ENERGY HEAT TREAT
Improving Accident Tolerance of Nuclear Fuel with Coated Mo-alloy Cladding
BOTW-50w  Source:  Science Direct – Nuclear Engineering and Technology
The goal of this initiative is to demonstrate the feasibility of developing coated Mo-alloy cladding for LWR fuel cladding to enhance the accident tolerance of fuel rods in several loss of coolant accidents. The target is to demonstrate that coated Mo-alloy cladding can meet: (1) performance and reliability requirements for normal operation; (2) licensing safety requirements during power transients; and (3) significantly enhanced tolerance to severe accidents. A measurable goal is to demonstrate that the coated Mo-alloy cladding can survive in a steam environment at 1,200–1,500°C for at least 24 hours.
Read More: Improving Accident Tolerance of Nuclear Fuel with Coated Mo-alloy Cladding by Bo Cheng, Young-Jin Kim, Peter Chou
Improving Accident Tolerance of Nuclear Fuel with Coated Mo-alloy Cladding Read More »
NSK Breaks Ground on New Addition to the Kirihara Building at the Fujisawa Plant
NSK Ltd. (NSK; Headquarters: Tokyo, Japan; President and CEO: Toshihiro Uchiyama) announced that it held a groundbreaking ceremony for the new addition to the Kirihara Building at the Fujisawa Plant on August 2. The Kirihara Building produces environmentally friendly products such as wind power equipment and uses environmentally responsible production methods.
The Fujisawa Plant was certified under the “Select Kanagawa 100” corporate location support initiative, which was launched in April 2016 by Kanagawa Prefecture.
NSK produces high-quality bearings for industrial machinery in the Shinmei and Kirihara areas of Fujisawa City in Kanagawa Prefecture. The addition to the Kirihara Building will include installation of state-of-art production equipment that will be used to expand production of large bearings. Some equipment will also be transferred from the Shinmei area to the new part of the Kirihara Building under the business continuity plan. These steps will help improve productivity and ensure a stable supply of products.
Plant Overview (Kirihara Building, Fujisawa Plant)
Location No.12 Kirihara-machi, Fujisawa City, Kanagawa Prefecture
Construction Commenced February 2008
Addition to be completed Summer 2017
Investment in addition and
equipment enhancement
5 billion yen
Manufactured products Large bearings for wind turbines, rail cars, steelmaking equipment, construction equipment, airplanes, and industrial robots
Floor space Before addition:15,000㎡
After addition:Approx. 30,000㎡
NSK Breaks Ground on New Addition to the Kirihara Building at the Fujisawa Plant Read More »
Broadwind Energy Announces Expansion of Abilene, TX Tower Facility
Broadwind Energy, Inc. (NASDAQ:BWEN) announced its Board of Directors has approved a $4 million expansion of the Company’s Abilene, TX tower facility. The expansion plan will increase tower production capacity in this plant to approximately 200 towers annually, a 30% increase. The Company expects the expansion project to be complete in mid-2017. Broadwind President and CEO Stephanie Kushner stated, “The strong demand for wind energy in the Texas region supports this expansion of our
Abilene facility. We are moving forward aggressively to bring this additional 30% capacity on line which should support incremental annual revenues of approximately $15-20 million, while adding
some important operating flexibility.”
Broadwind Energy Announces Expansion of Abilene, TX Tower Facility Read More »
Age-hardening an Aluminum Underwater Buoy Frame
BOTW-50w  Source:  Metlabheattreat.com
Metlab recently assisted TrimMaster in fabricating an aluminum frame for an underwater buoy that would meet customer specifications. Mike Allard, Sales Manager, explains “We were faced with the prospect of welding the aluminum assembly to put it together, and knew that there would be reduced strength at the weld joint. By changing the welding wire we used, we could take advantage of Metlab’s heat treating process, especially their large furnaces to accommodate these parts, to raise the strength of all weldment components to a T-6 condition, giving us the strength that we needed for the application.”
Read More:  Age-hardening an Aluminum Underwater Buoy Frame
Age-hardening an Aluminum Underwater Buoy Frame Read More »
GE Aviation to Invest 200 Million with 2 New Alabama Factories
BOTW-50w  Source:  AL.com
“The state of Alabama is celebrating another economic win in Huntsville this week after GE Aviation said it will launch two materials factories to service jet engines and land-based gas turbines.”
