ANNEALING TECHNICAL CONTENT
Seven Types of Annealing, and Why Bearing Manufacturers Should Turn to Spheroidization
Sources: Machine Manufacturing; Knergize.com
Heat treating more often than not includes the process of annealing in order to induce precise softness; to alter ductility, strength, or properties; or to produce a definite microstructure. Because of the wide variety of steels and metal alloys, it is important for heat treaters to match the correct annealing process with the steel grade and to the application of the parts being treated.
Machine Manufacturing has provided a summary of the annealing process and listed seven types of annealing, describing the process and the objectives for each. Included in the list are:
  1. Complete Annealing
  2. Isothermal Annealing
  3. Incomplete Annealing
  4. Spherification Annealing
  5. Diffusion, or Uniform, Annealing
  6. Stress Relief Annealing
  7. Recrystalization Annealing
Read more: "What Is Annealing and 7 Types of Annealing Process"
Dr. S.B. Sarkar
And to take the analysis into more specific types of annealing, over at Knergize.com, Dr. S.B. Sarkar discusses Spheroidized Annealing and its benefit to bearing manufacturers, describing the metallurgical science behind the process, noting the need to adhere to international standards and specifications, and addressing equipment management and quality control of the process.
Read more: "Why Spheroidised Annealing of Bearing Steel Is Important for Manufacturing Good Quality Bearings"
Photo credit
Seven Types of Annealing, and Why Bearing Manufacturers Should Turn to Spheroidization Read More »
New Material Retains High Transmissivity After Heat Treatment, Applied to Optical Devices
Source: Phys.Org
Researchers at Toyohashi University of Technology have collaborated with their counterparts at Massachusetts Institute of Technology (MIT) to develop a new material capable of retaining high transmissivity after annealing at 850°C (1562°F). The results address the challenge manufacturers face when combining different materials that react differently to heat treatment at certain temperatures.
Read more: “High-Refractive-Index Material Retains High Transmissivity After Annealing at 850 Degrees C”
New Material Retains High Transmissivity After Heat Treatment, Applied to Optical Devices Read More »
BILSTEIN CEE a.s. Orders EBNER HICON/H2® Bell Annealer Facility
BILSTEIN CEE a.s, based in the Czech Republic, is part of the globally active BILSTEIN GROUP. The BILSTEIN GROUP produces various grades of high-quality cold rolled strip for a wide variety of applications.
Two years ago an order was placed with EBNER to supply a HICON/H2® bell annealer facility to heat treat steel strip coils, comprising four workbases.
Although this facility was commissioned successfully less than one year ago, BILSTEIN CEE a.s. awarded EBNER the contract for the expansion of this facility by a further three workbases.
The new workbases will be commissioned in 2017, increasing production by about 60%.
BILSTEIN CEE a.s. Orders EBNER HICON/H2® Bell Annealer Facility Read More »
Direct-Chill Casting
BOTW-50w  Source:  Total Materia
Direct-chill (DC) casting is currently the most common semi-continuous casting practice in non-ferrous metallurgy. The process is characterized by molten metal being fed through a bottomless water cooled mould where it is sufficiently solidified around the outer surface that it takes the shape of the mould and acquires sufficient mechanical strength to contain the molten core at the centre. As the ingot emerges from the mould, water impinges directly from the mould to the ingot surface (direct chill), falls over the cast surface and completes the solidification.
Read More:  Direct-Chill Casting
Direct-Chill Casting Read More »
