HEAT TREATING EQUIPMENT
Largest Commercial Vacuum Furnace Nearing Completion
Solar Atmospheres of Western Pennsylvania and Solar Manufacturing, Inc. have been very busy these days building the largest vacuum furnace anywhere in the world.  The working hot zone of this high vacuum (three 35 inch Varian diffusion pumps) furnace is 80 inch diameter X 48 feet long with a maximum operating temperature of 2400°F.  Thirty five points of temperature will be surveyed to within +/- 10°F per the stringent AMS 2750E specification. The robust US Patented dual load car design will have the capacity to transfer up to 150,000 pounds of material in and out of the furnace.  For dimensionally critical, near net shaped jobs, the dual load car design will also have the capability to maintain the critical support needed at elevated temperatures to keep parts flat to within .030 inches.
All of the major components have been delivered and installed.  The gas and water systems are in place.  The remaining installation of all the electrical components and wiring will occur over the next several weeks.  This multi-million dollar project is expected to be completed in June with the commissioning of the furnace into production in July of 2016.  This unique piece of equipment will not only open up new production opportunities within the North American vacuum heat treating markets, but also internationally.
Largest Commercial Vacuum Furnace Nearing Completion Read More »
Heat Treat Expansion Complete at McGinnis Rolled Rings
 McInnes Rolled Rings has completed an $8 million, 25,000-square-foot expansion to its current manufacturing facility.  The addition expands its present heat treat size capabilities by providing the ability to quench and temper forgings up to 144 inches in diameter. With separate high agitation water and polymer quench tanks, this new state-of-the-art bay will significantly expand the daily tonnage capacity to ensure the fastest delivery times available in the industry.
McInnes contracted with Can-Eng Furnaces Intl. Ltd. to design and install the most advanced technology to process large diameter product. The furnace & quench tank designs are augmented by a customized material handling system by Dango & Dienthal Hollerbach GmbH capable of processing loads up to 25 tons.  The system’s fast transfer from furnace to quench tank provides optimal and repeatable process controls.
“This new bay nearly doubles our quenched and tempered offerings to the power transmission industry and adds the ability to solution anneal large diameter stainless steel rings. Also, the addition of water quenching improves our ability to meet the high property demands of the custom flange markets,” said Shawn O’Brien, VP Sales & Marketing.
The expanded heat treat operation will officially begin service on March 1, 2016.
Heat Treat Expansion Complete at McGinnis Rolled Rings Read More »
Industrial Batch Ovens to Automotive Supplier
Wisconsin Oven Corporation announced the shipment of two (2) direct gas fired batch ovens to a leading automotive supplier for tempering tire molds. The tempering process of the molds results in a longer mold life. This industrial oven was designed with the load capacity of 6,000 pounds and provides easy access of loading and unloading of tire molds by fork truck.
Each tempering batch oven has a maximum operating temperature rating of 800°F, work chamber dimensions of 5’0”W x 5’0”L x 8’0”H, and a 6” reinforced insulated floor. The recirculation system utilizes combination airflow which provides both horizontal and vertical upward airflow to maximize heating rates and temperature uniformity of the product. The batch oven is equipped with a 10,850 CFM @ 15 HP belt-driven blower. Supply air is delivered through fully adjustable boxed ducts and side-mounted along the length on each side of the work chambers. The heating system features an industrial air heat burner rated at 850,000 BTU per hour.
“Designing a solution for our customers that improves their production process is always a top priority. Improved work flow and ease of loading/unloading was a focus for this project to increase production efficiencies.” Tom Trueman, Senior Application Engineer, Wisconsin Oven Corporation
Unique features of these tempering batch ovens include:
  • Load capacity to 6,000 pounds
  • 575-volt electrical capacity
  • Operating temperatures to 800° F
  • 3/16” plate construction for durability
  • High volume of air flow; 10,850 CFM
  • Motorized dampers for quick cool down
  • Natural gas fired
  • Programmable controller
  • Meets all Canadian requirements – CUL, CSA TSSA
  • Field inspection provided by a trained factory technician
  • Temperature triggered door locks with safety pull cord
Industrial Batch Ovens to Automotive Supplier Read More »
temperature: 1300°C (2400°F)
Universal High Pressure Quench Delivers Wide Range of Process Capabilities to Slovenia Commercial Heat Treater, MIHEU Read More »
Aluminum Immersion Holding Furnace to Large Automotive Die Caster
Lindberg/MPH announced the shipment of an electric immersion aluminum holding furnace to a large automotive die caster. The equipment provided includes three electric immersion aluminum holding furnaces used to keep aluminum at die casting temperature.
These aluminum holding furnaces utilize Lindberg/MPH patented board lining and high efficiency immersion tubes/heaters. A manually operated winch crane operates the center cover for cleaning.
Repeat business based on past performance is a testament to the quality and durability of Lindberg/MPH equipment. We work closely with our customers to provide the best possible solution to their application needs and are pleased to be their chosen vendor.”  Andrew Paul, Sales Engineer
Unique features of these aluminum holding furnaces includes:
• Efficient electric immersion heating.
• Excellent temperature control and fast recovery.
• Lindberg/MPH patented board lining.
• Longer lining life.
• Manually operated winch crane cover lift
Aluminum Immersion Holding Furnace to Large Automotive Die Caster Read More »
Heat Treating 101
[Best of the Web] Source: Energy Insights
Looking for a solid primer on heat treatment that you can share with your new heat treat employees, family members, open houses, or at a college job fairs? Take a look at this excellent resource from South Carolina Electric & Gas (SCE&G).
Key Points
  • Heat treating is a widely used industrial process to optimize the mechanical properties of metal.
  • Metal is heated to a set temperature and then cooled according to a prescribed schedule.
  • Heat treating processes vary according to equipment type, energy source, temperature profile and environment.
Read more.
Heat Treating 101 Read More »
