What's the future of ferritic nitrocarburizing and how does it compare to other hardening processes? When it comes to metal hardening, there are many variations on central processes, including recent innovations in how to apply hardening processes.
This Technical Tuesday brings you a quick overview of how hardness technologies differ, specifically nitriding and FNC, and how certain heat treaters have developed these specific hardness technologies.
Understanding the Various Hardening Processes
If you want to know the future, the best you can do is understand the past and present. Let’s begin with looking at the most common hardening processing methods. Here are a few excerpts from “Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes” by Mike Harrison, engineering manager of Industrial Furnace Systems Division at Gasbarre Thermal Processing Systems:
Carburizing: “Gas carburizing is a process where carbon is added to the material’s surface. The process is typically performed between 1550-1750°F, with carburizing times commonly between 2-8 hours [this spec is disputed, and times may run up to 24 hours]; of course, these values can vary depending on the material, process, and equipment. The most common atmosphere used for atmosphere gas carburizing is endothermic gas with additions of either natural gas or propane to increase the carbon potential of the furnace atmosphere.”
Nitriding: “Gas nitriding is a process where nitrogen is added to the material surface. The process is typically performed between 925-1050°F; cycle times can be quite long as the diffusion of the nitrogen is slow at these temperatures, with nitriding times typically ranging from 16 – 96 hours or more depending on the material and case depth required. Nitriding can be performed in either a single or two-stage process and has the potential to produce two types of case, the first being a nitrogen-rich compound layer (or “white layer”) at the surface that is extremely hard and wear-resistant but also very brittle.”
Carbonitriding: “Despite its name, carbonitriding is more closely related to carburizing than it is to nitriding. Carbonitriding is a process where both carbon and nitrogen are added to the material surface. This process is typically performed in a range of 1450-1600°F [this spec is disputed, and temperatures may go up to 1650°F] and generally produces a shallower case depth than carburizing.”
Ferritic Nitrocarburizing (FNC): “In the author’s opinion, just like with carbonitriding, ferritic nitrocarburizing (FNC) is named incorrectly as it is more closely related to nitriding than it is with carburizing. FNC is a process that is still mostly nitrogen-based but with a slight carbon addition as well. The added carbon helps promote compound layer formation, particularly in plain carbon and low alloy steels that do not contain significant nitride-forming alloys. This process is typically performed in a range of 1025-1125°F with cycle times much shorter than nitriding, typically 1-4 hours.”
Low Pressure Carburizing (LPC): “Low-pressure carburizing (LPC), or vacuum carburizing, is a variation of carburizing performed in a vacuum furnace. Instead of the atmospheres mentioned previously, a partial pressure of hydrocarbon gas (such as acetylene or propane) is used that directly dissociates at the part surface to provide carbon for diffusion. After LPC, the workload is transferred to a quench system that could use oil or high-pressure gas, typically nitrogen.”
Nitriding
Gas nitriding, a process over 100 years old, is a hardening process that involves diffusing nitrogen into the surface of steel to create a hard, wear-resistant case. Among many benefits, the part will have enhanced fatigue properties, anti-galling properties under load, and a resistance to softening at elevated temperature. This makes it an excellent choice for the aerospace industry.
There is some recent history regarding problems related to the “white layer”. In a typical microstructure, the “white layer” is a nitrogen-rich surface layer and the diffusion layer exists beneath it.1 It is essential that the surface layer be controlled to avoid an overly brittle part. Mark Hemsath the vice president of Sales – Americas for Nitrex Heat Treating Services, elaborated on this in a Heat TreatRadioepisode:
"Doug Glenn: I assume, with all the modern day technology and whatnot, we're able to control that white layer and/or depth of nitriding layer through your process controls and things of that sort."
"Mark Hemsath: Yes. Nitriding has been around a long time, but one of the problems that they had was controlling the white layer. Because they basically would just subject it to ammonia and you kind of got what you got. Then they learned that if you diluted it, you could control it. That's with gas nitriding. Then plasma nitriding came around and plasma nitriding is a low nitriding potential process. What that means is it does not tend to want to create white layer as much. It's much easier to control when the process itself is not prone to creating a lot of white layer, unlike gas. Now, in the last 10 – 15 years, people have gotten really good at controlling ammonia concentrations. They've really learned to understand that."
"ZeroFlow nitriding is ammonia-based gas nitriding," commented Dr.Maciej Korecki, PhD Eng., vice president of the Vacuum Furnace Segment at SECO/WARWICK Group. "It is distinguished by the fact that the nitrogen potential is controlled by introducing the right portion of ammonia at the right time and only ammonia, instead of a continuous flow of a mixture of ammonia and diluent gas."
"Consequently, the ZeroFlow method uses the minimum amount of ammonia needed to achieve the required nitrogen potential and replenish the nitrogen in the atmosphere, taking into account the situation where no ammonia is supplied to the furnace at all, no flow, hence the suggestive name of the solution," he continued. "Using ammonia alone in the nitriding process, we are dealing with a stoichiometric reaction (as opposed to some traditional methods), that is, one that is uniquely defined and predictable based on the monitoring of a single component of the atmosphere. Therefore, the ZeroFlow process controls very precisely through the analyzer only one gas, obtaining an improvement in the quality and repeatability of the results compared to various traditional methods."
