MEDICAL HEAT TREAT
Vapor Degreasing Re-Gaining Wider Heat Treat Acceptance
  Source:  Today’s Medical Developments
Vapor degreasing has historically played a critical part in the heat treating process. When oils get on the parts, the parts often have to be cleaned. In the past, vapor degreasing was a very popular way of cleaning the parts, but it became an environmental issue because the solvents used were problematic. Other cleaning solutions were adopted but typically were not as effective as vapor degreasing.  Now vapor degreasing is making a comeback with less problematic solvents.  This article, although not dealing specifically with heat treating, will have a significant impact on heat treaters.
Read more:  Vapor Degreasing Returns for Medical Device Cleaning edited by Eric Brothers
Vapor Degreasing Re-Gaining Wider Heat Treat Acceptance Read More »
Heat Treating of Jaw Fixation Plates Provides Superelasticity
  Source:  Bioengineering
Process parameters and post-processing heat treatment techniques have been developed to produce both shape memory and superelastic NiTi using additive manufacturing. By introducing engineered porosity, the stiffness of NiTi can be tuned to the level closely matching cortical bone. Using additively manufactured porous superelastic NiTi, we have proposed the use of patient-specific, stiffness-matched fixation hardware, for mandible skeletal reconstructive surgery.
Heat Treating of Jaw Fixation Plates Provides Superelasticity Read More »
Medical Device Market’s Custom Solution – Magnesium
Magnesium alloys, commonly used in aerospace, performance cars, and nuclear industries, are now being used in medical devices.  In fact, some magnesium alloys are replacing titanium and stainless steel in bone repair applications.
Read more: Medical Device Market’s Custom Solution by Paul Lyon and edited by Elizabeth Engler Modic
Medical Device Market’s Custom Solution – Magnesium Read More »
Medical Manufacturer Chooses Vacuum Furnace System
A vacuum heat-treating system with 2-bar gas quenching was shipped to Costa Rica and will be used to manufacture surgical components. The TITAN® H2, manufactured by Ipsen, helps companies accelerate the pace of innovation while satisfying the strict legal requirements of the medical industry.
The standardized vacuum furnace features an 18″ x 24″ x 18″ (455 mm x 610 mm x 455 mm) all-metal hot zone with a 1,000-pound (450 kg) load capacity. It is capable of operating at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C) with ±10 °F (±6 °C) temperature uniformity. Equipped with the PdMetrics® platform for predictive maintenance – which securely connects to a network of integrated sensors on the furnace to gather and analyze data, run algorithms and provide real-time diagnostics – the furnace provides sophisticated monitoring of critical systems and key parameters that improve the health and integrity of the equipment. The company also received a gas backfill reservoir, a loader with a 2,000-pound (907 kg) load capacity and a complete air-cooled, closed-loop water system.
Medical Manufacturer Chooses Vacuum Furnace System Read More »
Medical Manufacturer Chooses Vacuum Heat Treating System
Ipsen recently shipped a TITAN® H2 vacuum heat-treating system with 2-bar gas quenching to Costa Rica. There it will be used to manufacture surgical components. With its compact dimensions and superior quality, the TITAN helps companies accelerate the pace of innovation while satisfying the strict legal requirements of the Medical industry. This shipment included more than just a furnace, though. The company also utilized Ipsen’s full-scale support offerings with Ipsen U training, a spare parts kit and installation/start-up support to advance their equipment and maximize uptime.
This standardized vacuum furnace features an 18” x 24” x 18” (455 mm x 610 mm x 455 mm) all-metal hot zone with a 1,000-pound (450 kg) load capacity. It is capable of operating at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C) with ±10 °F (±6 °C) temperature uniformity. Equipped with the PdMetrics® platform for predictive maintenance – which securely connects to a network of integrated sensors on the furnace to gather and analyze data, run algorithms and provide real-time diagnostics – the TITAN furnace provides sophisticated monitoring of critical systems and key parameters that improve the health and integrity of the equipment. They also received a gas backfill reservoir, a loader with a 2,000-pound (907 kg) load capacity and a complete air-cooled, closed-loop water system.
Medical Manufacturer Chooses Vacuum Heat Treating System Read More »
Titanium Used on Medical Implants
Source:  Engineering 360
Medical Heat Treating, Engineering 360
Blood, plasma and water droplets beading on a liquid-repellent surface.
Source: Colorado State University
A titanium surface that’s extremely repellent to blood could form the basis for surgical implants which reduce the risk of rejection by the body.
Read more: Implant Material Repels Blood by the Engineering 360 News Desk
Titanium Used on Medical Implants Read More »
Enhanced Properties for Bright 17-7 PH Stainless Steel
Already extensively used in aerospace, semiaustenitic stainless steel 17-7 PH is finding new applications in the medical industry. The material is most often used in sheet and strip form, with springs, clips, and bellows being widely produced. The high alloy content of 17-7 provides excellent corrosion resistance, an attractive attribute to the medical industry.
Read more to find out how this material behaves after annealing at 1,950°F…….
Enhanced Properties for Bright 17-7 PH Stainless Steel Read More »
Titanium + Gold = New Gold Standard for Artificial Joints
BOTW-50w  Source:  Rice University News and Media
“Titanium is the leading material for artificial knee and hip joints because it’s strong, wear-resistant, and nontoxic, but an unexpected discovery by Rice University physicists shows that the gold standard for artificial joints can be improved with the addition of some actual gold.”
Read More:  Titanium + Gold = New Gold Standard for Artificial Joints by Jade Boyd and Co-Authors Pulickel Ajayan, Sruthi Radhakrishnan and Chandra Sekhar Tiwary, all of Rice; Tiglet Besara, Yan Xin, Ke Han and Theo Siegrist, all of Florida State; Fevzi Ozaydin and Hong Liang, both of Texas A&M; and Sendurai Mani of MD Anderson
Titanium + Gold = New Gold Standard for Artificial Joints Read More »
