ATMOSPHERE AIR FURNACES NEWS
Aero and Turbine Heat Treat Expands for Titanium Steel Castings Manufacturer
A front-loading box furnace delivered to a northeastern U.S. supplier of titanium castings will expand the manufacturer’s aerospace and gas turbine castings heat treat abilities. The company supplies to the aerospace and power generation fields and deals with exotic metals that are ideal for superior products using the lost wax process for castings, such as nickel and cobalt-based alloys.
L&L Special Furnace Co., Inc. Box Furnace
Source: L&L Special Furnace Co., Inc.
The L&L Special Furnace Co., Inc. model FB435 has an effective work area of 48” wide by 32” tall by 60” deep and has certifiable temperature uniformity of ±10°F from 500 to 1,850°F. Additionally, the elements are very evenly spaced around the chamber and the furnace is lined with ceramic fiber on the sides and top.
The furnace case is sealed internally for atmosphere control, and an inert blanketing gas such as nitrogen is used to displace oxygen present within the work chamber. This provides a surface finish in which oxidization is less likely to form on the part. The atmosphere is delivered automatically through a flow panel by the furnace control.
Aero and Turbine Heat Treat Expands for Titanium Steel Castings Manufacturer Read More »
Tool Manufacturer To Expand Heat Treat Capabilities with Pit Furnace
Lindberg/MPH, a manufacturer based in Michigan, shipped the steam treating furnace which has a maximum temperature rating of 1,250°F and work chamber dimensions of 22" diameter x 36" depth. The pit furnace is insulated with vacuum formed ceramic fiber modules that allow for rapid heat up rates and fast control response. A circulation fan distributes heat evenly throughout the chamber which ensures rapid and uniform heat transfer throughout the product load.
Tool Manufacturer To Expand Heat Treat Capabilities with Pit Furnace Read More »
2 “Heavy Duty” Furnaces Expand Tempering Capabilities for Ohio Heat Treater
Twin convection furnace systems were recently supplied to Winston Heat Treating. The furnaces replaced two older tempering systems. The new systems are for ferrous alloys and aging PH stainless steels.
David Reger
President at Winston Heat Treating
Source: LinkedIn
The SCAHT®-HD (Heavy Duty) Series furnaces, from DELTA H®, are set up with Instrumentation Type B and have two load thermocouples. The furnaces have a certified TUS volume of 2 feet wide, 1.5 feet high and 2 feet deep with a maximum continuous operating temperature of 1,200°F.  Both are designed to receive baskets of parts from many nearby heat treating operations for secondary heat treatments. Temperature control and data acquisition are provided by Super Systems and feature the SSi 9130 controller/programmer. ATP qualified them as Class 2 (+/- 10°F) from 300°F to 1200°F.
“We were looking for a partner to replace existing tempering furnaces that had become too costly to maintain and could no longer meet required pyrometry standards. Our goal was to install reliable and modern furnaces that were specialized for our small batch/job shop work," said David Reger, president at Winston Heat Treating and a Heat Treat Today's 40 Under 40 recipient.
2 “Heavy Duty” Furnaces Expand Tempering Capabilities for Ohio Heat Treater Read More »
Heat Treat Brought In House for North American Producer
HTD Size-PR LogoA North American producer of mining, construction, and material handling products added a continuous quench and temper furnace system as part of a larger plant expansion to bring foreign outsourced manufacturing in house.
Can-Eng Furnaces International Limited's furnace will be part of an automated manufacturing cell and fed automatically from upstream handling equipment. The multizone belt style temper furnace employs high efficiency natural gas-fired heating and recirculation systems. Having the furnace system in house will not only improve part quality but also help eliminate overall shipping costs and reduce supply chain issues.
Heat Treat Brought In House for North American Producer Read More »
Manufacturer To Expand Heat Treat Capabilities with Box Furnace
Bill St. Thomas
Business Development Manager
Lindberg/MPH
Source: Lindberg/MPH.com
A manufacturer is expanding their heat treat capacities with a new box furnace, designed for air atmosphere applications, from a North American furnace provider.
Lindberg/MPH's heat treat furnace has a maximum temperature rating of 1,250°F and a load capacity of 6,000 lbs and is designed to accept fixtures that are 48" wide by 84" deep by 48" high. A full-width roller hearth is located across the furnace chamber floor for manual loading and load support. Temperature is controlled by a Honeywell DC2500 Series controller with an adjustable alarm set-point and latching output relay; the controller disconnects the power to the heating elements and sounds an audible alarm in an event that temperature exceeds desired set-point.
“The high velocity forced heating system circulates heat evenly within the furnace chamber," commented Bill St. Thomas, business development manager at Lindberg/MPH. "[This] assures rapid and uniform heat transfer throughout the workload.”
Manufacturer To Expand Heat Treat Capabilities with Box Furnace Read More »
Atmosphere-Controlled Retort Burn-Off Furnace Delivered to Midwest Manufacturer
HTD Size-PR LogoA heat treat furnace has been delivered to a Midwest manufacturer of ceramic matrix parts. This system will be used for aerospace and military purposes.
Atmosphere-Controlled Retort-Burn Off Furnace
Source: L&L Special Furnace Company, Inc.
Ceramic matrix parts materialize when nanofibers of silicon carbide or other ceramic nano threads are wound together, forming various sheets and 3D-printed shapes. The nano threads in the process are coated with proprietary resins that must be completely removed from the substructure using heat. The resulting finished product is lighter and stronger than titanium.