According to Dr. Korecki, the process is about going back to the basics of nitriding: "The inventor of the method is Prof. Leszek Maldzinski of the Poznan University of Technology, who developed the theoretical basis and confirmed it with research. Then, more than 10 years ago, a partnership between SECO/WARWICK and the Poznan University of Technology initiated a project to develop and build the first industrial furnace designed to perform the ZeroFlow nitriding processes. The furnace was launched at SECO/WARWICK's research and development department (SECO/LAB®), where the method has been implemented and validated on dozens of industrial-scale processes."
This nitrogen-based process can produce a deeper compound layer than nitriding, which is great for industrial machinery applications where this deep layer is needed for increased wear resistance and the critical strengthening of a deep case depth is not essential.
FNC has gone through a technical evolution with different heat treaters in the industry developing their own unique applications with method in mind. We'll look at two recent examples: AHT's Super Ultra Ox and Bodycote's Corr-I-Dur.
According to experts at Advanced Heat Treat Corp. (AHT), Edward Rolinski (Dr. "Glow"), Jeff Machcinski, Vasko Popovski and Mikel Woods, "Thermochemical surface engineering of ferrous alloys has become a very important part of manufacturing. Specifically, nitriding and nitrocarburizing (FNC) processes are used since their low temperature allows for treatment of finished components. They are applied to enhance the tribological and corrosion properties of component surfaces.2 In many situations, nitriding replaces carburizing even if the nitrided layer is not as thick.3 A post-oxidizing step, applied at the end of FNC, leads to significant enhancement of corrosion properties by formation of a magnetite layer (Fe3O4).
"AHT’s newly developed process, UltraOx® Hyper, results in superior wear and corrosion resistance and allows for good control of the parts’ blackness. The latter is very important when the treatment is used for firearms. While the parts’ corrosion resistance improves with nitriding alone, the additional steps in UltraOx® Hyper significantly extend corrosion resistance. AHT is committed to achieving its customers’ desired metallurgical and cosmetic results through R&D and investing in state-of-the-art equipment. These innovations allow for flexibility in these areas."
From Bodycote, they say that their proprietary Bodycote thermochemical treatment “Corr-I-Dur® is a combination of various low temperature thermochemical process steps, mainly gaseous nitrocarburising and oxidising.”
They explain, "In the process, a boundary layer consisting of three zones is produced. The diffusion layer forms the transition to the substrate and consists of interstitially dissolved nitrogen and nitride precipitations which increase the hardness and the fatigue strength of the component. Towards the surface it is followed by the compound layer, a carbonitride mainly of the hexagonal epsilon phase. The Fe3O4 iron oxide (magnetite) in the outer zone takes the effect of a passive layer comparable to the chromium-oxides on corrosion resistant steels.
"Due to the less metallic character of oxide and compound layer and the high hardness abrasion, adhesion and seizing wear can be distinctly reduced. Corr-I-Dur® has very little effect on distortion and dimensional changes of components compared to higher temperature case hardening processes."
How to Implement?
We’ve seen a lot of development in way of nitriding and ferritic nitrocarburizing (FNC), but for many heat treaters, you inherit specific processes and traditions of accomplishing heat treatment and do not have the chance to understand how to implement each process. Read the full 21 point comparative resource at FNC vs. Nitriding
The more informed you are, the better decisions you can make. For example, knowing these recent developments in metal treating and hardening is sure to help you decide whether to shift directions in how you company process parts for electric vehicles, or if you are ready to expand your offerings for your aerospace clients. It is clear that each of these processes have a future all-their-own. It’s up to you to decide whether that future should be yours, too.
For more information on the basics of hardness, listen to the what, why, and how of hardening with Mark Hemsath, an expert on metal hardness and vice president of Sales – Americas for Nitrex Heat Treating Services, on this Heat TreatRadio episode with Doug Glenn, publisher of Heat TreatToday. You can also review the resources below that were referenced in today’s article.
2 “Thermochemical Surface Engineering of Steels”, Woodhead Publishing Series in Metals and Surface Engineering: Number 62, Ed. Eric J. Mittemeijer and Marcel A. J. Somers, Elsevier, 2015, pp.1-769.
3 J. Senatorski, et. al, Tribology of Nitrided and Nitrocarburized Steels”, ASM Handbook Vol 18, Friction, Lubrication and Wear Technology, ed. G. Totten ASM International, 2017, pp. 638-652.
Senatorski, J. Tacikowski, E. Rolinski and S. Lampman, “Tribology of Nitrided and Nitrocarburized Steels”, ASM Handbook Vol 18, Friction, Lubrication and Wear Technology, ed. G. Totten ASM International, 2017.
Your parts need heat treated to herculean surface hardness but with a soft, ductile core. That is to say, you are looking at case hardening processes, most likely one of these: gas carburizing, low-pressure carburizing, carbonitriding, gas nitriding, and ferritic nitrocarburizing.
