MANUFACTURING HEAT TREAT
University Purchases 1500°C Box Furnace
A 1500°C box furnace was recently shipped to a university, designed for testing, research and development, and laboratory applications and with capability for ease of mobility within the facility.
The heavy-duty furnace, supplied by Lindberg/MPH, is suited for multiple applications such as annealing, ashing, carbon firing, ceramic firing, hardening, sintering, solution treating, and stress relieving, and has locking casters to allow it to be moved to different locations.
University Purchases 1500°C Box Furnace Read More »
Kazakhstan Steel Producer Orders 290-Ton Ladle Furnace
Steelmaker ArcelorMittal recently ordered a 290-ton ladle furnace to control chemical composition and temperature of liquid steel and slag for its integrated steel plant in Temirtau, Kazakhstan.
The furnace will be supplied by SMS Group, and commissioning will include the engineering, mechanical and electrical equipment, and supervision of erection, and commissioning of the new ladle furnace, gas cleaning plant, additives handling system and water treatment plant. ArcelorMittal’s Kazakhstan facility has an annual capacity of 4 million tons of crude steel and produces hot and cold rolled steel, tin plates, galvanized steel and polymer-coated coils, welded pipes, coke, and chemical by-products. plant
Commissioning is scheduled for the second quarter of 2018.
Kazakhstan Steel Producer Orders 290-Ton Ladle Furnace Read More »
Firearms Parts Manufacturer Utilizes Precision Heat Treating for .308 Match Bolt Assembly
A U.S.-based aerospace and firearms parts company, which has been manufacturing bolt carrier groups for the AR-15 and M16 rifles since 1991, offers precision manufacturing of the .223/5.56 bolts and bolt carriers to buyers of a high quality .308 bolt carrier assembly for the AR-10 rifle.
The .308 bolt, made by Young Manufacturing from SAE 9310 steel, is precision ground in three critical areas after heat treating to military specifications (mil-spec). This removes the distortion that occurs during heat treat and provides the most accurate fit possible on the center support ring and the bolt tail. Grinding the back of the lugs true to the bolt face produces a bolt that locks up true and square to the center of the bore. Bolts are magnetic particle inspected to detect any stress fractures that might occur during the heat treat process.
.308 carriers follow the same strict process as the .223 bolt assembly components, starting with 8620 steel heat treated to mil-spec, followed by precision grinding the inside bores and outside diameter to ensure they run concentric to each other and again remove the distortion from heat treat. The manufacturer adds additional surface or contact area near the front of the carrier for a tighter fit and support when the carrier is in the battery.
Firearms Parts Manufacturer Utilizes Precision Heat Treating for .308 Match Bolt Assembly Read More »
Fastener Manufacturer Expands Heat Treatment in Response to Growth
Global industrial fastener manufacturer Trifast PLC has announced the expansion of its heat treatment capabilities as part of the company’s response to positive gains in the first half of 2017.
“This substantial expansion allows us to access further the growth market sectors within Europe,” stated the company in a recent release, pointing to the installation of a £1 million new heat treatment plant at their TR Vic location in Italy. In addition, more complex value-add components will be supported by new automated inspection and packing machines at the production facility.
Fastener Manufacturer Expands Heat Treatment in Response to Growth Read More »
New Isofrax® 1400 Fiber Launched for Higher Temp Processes
Enhanced fiberization techniques combined with proprietary processing technology is behind the manufacturing of a recently unveiled low bio-persistent (LBP) fiber that provides high-temperature performance up to 1400°C, higher than other LBP fibers currently available in the market.
Unifrax, a leading global supplier of specialty products used in industrial, filtration, automotive and fire protection applications, and headquartered in Tonawanda, New York, recently launched Isofrax® 1400, a low bio-persistent (LBP) fiber to provide customers with improved thermal and physical characteristics. The high-temperature LBP technology was first introduced by Unifrax 18 years ago and offers thermal conductivity, thermal shock resistance, and low h, at storage, as well as ease of cutting and fabrication in the worldwide ferrous/non-ferrous metals, chemical processing, and ceramics industries.
In addition to higher temperature resistance, Isofrax 1400 fiber has high solubility in simulated body fluids and hence carries no hazard classification, meeting stringent European regulatory requirements. Isofrax® 1400 fiber are exonerated from classification as hazardous (tested according to Note Q Regulation (EC) No. 1272/2008).
“The enhanced Isofrax 1400 fiber exhibits a higher melting point and reduced shrinkage at high temperatures demonstrating superior thermal performance,” said Jayne Webb, Unifrax Product Manager, USA.
