload of 20,000 lbs.
All of the pit furnaces have pneumatically operated lids with three-way hand control valves and limit switches that disconnect power to the heating elements when the covers are open. The pit furnaces are electrically heated with heavy duty rod overbend heating elements.
3 Heat Treat Rod Overbend Furnaces Shipped Read More »
NC Forgings Producer Secures Heat Treat Line
A roller hearth iso-thermal annealing line for steel automotive impression forgings is to be installed for a major American producer located in North Carolina.
The system comes from CAN-ENG Furnaces International Limited. It will be capable of both iso-thermal annealing and normalizing with a high temperature furnace operating under exothermic atmosphere. The line includes a separate low temperature roller hearth furnace, automatic bin dump and loading system, integrated tray/basket return system, and level II automation technology. The time frame for the heat treat line installation is in Q2, 2024.
Prior to the sale of this heat treat furnace, the furnace supplier had provided a mesh belt normalizing furnace, cast link belt normalizing furnace, and a roller hearth iso-thermal annealing furnace to the forgings producer.
NC Forgings Producer Secures Heat Treat Line Read More »
Firearms Manufacturer Adds Annealing Vacuum Furnace
A vacuum furnace was recently shipped to a firearms manufacturer based in the Midwest United States. The heat treat furnace will primarily be used to anneal firearm components.
Solar Manufacturing, based in Sellersville, PA, shipped a Model HFL-5748-2IQ furnace that has a graphite insulated hot zone of 36” x 36” x 48” with a weight capacity of 5,000 lbs., and maximum operating temperature of 2400°F.
“This was the first vacuum furnace our customer had purchased for their in-house heat treating,” commented Adam Jones, sales manager for the Midwest region at Solar Manufacturing. The company assisted with the furnace installation.
Firearms Manufacturer Adds Annealing Vacuum Furnace Read More »
Power Generation Systems Manufacturer To Expand Heat Treat
Peter Zawistowski
Managing Director
SECO/VACUUM Technologies, USA
Source: SECO/WARWICK
A global developer of power generation systems is planning to expand heat treat capabilities with a 2-bar vacuum furnace.
SECO/VACUUM was awarded this contract and will provide a Vector® single chamber high-pressure quench vacuum furnace to expand the company's processing capacity, including high vacuum sintering and annealing. The new furnace will provide deep vacuum levels needed for the global developer's highly specialized applications.
"Securing continued business with this [client] is about working with people as much as it is working with machines," commented, Peter Zawistowski, managing director of SECO/VACUUM. This order is for a nearly identical furnace to one the same heat treat client ordered last year, which "really validated not just our furnace quality but also the teamwork and customer service behind it."
Power Generation Systems Manufacturer To Expand Heat Treat Read More »
Manufacturer Adds Gas Generator To Improve Sustainable Heat Treating
Marcio Boragini
Sales Director for Brazil at UPC-Marathon
Source: LinkedIn
A gas generator was recently installed for Jomarca, one of the biggest manufacturers of fasteners, bolts, nuts, and fixing elements in Brazil. The generator will supply exothermic gas to a continuous wire annealing furnace, which is part of the manufacturer’s efforts to meet market demand efficiently and sustainably for baling wire in the construction industry.
Using exothermic gas instead of nitrogen, the company expects to reduce operating costs, increase production efficiency, and improve the wear properties and finish of its wire products.
“By providing them with our latest generator technology," commented Marcio Boragini, sales director for Brazil at UPC-Marathon, "we have helped Jomarca improve process efficiency, achieve sustainability, and exceed their customers’ expectations for high-quality wire products.”
Jomarca already owns two endothermic gas generators from UPC-Marathon, a Nitrex company with headquarters in North America. In March of this year, the company upgraded its wire operations with a 150 m3/h capacity ExoFlex generator to ensure consistent gas composition and prevent scale formation on the wire surface.
Manufacturer Adds Gas Generator To Improve Sustainable Heat Treating Read More »
NAS Announces Expansion, New Jobs in Kentucky
North American Stainless (NAS), a stainless steel producer in the United States, will proceed with a $244 million expansion to its Ghent, Kentucky facility in Carroll County. This expansion adds 70 new jobs to the plant.
For its 13th expansion since 1990, NAS will build a new cold rolling mill, roll grinders, an extensive upgrade of its annealing and pickling lines to support the new rolling mill, a new temper mill and the expansion of the Melt Shop Building to include a 400-metric ton crane. The new expansion will grow NAS’ 4.4 million-square-foot facility in Carroll County. NAS offers a full range of stainless flat and long products. All of NAS’ production lines are located onsite at its 1,600-acre headquarters.
Andy Beshear
Governor of Kentucky
"Our latest expansion will bring more clean, sustainable and American-made stainless to consumers and directly compete with the subsidized imports of stainless,” said Cristobal Fuentes, CEO at NAS. “Our parent company Acerinox was eager to further invest in Kentucky to demonstrate its commitment to our customers and the U.S. market.”
“I’m excited to announce more growth in Kentucky’s metals industry with this latest investment from North American Stainless,” said Andy Beshear, Governor of Kentucky.
NAS Announces Expansion, New Jobs in Kentucky Read More »