Mike Harrison at Gasbarre Thermal Processing Systems brings us a Technical Tuesday article about what case hardening is and how five of the most common processes vary by (1) comparing the specific guidelines for each temp and time, (2) identifying equipment used to perform each process, and (3) providing a chart (at the end!) to understand different process considerations.
Atmosphere Gas Carburizing
Low-Pressure Carburizing
Carbonitriding
Diffusion Only Processes
Gas Nitriding
Considerations
How well do you know hardness processing? Can you draw the line where nitriding and ferritic nitrocarburizing (FNC) differ? In this Technical Tuesday feature, skim this straight forward data that has been assembled from information provided by four heat treat experts: Jason Orosz and Mark Hemsath at Nitrex, Thomas Wingens at WINGENS LLC – International Industry Consultancy, and Dan Herring, The Heat Treat Doctor at The HERRING GROUP, Inc.
Let us know what you think! What is the next comparison you'd like to see? What facts were you surprised by? Email Heat TreatDaily editor Bethany Leone at bethany@heattreattoday.com.
Nitriding
Descriptor
480º-590C (896º-1094ºF) typical
Temperature Range
565º-590ºC (1049ºF-1094ºF) typical
Wrought and powder metallurgy materials including alloy steels (e.g., 4140), stainless steel (e.g., 304L, 420), tool steels (e.g., H11, H13) and special nitriding steels (e.g,, Nitralloy 135M, Nitralloy EZ) are typical examples. Many other steel grades are possible.
Materials Commonly Processed
Plain and medium carbon steels (e.g., 1015, 1018, 1045), alloy steels (e.g., 4140, 4340) and tool steels (e.g., H11, H13) are typical examples. Many other steels grades are possible.
Wear (as in abrasion resistance), bending, torsional and rolling contact, fatigue resistance, lubricity, and adhesive strength improvements.
Materials Commonly Processed: Why to Process Them with These Methods
Wear resistance, lubricity, fatigue, and corrosion resistance are primary benefits with improved fatigue strength and adhesive strength possible.
3-48 hours at temperature. May be up to 72 hours.
Relative Cycle Times
2-6 hours at temperature.
Pit retort furnaces and front load retort furnaces for gas nitriding, although bell retort furnaces have also been used.
Equipment Types Used for the Process
Pit retort furnaces and front load retort furnaces for gaseous ferritic nitrocarburizing. Bell retort furnaces have also been used.
Ammonia and nitrogen or ammonia and dissociated ammonia.
Atmospheres Used/Required
Ammonia and nitrogen and carbon-bearing gas such as CO2, CO, or endothermic gas.
Dies, gears, pump bodies, springs, gun barrels, shafts and pinions, pins, brake rotors and may other types of component parts produced from bar, plate, rod, forgings and castings formed by stampings, machining, rolling, forging, casting, etc.
Typical Parts Processed
Wear plates, washers, clutch plates, gas pistons, brake pistons, brake rotors, barrels, slides, differential cases and other types of component parts produced from bar, plate, rod, etc., and formed by stampings, rolling, machining, casting, etc.
Cost is often higher for gas nitriding as opposed to other case hardening processes (including FNC) based on the type of component parts run. In many cases, cost is a function of the longer cycle time and/or more labor involved.
Relative Cost Per Unit
Cost is often lower than many other case hardening processes (including gas nitriding) based on the type(s) of component parts run. In many cases, cost is a function of a shorter cycle time and/or less labor involved.
Basic specifications are easily achieved with good equipment and/or controls; difficulty increases when attempting to produce specialized layer compositions/phases.
Ease of Use/Control
Basic specifications are easily achieved with good equipment and/or controls; difficulty increases when attempting to produce specialized layer compositions/phases. Hardware/control requirements are more complicated than for nitriding when controlling for carbon potential.
It can range from very simple to medium-high depending on application.
Relative Expertise Necessary to Perform
Medium-high depending on the application. The user will want to look for clean parts, a good loading system, and PLC controlled cycle.
Aqueous (clean chemistry) including rinse/dry, vapor degreasing (clean chemistry).
Cleaning Requirements
Time, temperature, gas flow, nitriding potential (Kn) and/or percent dissociation, hydrogen sensors.
Controls
Time, temperature, gas flow, nitriding potential (Kn), carbon potential (Kc) and oxygen potential (Ko). Hydrogen sensor and oxygen (carburizing) sensor may be used.
electric and gas-fired equipment
Fuel Source
Hardness (surface, core), case depth determination (via microhardness – typically core hardness + 50 HV), microstructure (compound and diffusion zone depths), composition, core structure, presence of absence of nitride networking (aka nitride needles), and the presence or absence of cracking or spalling of the case.
Testing Required
Hardness (surface, core), case depth determination (via microhardness – typically core hardness + 50 HV), microstructure (compound and diffusion zone depths), composition, core structure, porosity (type and depth), and the presence or absence of cracking or spalling of the case.
Warm wall plasma nitriding, as well as advances in controls, sensors, temperature uniformity, and reduced gas volumes.
Latest Advances
Black oxide, hydrogen sensors, and fast cooling techniques as well as advances in controls, sensors, and temperature uniformity.