New Isofrax® 1400 Fiber Launched for Higher Temp Processes Read More »
More Accessible Design-to-Launch Services Unveiled with IT, AM Technologies Partnership
Sudip Singh, Global Head, Engineering Service at Infosys Ltd
An end-to-end product development service using metal additive manufacturing (AM) technology was announced last month by two leading companies partnering to help customers accelerate their deployment of AM, also known as 3D printing, for volume production of end-use metal components.
Engineering and IT services company Infosys will apply its engineering processes and design for AM knowledge to manage product development projects from concept through to launch. Renishaw, a leader in metrology and additive manufacturing technologies, will support Infosys through its global network of Additive Manufacturing Solutions Centres, which provide access to Renishaw’s metal AM technology, which is used in series production of high-performance parts for aerospace, medical, automotive, oil and gas, mould and die, and consumer products.
“Additive manufacturing enables us to design and make innovative products with spectacular gains in performance and efficiency,” said Sudip Singh, Global Head, Engineering Service at Infosys Ltd. “Infosys has developed a rich knowledge base of AM design best practices, coupled with powerful design tools to analyze and optimise product designs, so that we can take full advantage of the flexibility that AM offers.”
Marc Saunders, Director – Global Solutions Centres at Renishaw
“Whilst additive manufacturing can create complex geometries in a single process step, some level of finishing is generally required to produce functional products,” said Marc Saunders, Director – Global Solutions Centres at Renishaw. “Renishaw’s knowledge of metrology, machining and finishing processes can help customers to develop an integrated manufacturing solution for their innovative new product.”
The two companies are currently working together on projects for customers located in Europe, Asia, and North America.
More Accessible Design-to-Launch Services Unveiled with IT, AM Technologies Partnership Read More »
Sophisticated All-Metal Hot Zone Delivered
A uniquely engineered, high-temperature refractory metal hot zone has been delivered by the furnace division of an international supplier of refractory technology metals and technical ceramics to one of its furnace customers. The engineering team of the German manufacturing firm H.C. Starck fabricated a 1600°C hot zone designed to operate in a vacuum, with certain inert gases or in a reducing atmosphere. By simulating the temperature of each layer, it was ensured that the proper materials were applied throughout the hot zone.
 ”H.C. Starck is excited to deliver the first of its kind refractory metal hot zone,” said Andreas Mader, President and CEO of the Fabricated Products Division. Supplying growth industrial sectors such as the electronics sector, the chemical industry, medical technology, aviation and aerospace, energy and environmental technology, and machine and tool building from its own production locations in Europe, America, and Asia, the company employs 2,500 people in the USA, Canada, the UK, Germany, China, Japan and Thailand.
Sophisticated All-Metal Hot Zone Delivered Read More »
U.S.-Produced Aluminum Cladding Adorns Façade of South African Mall
Source: AlCircle
To achieve a distinctive look that can be seen from a distance, a shopping mall in the economically developing township of Waterfall City, located between Johannesburg and Pretoria in South Africa, has turned to a U.S. manufacturer of flat-rolled aluminum products to cover the cladding of its parking garage with a façade made of sheets of aluminum measuring 1,437 x 3,880 mm (4.7 x 12.7 ft.), each treated with weather-resistant coating and classified for fire protection. The unique wave-look of the façade was achieved by laying aluminum plates horizontally.
Read more: “Novelis Does Cladding for South Africa Mall with Its ff2 Pre-Painted Aluminum Facade”
U.S.-Produced Aluminum Cladding Adorns Façade of South African Mall Read More »
Tool and Die Failure, Heat Treatment Causes and Corrections
George Vander Voort has a background in physical, process and mechanical metallurgy and has been performing metallographic studies for nearly 50 years. He is a long-time member of ASTM Committee E-4 on metallography and has published extensively in metallography and failure analysis. He regularly teaches MEI courses for ASM International and is now doing webinars. He is a consultant for Struers Inc. and will be teaching courses soon for them.  His website, www.georgevandervoort.com, not only details his consulting services but also houses over one hundred articles, studies, or instructional graphics on topics related to physical, process and mechanical metallurgy. The following is an overview and an excerpt of failure factors from “Identifying the Cause of Tool and Die Failure”, published in 2016. There are particular elements to this study which relate to the heat treat industry.
Steels used for tools and dies differ from most other steels in several aspects. First, they are used in the manufacture of other products by a variety of forming processes. Second, tools and dies are generally used at a higher hardness than most other steel products; 58 to 68 Rockwell C is a typical range. Dies for plastic molding or hot working are usually used at a lower hardness, typically from 30 to 55 Rockwell C.