L&L Special Furnace Company, Inc.'s Model XLC3672 has a work zone of 32” wide by 32” high by 66” deep. It has a single zone of control with a temperature gradient of ±20°F at 1,100°F using four zones of temperature control with biasing to balance any temperature gradients. The Model XLC3672 is controlled by a Eurotherm Nanodac Mini 8 program mechanism with overtemperature protection.
Atmosphere-Controlled Retort Burn-Off Furnace Delivered to Midwest Manufacturer Read More »
Heat Treating System Delivered to Tinker Airforce Base in Oklahoma
HTD Size-PR LogoA heat treat system for use in the aerospace and defense industry was recently delivered to Tinker AFB, OK - USAF.  The system is certified to AMS2750G and will be used to heat treat aluminum as well as other metals for use on military aircraft.
Richard B. Conway
Founder/Director/ CTO
DELTA H® Technologies, LLC
Source: DELTA H
DELTA H® and Phillips Federal delivered the furnace to Tinker AFB, which will be used for for heat treating aviation grade aluminum for military purposes. Third party services for calibration and qualification were performed by Andrew Bassett, president of Aerospace Testing and Pyrometry. The certifications for instrumentation, temperature uniformity surveys, and system accuracy testing were completed through ATP’s new Aerospace Compliance Software (ASC) to AMS2750G.
The Dual Chamber Aerospace Heat Treat (DCAHT ®) system has a certified TUS volume of 24” wide, 16" high, 72" long. In addition to aluminum, the system can be used for PH stainless steel aging, as well as titanium and ferrous alloy processes.  Training was provided to several operators, QC personnel, and two “Trainers” qualified to train other operators.
“As an USAF veteran," commented Richard B. Conway, founder, director, and CTO of DELTA H. "[I]t is a deep honor to do all we possibly can to assure that our Warfighters have the finest heat treating equipment available for defending our nation."
Heat Treating System Delivered to Tinker Airforce Base in Oklahoma Read More »
Twin Heat Treat Furnaces Delivered to RIDGID® TOOLS
Nic Willis
Metallurgist/Heat Treat Manager
Emerson Professional Tools
Source: DELTA H
RIDGID® TOOLS received twin furnace systems from a North American supplier. These systems will heat parts from ambient to 975°F, soak for two hours, cool to 120°F, soak two hours, and then repeat. This will increase the production capacity of the company's current operations.
The furnaces, from DELTA H®, feature a stainless steel interior with low mass ceramic fiber insulation for minimal heat retention, are designed to receive baskets with parts from an Ipsen Titan vacuum furnace, and include a floor guide system to enable precise load placement.
Roseanne Brunello, director of Sales at DELTA H®, has the honor first revealing the company's logo.
Source: DELTA H
"We had a challenge with utilization of our [current] vacuum furnace where a secondary heat treatment might be better accomplished with a convection furnace," explained Nicolas (Nic) Willis, metallurgist/heat treat manager at Emerson Professional Tools, provider of RIDGID® TOOLS. "This would dramatically increase the production capacity of our vacuum furnace and fully [optimize] this process. The extreme and demanding rapid heating and cooling cycles called for a unique convection furnace design."
"I have known Nic for many years, including the Cleveland Chapter of ASM International where we both served as officers – and was honored to nominate him to the Heat Treat Today's 40 Under 40 Class of 2020," comments Rosanne Brunello, director of sales at DELTA H. "The process here was a challenge, but our CTO, Richard Conway, answered the call with an innovative and unique furnace design."
Main Photo Caption: Nicolas (Nic) Willis, Metallurgist/Heat Treat Manager at RIDGID® TOOLS and Richard Conway, Director/Chief Technology Officer at DELTA H®
Twin Heat Treat Furnaces Delivered to RIDGID® TOOLS Read More »
Heat Treat Capabilities “Take Off” at Edwards Air Force Base
Edwards Air Force Base, an historic airfield engaged in experimental aviation, is expanding its heat treat capabilities with two dual chamber furnaces.
DELTA H® delivered the two Defender Series dual chamber aerospace heat treating (DCAHT®) systems. These systems were developed for specific requirements of the armed forces; they meet the pyrometry standards of USAF/NAVAIR Tech Order 1-1A-9 and qualify to SAE AMS2750G.
Defender Series are "deployable" and has stackable chambers that can be configured with 500°F, 1200°F or 2000°F maximum temperatures as either dual or single chamber systems. They serve as "universal heat treating systems" for hangar sheet metal back shops that are tasked with “keeping them flying” – and are “mission essential” equipment. In addition to Edwards AFB, these systems are located at Texas and Kansas Air National Guard facilities as well as Beale AFB in Northern California to date.
Heat Treat Capabilities “Take Off” at Edwards Air Force Base Read More »
Heat Treater of Military and Aerospace Ceramic Parts Expands with Box Furnace
GHH Series Box Furnace for Ceramic Matrix Composites
HTD Size-PR LogoA U.S. manufacturer with a plant in the Midwest received and commissioned a large high-temperature box furnace for processing ceramic matrix parts that will be used in military and aerospace applications.
L&L Special Furnace Company, Inc.'s GHH3350 has an effective work zone of 32” wide x 30” high x 50” deep. The furnace is capable of reaching temperatures up to  3100°F/1700°C under partial atmospheric pressure. A vacuum pump helps to remove oxygen prior to beginning the thermal cycle. The case is sealed for use with inert atmosphere.
Heat Treater of Military and Aerospace Ceramic Parts Expands with Box Furnace Read More »