(1) simple equipment, (2) can offer beneficial tribological changes part/metal, (3) performed after part machining, (4) little-to-no distortion.
Pros (Strengths)
(1) fast, cheap, repeatable results, (2) excellent corrosion resistance, especially with (black) oxide, (3) performed after part machining, (4) minimal distortion/almost distortion free
(1) long cycle time, sometimes a multi-day process if deep case is required, (2) effective pre-cleaning required, (3) weldability becomes reduced, (4) ammonia is used, (5) embrittlement with too much white layer.
Cons (Weaknesses)
(1) Focused on part surface, mainly with inexpensive materials, (2) effective pre-cleaning required, (3) weldability becomes reduced, (4) ammonia is sometimes a concern.
Why is parts cleaning an important step in heat treat? While a nice surface finish reflects quality, the importance of cleaning goes far beyond the aesthetic aspect. Parts cleaning can ensure against quality issues, especially when it comes to nitriding or brazing where high surface cleanliness is a prerequisite. Learn what questions you should be asking to achieve optimal parts cleaning.
This Technical Tuesday feature written by Michael Onken, market development manager at SAFECHEM, will be published in Heat TreatToday's August 2021 Automotive print edition.
There are two types of cleaning in heat treat. One is cleaning prior to hardening where residual metal working fluids on parts must be removed. Then there is cleaning after quenching. Residue oils left on parts after quenching may cause challenges in the next process steps, such as tempering.
Inadequate cleaning not only affects subsequent processes, but also parts quality. Contaminations on parts can also get into furnaces and fixtures, and thereby impact their functionalities.
Quality cleaning is costly, but necessary, if the goal is to achieve quality components. The important questions are: What cleaning solution should I choose? Is water-based cleaning better, or rather solvent cleaning? The answer is that it depends. We have briefly outlined 4 key questions you should consider.
What are your cleaning quality requirements?
Different industrial applications require varying degrees of surface energy of the metal surface, which is influenced by filmy contaminations. With nitriding, for example, a higher surface energy is required than with standard coating or assembling. The ability of the cleaning agent to remove the contamination should therefore match the required surface energy.
What is the affinity of the cleaning agent to the soils?
Effective cleaning is based on the principle “Equal dissolves equal.” For water-based types of contaminations, such as coolant and lubricant emulsions, aqueous cleaning agents are typically the first choice.
When removing mineral oil-based, non-polar contaminations, such as machining oils, greases, and waxes, solvent will commonly be the preferred cleaning agent.
The above contaminations can be classified as filmy contaminations that can be dissolved in a suitable cleaning agent. Another important category of contaminations is particles like chips, dust, and residues of polishing pastes. These contaminations cannot be dissolved in a cleaning agent. To remove these, sufficient mechanics are required in the cleaning machine to flush off particle contaminations.
What metal types are being cleaned and how are they configured?
In water-based processes, cleaning agents, which can be acidic, neutral, or alkaline, are usually matched to specific metal types. Simultaneous cleaning of different metals can therefore be problematic, and this can result in compatibility issues and in the worst case—corrosion. Solvents, in comparison, have universal compatibility with metals.
If the component parts are tiny or have complex geometry or small crevices, solvent is often recommended due to its lower surface tension and viscosity, which makes it easy to seep into and evaporate out of tight spaces.
What is the environmental impact?
The energy consumption in a water-based process can be significant, due to the energy requirement to operate high-pressure pumps, heat the cleaning water, dry the metal parts, as well as treat and purify used water for reuse or disposal. Depending on the cleaning agents, dirt and soil are emulsified and the contaminations are diluted in the water. As a result, aqueous baths that are not treated must be replaced frequently.
Solvent in a closed vacuum vapor degreaser can be recycled again and again via the built-in distillation unit. This can significantly increase solvent lifespan and cut down on waste volume. While energy is required to keep the closed cleaning machine under vacuum, this also lowers the boiling points of solvents, hence accelerating their evaporation and enabling quick drying of metal parts within a shorter cycle time.
The questions listed above are by no means exhaustive and there are many more key aspects to consider. The optimal cleaning decision should balance technical, economic, and environmental needs. Given the potential of parts cleaning to make or break heat treat processes, when done properly, it can deliver much more value than the mere technical function it fulfills.
Read more about parts cleaning in heat treat here.
About the Author: Michael Onken is a market development manager at SAFECHEM Europe Gmbh. For more information, contact Michael at m.onken@safechem.com or Phone: +49 211 4389-300
Pulse plasma nitriding systems deliver uniform case-hardening and increased speed of processing when treating high wear parts.
Did you think purple was just a fashion statement? Explore the advantages, applications, and future of advanced pulse plasma nitriding in this Technical Tuesday.Heat TreatTodayhopes you enjoy this original content piece by technical writer Jeff Elliott in cooperation with PVA TePla.