Read More: GE Aviation to Invest $200 Million, Employ 300 with 2 New Alabama Factories
GE Aviation to Invest 200 Million with 2 New Alabama Factories Read More »
Induction Heat Treating Used in Welding P91 Pipe
BOTW-50w  Source:  The Tube & Pipe Journal – June 2016
“Because precision and stability in temperature control are important when welding P91 pipe, induction heating is well-suited to this application for its control and uniformity of heating.”
Read more:  Advanced GMAW Processes Help in Welding P91 by Dan Hernandez and David Benson
Induction Heat Treating Used in Welding P91 Pipe Read More »
Saudi Aramco Signs to Set Up High-End Forging & Casting Manufacturing Facility
Saudi Aramco has signed a Memorandum of Understanding (MoU) with GE (NYSE: GE) and Cividale SpA of Italy to build the Middle East and North Africa’s first-of-its-kind high-end forging & casting manufacturing facility that will serve the region’s maritime and energy industries.
Marking a joint investment of over US$400 million (SAR1.5 billion), the new facility, to be located in Ras Al-Khair under the Royal Commission of Jubail and Yanbu industrial area, aims to establish a high-value supply chain that boosts exports and economic competitiveness. Set to be operational in 2020, the plant will create 2,000 quality jobs in the Kingdom and catalyze the growth of Saudi small and medium enterprises (SMEs).
The MoU follows a preliminary partnership between Saudi Aramco and Cividale, a leading European producer in the steel and cast iron sector, to conduct feasibility studies for forging and casting manufacturing services in the Kingdom. GE has come on board to extend its expertise and investment in developing the world-class manufacturing plant through a joint venture between the three entities.
The Forging & Casting Manufacturing Facility complements plans by Saudi Aramco to develop several industrial projects in the Kingdom including a maritime project focused on building, maintenance, repair and overhaul (MRO) of offshore platforms, jack-ups, offshore service vessels and commercial tankers.
Saudi Aramco is also working with its partners to develop an onshore rig manufacturing facility for providing new build and MRO services to onshore rigs and systems; an engine manufacturing project for the manufacturing, maintenance and repair of diesel engines, manufacturing and repair of marine pumps; and an Energy Industrial City to accelerate manufacturing industries in the oil and gas sector.
The Forging & Casting Manufacturing Facility will serve all these projects in addition to providing the best-in-class services and technologies to downstream & other industries across the region and global markets. It will also support the ongoing emphasis of the government, under Saudi Vision 2030, to develop the mining sector of the Kingdom by creating a domestic source-market for various raw materials & supplies that go into the production line.
Abdallah I. Al-Saadan, Senior Vice President, Finance, Strategy & Development, Saudi Aramco, said: “The MoU reflects our ambition to create a robust supply chain that builds positive synergies in the oil and gas manufacturing sector. This builds on our deep commitment to support the goals of Saudi Vision 2030 to promote economic and industrial diversification in the Kingdom and boost localized manufacturing.”
Rami Qasem, President & CEO, GE Oil & Gas, Middle East, North Africa & Turkey said: “For the Forging & Casting Manufacturing Facility, we will leverage our already strong expertise in ‘Made in Saudi’ manufacturing. Together with our partners, we will actively engage Saudi SMEs to support the plant’s operations, and train & hire Saudi professionals, adding further value to the economy. By building a domestic forging and casting production unit, Saudi and regional customers can achieve greater operational efficiencies in product procurement, repair and service support.”
Antonio Valduga, President of Cividale, added: “The feasibility assessment study underlines the strong potential for a world-class manufacturing facility for forging and casting services in the Kingdom. Developing a full-fledged facility through the joint partnership will position Saudi Arabia as a technology and services hub for specialized equipment and services.”
The collaboration is a strong example of the public-private partnerships that the government fosters under Saudi Vision 2030 to develop local manufacturing capabilities that add significant value to the economy.
Saudi Aramco Signs to Set Up High-End Forging & Casting Manufacturing Facility Read More »
GE Oil & Gas to Use Robotics and 3D Printing in Talamona
BOTW-50w  Source:  Today’s Energy Solutions
A new nozzle production line is the first completely automated line for GE Oil & Gas, and a new additive manufacturing line will use laser technology to 3D print end burners for gas turbine combustion chambers at the Talamona, Italy plant. These new advanced manufacturing lines establishes this site as a center of excellence for the oil and gas industry.