These high hardness values are required to resist anticipated service stresses and to provide wear resistance. However, the steels must also be tough enough to accommodate service stresses and strains without cracking. Premature failure caused by cracking must be avoided, or at least minimized, to maintain minimum manufacturing costs. Unexpected tool and die failure can shut down a manufacturing line and disrupt production scheduling. Tools and dies must also be produced with the proper size and shape after hardening so that excessive finishing work is not required. Heat-treatment distortion must be controlled, and surface chemistries must not be altered. Because of the careful balance that must be maintained in heat treatment, control of the heat-treatment process is one of the most critical steps in producing successful tools and dies. In addition to controlling the heat-treatment process, tool and die design and steel selection are integral factors in achieving tool and die integrity.
The following list is excerpted and abridged to highlight phases or processes related to heat-treat. The explanation behind each factor is available at the original post.
A number of factors can be responsible for tool and die failures. They include:
1. Mechanical design. The design must be compatible with the steel grade selected, the procedures required to manufacture the tool or die, and the use of the tool or die. . . .
The importance of good design cannot be overemphasized. Poor design can cause or promote heat-treatment failures before any service life is obtained, or it may reduce service life dramatically.
In designing a tool or die, a host of factors must be considered. In practice, separating the design stage from grade selection is difficult because the two steps are interdependent. The choice of a certain grade of steel, such as one that must be brine- or water-quenched, will have a substantial bearing on all aspects of design and manufacture. In general, any steel grade that requires liquid quenching demands very conservative, careful design.
Air-hardening grades tolerate some design and manufacturing considerations that could never be endured by a liquid quenching grade. The design must also be compatible with the equipment available–heat-treatment furnaces and surface-finishing devices, for example. . . .
2. Grade selection. The grade of steel selected must be compatible with the design chosen, the manufacturing processes used to produce the tool or die, and the intended service conditions and desired life. . . .
3. Steel quality. The material must be macrostructurally sound, free of harmful inclusions to the degree required for the application, and free of harmful surface defects.
Despite the care taken in the manufacture and inspection of tool steels, faulty materials occasionally cause tool and die failures. However, such problems are rare. The most common of these defects are voids from secondary pipe, hydrogen flakes, surface cracks, porosity or microvoids, cooling cracks, segregation, and poor carbide distributions. Improper control of annealing may also produce non-uniform carbide distribution or carbide networks that may influence heat-treatment uniformity, lower ductility, or impair machinability.
4. Machining processes. The machining processes used to produce the tool or die must not alter the surface microstructure or surface finish and must not produce excessive residual stresses that will promote heat-treatment problems or service failures.
Machining problems are a common cause of tool and die failures. It is generally best to avoid machining directly to the finish size unless pre-hardened die steels are used. Obtaining perfect control of surface chemistry and size during heat treatment is difficult. Thus, some final grinding is usually needed after heat treatment. The presence of decarburization is generally quite detrimental. Also, because stresses are high in heat treatment and in service, rough machining marks must be avoided. Identification stamp marks are another common source of failures in heat treatment and in service; they should be avoided.
5. Heat-treatment operation. Heat treatment of tools and dies must produce the desired microstructure, hardness, toughness, and hardness at the surface and in the interior.
Improper heat-treatment procedures are the single largest source of failures during heat treatment, in subsequent processing steps, or in service. Each tool steel grade has a recommended austenitizing temperature range, which is generally rather narrow; a recommended quench medium; and recommended tempering temperatures and times for optimum properties. Some grades are more forgiving than others.
6. Grinding and finishing operations. Grinding and finishing operations must not impair the surface integrity of the component.
7. Tool and die setup. Alignment of tools and dies must be precise to prevent irregular, excessive stresses that will accelerate wear or cause cracking.
8. Tool and die operation.
Read the full study and report, including images of tool steel failure examples, at “Identifying the Cause of Tool and Die Failure”.
Tool and Die Failure, Heat Treatment Causes and Corrections Read More »
Hoa Phat Orders 4 Blast Furnaces to Increase Production at Dung Quat Complex
Vietnamese steel producer Hoa Phat Steel has awarded a contract to an Italian steel production technology specialist for the design, supply, and supervision of four greenfield blast furnaces.
The project is part of the new Dung Quat iron and steel making complex committed to by Hoa Phat, which currently operates a 2 million metric ton per year (mtpy) iron and steel making plant in Hai Duong. The scope of the project also includes the hot blast mains, bustle mains, tuyere assemblies, level 2 automation systems and pulverized coal injection systems. The new plant will add 4 mtpy to Hoa Phat’s annual steelmaking capacity.
The four blast furnaces will have a 1080 m³ working volume and are designed for an annual production of 1 million tons of hot metal each. The furnaces will be supplied by Danieli Corus and equipped with the company’s high conductivity cooling and lining design based on copper plate coolers combined with graphite and silicon carbide refractories. The four furnaces will be completed and commissioned in sequence, with the fourth being scheduled for delivering the first hot metal in 2019.
Hoa Phat Orders 4 Blast Furnaces to Increase Production at Dung Quat Complex Read More »