When case-hardening the surface of steel, or steel alloy parts, commonly used in the transportation industry, such as gears, crank pins, dies, camshafts, the options have traditionally included one-of-three processes: carburizing, salt-bath nitrocarburizing and gas nitriding. Each process has advantages and disadvantages, but those seeking more precise control of the diffusion layer formation, depth of case hardening, and preservation of component dimensions are increasingly turning to plasma nitriding.
Although pulse plasma has been utilized for decades, advanced pulse plasma nitriding offers absolute control of the DC (direct current) pulsing signal. In addition, improved chamber design and construction allow for more precise temperature control and uniform distribution of the heat zone throughout the hot-wall chamber. The result is extremely consistent and uniform nitriding batch-to-batch and part-to-part, with less gas consumption.
“The benefits are more precise control of the diffusion layers, and its broader appeal to heat treat more diverse materials, beyond steel, that include titanium, stainless steel, and even aluminum,” says Thomas Palamides, senior product and sales manager at PVA TePla America.
In addition, commercial heat treat shops and high-volume part producers can now select from multiple system configurations that offer flexibility, efficiency, repeatability, and throughput optimization. As a result, global manufacturers in machined parts, tool design, die forming, die cutting, medical device manufacturing, additive manufacturing, electric vehicles, trains, electric generators, and land-based power systems are now leveraging these systems to run a cleaner, more efficient operation.
Pulse Plasma Nitriding Advantages
For steel and steel alloys, case-hardening can be achieved by carburizing, nitriding, cyaniding, or carbonitriding. Although carburizing is a traditional approach, the part has to be raised above the A3 temperature (727°C or 1341°F) on the Iron-Carbon diagram, usually in the temperature range of 900-930°C (1652-1706°F) or higher. Since the solubility of carbon is higher in the austenitic state, than the ferritic state, a fully austenitic state is required for carburizing.
Along with the high temperatures and time-at-temperature associated with carburizing, parts can be distorted. Depending on the part, and its geometric tolerances, limited machining may also be required.
An alternative to carburizing is nitriding, a lower-temperature, time-dependent, thermo-chemical process used to diffuse nitrogen into the surface of metal.
One method is salt bath nitriding. In this process, liquid immersion is required, and is typically conducted at 550 to 570°C (1022 to 1058°F). The source of nitrogen is a nitrogen-containing salt, such as sodium cyanide, often greater than 50% in concentration. However, with salt bath nitriding, post-bath cleaning is required to remove the residual cyanide-based treatment. In addition, there are disposal costs for salt and washing , also known as sodium hydroxide, environmental handling costs, as well as safety and operational liabilities.
Gas nitriding (500oC or 932°F) and gas nitrocarburizing (540-580oC or 1004-1076°F) are universally accepted procedures, and typically require a high concentration of ammonia (NH3), and a high amount of carrier gas flow (normal pressure process) compared with pulse plasma nitriding. The elemental nitrogen gas constituent diffuses into iron and forms hard nitrides. Because of the reduced temperature compared to carburizing, no quenching is necessary, and therefore the chance for distortion and cracking are lower.
Several disadvantages of gas nitriding are that it requires the use of flammable gases like ammonia, and high gas consumption compared to pulse plasma. Gas nitriding is also not able to treat rust- and acid-resistant steels (i.e. stainless steels with greater than 12% Cr content) due to the impenetrable layer of the protective surface oxide layer. Where as the energized pulsed plasma signal, during heat up, allows for the dissolution, or breakdown, of this thin protective layer, in effect cleaning the surface, allowing atomic nitrogen to penetrate.
With recent advancements in pulse plasma nitriding, however, a new level of precision and control is possible which results in uniform and consistent case hardening. Together with the advantages of using environmentally friendly gases only – in contrast to the use of ammonia in gas nitriding – plasma-based nitriding has become a focal point for additional innovations and a requirement for those that seek a more environmentally and safe solution.
In pulse plasma nitriding, parts are loaded into a heated vacuum chamber. After evacuating the chamber to a working pressure of 50 to 400 Pa, on a supporting fixture, to be covered by a bell chamber. The chamber is evacuated to below 10 Pa (7.5 x 10-2 Torr) prior to heating and a pulsating DC voltage of several hundred volts is applied between the charge (cathode) and the chamber wall (anode). The process gas in the chamber is then ionized and becomes electrically conducting. For this type of process, nitrogen and hydrogen gas mixtures and gases with carbon additions, like methane are often utilized.
Depending on treatment time and temperature, nitrogen atoms diffuse into the outer zone of components and form a diffusion zone. This can be is atomic nitrogen, dissolved in the iron lattice, as well as in the form of included nitrate deposition.
Adding further precision, innovators in advanced pulse plasma have discovered methods to optimize the process through better control of the pulses. In the PulsPlasma® process developed by PVA TePla AG Industrial Vacuum Systems, for example, a precision regulated gas mixture of nitrogen, hydrogen, and carbon-based methane is used. A pulsating DC voltage signal of several hundred volts is delivered in less than 10 microseconds per pulse to ionize the gas. This serves to maximize the time between pulses for superior temperature control throughout the chamber.