Read More:  GE Oil & Gas to Use Robotics and 3D Printing in Talamona
GE Oil & Gas to Use Robotics and 3D Printing in Talamona Read More »
Argonne Coating Improves Wind
Despite the rigors of scientific inquiry and the methodical approaches of the world’s most talented researchers, sometimes science has a surprise in store. Such was the case when a group of researchers from the U.S. Department of Energy’s (DOE’s) Argonne National Laboratory and the University of Akron discovered that a particular form of carbon coating not necessarily designed for wind turbines may indeed prove a boon to the wind industry — a serendipitous finding that was recently highlighted in the journal Tribology International
Due to the strenuous environment inherent in wind turbine drivetrains, key components such as actuators, bearings and gears are prone to failure, meaning turbines require regular maintenance that helps drive up the price of wind energy. Prolonging the life of these components could greatly reduce the cost of wind power, the fastest growing source of energy in the world, thereby making it an even more attractive energy source.
These failures are often due to a phenomenon known as micropitting in which the repeated rolling and sliding cycles in the gears and bearings of turbines lead to cracks on the surface of drivetrain components. Further contact only exacerbates the cracking once it begins, chipping away at the metal and increasing the severity of the existing cracks until costly maintenance is necessary or, even worse, the drivetrain fails.
Enter Argonne’s Tribology and Thermal-Mechanics Section and its Surface and Lubrication Interaction, Discovery and Engineering (SLIDE) initiative, which investigates how lubricants and materials interact and develops novel lubrication and coating concepts that reduce friction, and therefore micropitting, prolonging component life across a range of energy technologies.
And sometimes they get a little lucky. Such was the case when SLIDE researchers applied this “diamond-like” (some of the carbon-to-carbon bonding in the coating is similar to that of diamonds) coating to wind turbine components, which was not the intended use.
“We felt that if it was working under other sliding conditions, it might work in wind turbine drivetrains as well,” said SLIDE’s Ali Erdemir, an Argonne Distinguished Fellow. “Initially, our expectations were low, as we thought the coating would wear out due to the high stresses inherent in wind turbines, but that didn’t happen.”
So far the coating, named N3FC, has proven its worth through more than 100 million testing cycles with no appreciable micropitting. Erdemir admits that they don’t know exactly how far it could go, as it has surpassed the time limit of SLIDE’s benchtop micropitting test rig. If the coating performs similarly under real-world conditions, it could mean huge savings in terms of maintenance and prevention of failure in wind turbines nationwide — to the tune of millions of dollars, said Erdemir.
But first, he added, they need to learn exactly why it works.
“We don’t yet understand the exact mechanism,” said Erdemir. “The general belief is that component wear life extension requires a much harder coating, as more hardness reduces wear. But in this case the coating has less hardness than the base steel, so conventional thought doesn’t apply.”
The team is now eager to work with companies and see how N3FC performs in the field. Until then, they will stay busy trying to discover the mechanism behind this surprising scientific development. “We would love to get to the bottom of this and design even better coatings,” said Erdemir.
The team is also testing the coating in sealing applications for compressors. As a low-friction surface coating, it may also prove beneficial in natural gas and hydrogen environments. “It appears to have multiple capabilities in terms of performance,” said Erdemir.
While much of the work was done in Argonne’s tribology laboratory, Raman spectroscopy (which uses monochromatic light, usually from a laser) was performed at the laboratory’s Center for Nanoscale Materials, a DOE Office of Science User Facility.
The research was funded by DOE’s Office of Energy Efficiency & Renewable Energy (Vehicles Technologies Office and Wind and Hydropower Technologies Office).
Team members include Argonne researchers Giovanni Ramirez, Osman Eryilmaz and Aaron Greco, as well as Gary Doll of the University of Akron and Harpal Singh of both Argonne and the University of Akron.
Argonne National Laboratory seeks solutions to pressing national problems in science and technology. The nation’s first national laboratory, Argonne conducts leading-edge basic and applied scientific research in virtually every scientific discipline. Argonne researchers work closely with researchers from hundreds of companies, universities, and federal, state and municipal agencies to help them solve their specific problems, advance America’s scientific leadership and prepare the nation for a better future. With employees from more than 60 nations, Argonne is managed by UChicago Argonne, LLC for the U.S. Department of Energy’s Office of Science.
Argonne Coating Improves Wind Read More »