“If you have a temperature variance of plus-minus 10 degrees within a batch, you will get completely different treatment results,” says Dietmar Voigtländer, sales manager at PlaTeG – Product Group with PVA Industry Vacuum Systems (IVS), Wettenberg, Germany, the manufacturer of PulsPlasma nitriding systems. “However, by controlling the pulse current by means of an exact pulse on and off time management, the overall temperature can be precisely managed with a uniform distribution, from top to bottom, throughout the hot wall chamber.”
A unique feature with this approach is that the system can be switched on to a stable glow discharge at room temperature. Most systems cannot do this because the generators do not supply stable plasma. To compensate, those systems must first be heated to 300-350°C (572-662°F) before plasma can be applied, adding time to the process.
[blocktext align="left"]“The benefits are more precise control of the diffusion layers, and its broader appeal to heat treat more diverse materials, beyond steel, that include titanium, stainless steel, and even aluminum." -Thomas Palamides, PVA TePla America.[/blocktext]Even the materials of construction used to manufacture the nitriding systems furnace itself have been optimized. In all systems, PlaTeG uses insulative materials developed in the aerospace industry to create a furnace wall as thin as 40 millimeters, compared to the industry standard of 150 millimeters. With less wall mass, the furnace requires less energy and time to heat, while still protecting workers that may accidentally touch the outside of the chamber.
With better overall control, advanced pulse nitriding furnaces offer multiple heating and cooling zones with each controlled by its own thermocouple. “This will create a very uniform temperature distribution within plus or minus 5 degrees Celsius (9 degrees Fahrenheit) from the bottom to the top of the furnace,” said Voigtländer.
Uniformity of temperature within a chamber pays a dividend beyond the consistency of nitriding results. With an even temperature throughout the chamber, the entire space is available for loading components which effectively increases the chamber’s capacity.
Stainless Steel – a Softer Steel
One of the key advantages of pulse plasma nitriding is that it is more suited to heat treating of high alloy materials such as stainless steel. When working with steels that have a higher chromium content, liquid nitriding can react with chromium and other elements, resulting in a loss of corrosion resistance.
Stainless steel has a natural passivation layer of chromium oxide, which inhibits corrosion. To bring nitrogen into the material, the chromium oxide layer must first be removed. With gas nitriding, removal of the passivation layer requires the application of a special gas chemistry, stainless steels can also be nitrided in salt baths, but only with a sacrifice of some level of corrosion resistance.
In the case of PulsPlasma nitriding, the treatment is applied directly through controlled ionic bombardment of the surface. By choosing a nitriding temperature below 450°C (or 842°F), and with exact control of the gas mixture, the material surface can be treated without reducing the corrosion resistance of the material.
Dies, Stamping & Injection Molds – a Harder Steel
Today, various molds and dies are used to shape everything from plastic bottles, to automobile quarter panels, to extruded wire, to metal injection molded (MIM) parts. Depending on the intricacy of the mold and die, it can cost a customer hundreds of thousands of dollars to fabricate. Customers require die longevity, while maintaining part tolerance, throughout the life of the die to ensure return-on-investment (ROI).
Despite being made of hardened steel, however, injecting melted resins at high temperatures and pressure into cavities over thousands of cycles begins to wear away and erode die edges, cavities, and moving components. Even the thermoplastic material can be abrasive, acting like sandpaper or leaving residue that wears down the surface. With the ever-increasing utilization of even more abrasive material, in the form of long glass and composite fibers, the amount of abrasion and friction within molds is increasing.
According to Voigtländer, pulse plasma nitriding is an ideal solution both to protect molds against damage and corrosion, but also because the diffusion of nitrogen increases the lubricity of the surface, facilitating quick removal of parts. “The diffusion of the nitrogen into the mold surface," he explains, "increases the fatigue strength of the material. In doing so, you can protect the surface against scratches… and increase the lifetime of the mold or die."
Sintered Parts
Pulse plasma nitriding also represents a strong option for sintered, or sinter hot isostatic pressing (HIP) components manufactured though additive manufacturing.
Salt baths have historically been used to nitride sintered components. However, the process of immersing components in molten salt makes it very difficult to remove the salt from open surface porosity. When gas nitriding is used, the nitriding atmosphere permeates all open pores resulting in the entire component, the surface, and the core, being completely nitrided.
“With pulse plasma nitriding, the atmosphere goes through the pores and only the surface area is affected, leaving the core or base material soft,” said PVA’s Voigtländer. “Most designers prefer having a wear-resistant surface with a soft, elastic core.”
Increased Production Throughput
Nitriding is a batch process. Innovation in furnace design, through an optimized mechanical operation, can increase efficiency and increase production capacity. While the actual time for nitriding does not change, efficient loading and unloading scenarios plays an important part. The PlaTeG plant design can use any one of a Mono, Shuttle or Tandem footprint, to manage throughput, resources, and operations costs.
As a batch process, nitriding typically requires waiting for the prior batch to be treated, cooled, and unloaded before a new batch can be started. Shuttle and tandem extensions are now available to streamline the batch process.
With a shuttle extension, an additional vacuum chamber bottom may be added to a furnace. During a running nitriding process, the unloading of an earlier batch and the loading/preparing of a subsequent batch on the second vacuum chamber is possible. The cycle time therefore for two consecutive batches is reduced because of the overlapping of the time for unloading/loading of a vacuum chamber with the treatment time of the running process.
With a tandem extension there are two complete vacuum chambers which are operated alternately by the vacuum pumps, the process gas supply, the plasma generator and the control unit of the system. In situations such as unmanned weekend operations, an automatic process can be started and controlled for both batches in succession. With this type of operational structure, “it is possible to increase overall nitriding capacity by 30-60% annually,” according to Voigtländer.
Because plasma nitriding uses environmentally friendly nitrogen and hydrogen, the furnaces can be collocated with the machining of components without requiring a separate room. Moreover, the pulse plasma nitriding systems produce no polluting gases. This makes nitriding more efficient as part of an overall manufacturing process as an operator can locate the furnaces beside their drilling machines.
Pulse plasma offers significantly more precision in nitriding through the control of the mixture of gases, the controllability of glow discharge intervals, the design of the Pulsed signal, and the use of a highly insulated hot wall nitride furnace. Together with innovations in the design of the furnaces to streamline batch management in nitriding operations, manufacturers who depend on nitriding components can benefit from greater uniformity of results, better-protected materials, and increased throughput.
About the Author: Jeff Elliott is a Torrance, California-based technical writer. He has researched and written about industrial technologies and issues for the past 20 years. He wrote this article in cooperation with PVA TePla.
Check out more of Heat Treat Today’sTechnical Tuesday articles by searching “technical tuesday” in the search bar.
Gas Nitriding
4140 steel. AISI 4140 is a chromium-, molybdenum-, and manganese-containing low alloy steel (usually referred to as chrome-moly steel). It has high fatigue strength, abrasion and impact resistance, toughness, and torsional strength.[1]
Grade 416 stainless steel. Grade 416 steel is a free-machining, martensitic stainless steel with a machinability of 85%. [2]
Grade 410 stainless steel. Grade 410 stainless steels are general-purpose martensitic stainless steels containing 11.5% chromium. Grade 410 steels have good corrosion resistance properties which can be further enhanced by hardening, tempering, and polishing.[3]
Grade 420 stainless steel. Grade 420 stainless steel is higher incarbon than 410 with a minimum chromium content of 12%.
4340 steel. AISI 4340 alloy steel is a low alloy steel containing chromium, nickel, and molybdenum. When heat-treated, it exhibits high toughness and strength. This material is considered extreme duty and is typically used for higher-end firearms.[4]
17-4 stainless steel. 17-4 stainless steel is an age-hardening martensitic alloy combining high strength with the corrosion resistance of stainless steel. It is relatively cost-effective and more weldable than other martensitic alloys.[5]
Nitriding Specifications
Hot Isostatic Pressing (HIP)
FL-4605. FL-4605 is a low alloy steel with prealloyed manganese, molybdenum and nickel content for enhanced hardenability.[6]
420 stainless steel. 420 stainless steel is relatively high in carbon with a minimum chromium content of 12%, which gives it the highest hardenability of stainless steel grades.[7]
HIP Specifications
ASTM F3301, a specification that outlines standards for thermal post-processing for metal parts made with powder bed fusion. ASTM F3301 identifies hot isostatic pressing as an acceptable means to stress relieve additive manufactured components.
ASTM F3055, the standard specification for additive manufacturing nickel alloy with powder bed fusion. In this specification, HIP is required for Class B, C and D components and is considered optional for Class G.
Black Oxide Coating
High Pressure Gas Quenching
Electronic tracking. Each lot of parts is assigned a barcode that links to electronic records of all relevant information about the job—process parameters, specifications, shop orders, etc. The process parameters on the parts’ barcode are integrated with equipment, so when parts are scanned for processing, the furnace will be automatically set to the proper parameters according to the parts’ recipe. This helps us prevent parts from being improperly heated or subject to the wrong process altogether.
Secure storage. In Paulo plants that process firearms, we use locked cages and secure vaults to protect serialized components. All access to these areas is monitored and recorded to maintain accountability and, if applicable, adhere to AMS specifications.
Specialized handling. To give our firearms customers more peace of mind and to safeguard against errors in our process, we’ve also engineered secure fixturing for many components that allows them to remain locked throughout the entire heat treatment and finishing process.
Why do forging dies fail? How can heat treating prevent failure? And what specific role does gas- or plasma-assisted nitriding treatment play in enhancing metal structure?
Heat Treat Todaybrings you this Best of the Web feature article this Technical Tuesday to answer these questions. Written by Dr. Edward Rolinski and Mike Woods of Advanced Heat Treat Corp., this article explains the impact of forging process, material and press type; heat treatment for forging dies; and nitriding forging and stamping dies.
An excerpt: "Surface properties critical for die performance can be further elevated by a surface-treatment process employing a multi-gradient design strategy, a novel plasma, multi-step treatment with formation of the nanostructured layer/coating developed by Advanced Heat Treat Corp."
Extensive wear or fatigue from friction and contact stress cause many engineering components made of ferrous or titanium alloys to fail. In this Best of the Web
Technical Tuesday feature, Edward Rolinski, aka Dr. Glow, from Advanced Heat Treat Corp., compares “wear resistance between engineering components that were carburized vs nitrided,” originally published in his article, “Tribological Performance-Enhancing Surface Treatments for Improving Durability of Engineering Components” at AHT’s website.
“The results of the tribological studies strongly suggest that for many engineering components, the application of nitriding may be more beneficial than carburizing since the nitrided layer had better wear properties than the carburized layer despite the fact that the layer was about four times as thick.”
Rolinski defines the uses, advantages, and tribological behavior of nitrided and carburized steel and provides illustrations of samples subjected to both treatments.
Main image photo credit/caption: Advanced Heat Treat Corp / Advanced Heat Treat’s Cullman, Alabama, location ion nitroding vessel, which the company says is one of the largest in the United States—”big enough for two small cars to fit inside.”
Conventional wisdom says that batch processing is for smaller volumes. Anytime large volumes of 1 million or more parts per year are envisioned, for instance with ferritic nitrocarburizing, the go-to technology is a roller hearth or other continuous systems like rotary retort or mesh belt furnace. In this article, which originally appeared in Heat Treat Today’sJune 2019 Automotive print edition, Mark Hemsath urges end-users and engineers who use, or specify, continuous systems to not undervalue automated batch processing for large volume production.
There are a number of trends in the automotive arena:
More parts are being light-weighted. This means they need more precise and repeatable heat treating.
Parts need to be cheaper and lighter. The trend we see are increased and more sophisticated stampings.
The trend is away from carbonitriding and toward ferritic nitrocarburizing due to less distortion on lighter parts.
Gears and such are smaller and require exact carburizing, minimized quench distortions, and less hard machining.
A deep discussion of all of these is beyond this article, but we will touch on each as we focus on nitrocarburizing for large-volume production.
Batch v. Continuous
What is the difference between a classic “batch” furnace and a classic “continuous” furnace? The answer is material handling. By definition, heat treating is a “batch” operation. In virtually all instances, the product must be brought to temperature and held—or “soaked”—for a specific time. Ferritic nitrocarburizing is no different. This ramp heat, hold, and cool is a “batch”. Thus, virtually all heat treating is batch and only material handling is the difference. The basic difference is that in batch we move the product in its cold state and heat it in one place (batch). In continuous furnaces, we move it while it is heating.
Advances in Material Handling
Advanced, fully automated, and reliable material handling has made great advances over the last two decades from more recent industries like Amazon, where millions of packages need to be moved through the shipping process, to older industries like heat treating which moves steel parts through furnaces and other equipment. Automation, such as conveyors with self-driven rollers and photo sensors or proximity switches, or robots and automated self-guided vehicles—all coordinated by a PLC—have made material handling more reliable. Manufacturers have a lot of options.
A continuous furnace like a roller convey-or—or “roller hearth”—furnace conveys the product while it is heating (Figures 1, 5 & 8). A mesh belt furnace conveys parts while heating, and a rotary retort furnace (Figure 4) moves parts via a heated rotating barrel to the next process step which is typically cooling or quenching. Moving parts while hot is a challenge, but reliable high volume heat treating is why these furnaces have seen such success over the years. Roller furnaces and rotary retort furnaces are still built and used in a wide variety of industries, and they make sense for a number of reasons. Lower energy use is one main factor.
With robots placing the load, both batch and continuous processes can be fully automated. With such options, batch processing has increased in use.
Automated Batch
A leading manufacturer of heat treating furnaces has implemented the high volume automation approach many times using batch technologies. In 2013, a fully automated batch FNC installation for gears was installed for processing 1 million gears annually.[1] As a result of this success, the customer added more batch furnaces to the line.
The furnaces in Figures 2 and 3 are retort-based nitriding and ferritic nitrocarburizing furnaces. With automatically opening doors, complete PLC control, and automated batch load movement, no humans are needed. A load car operates in both directions for a heavy load of two metric tons or more, allowing furnaces to be placed facing each other.
Automated, High-Volume System Design
As mentioned, the company supplied nitrocarburizing technology using its ZeroFlow™ method (Figures 2 and 3) for an automated thermal treatment line for the production of a variety of gears. The line consisted of six large, front-loaded retort-style batch furnaces, a four-chamber vacuum washer, two ovens for pre-activation in air, additional post-cooling of the furnace charges, and an automatic robotic loader/unloader, which ensured charge transport within the system (seen in Figure 3). The automated line also included safety monitoring. System workload dimensions were 32″ wide x 32″ high x 60″ long with a gross workload capacity of 4,400 pounds. Production totaled 2,000 pounds of gears per hour. Good equipment design, retort technology, and use of ZeroFlow control technology resulted in a very successful project.
Cooling the Load and Vacuum Purging
There are advantages to continuous furnaces like a conventional roller hearth furnace; however, special options like fast cooling and vacuum purging present challenges to these conventional furnace designs. In batch, this is usually not a problem. Vacuum (and even cooling) is more difficult to attempt in continuous variations due to sealing challenges in the chamber designs. An example of a good solution is the rotary retort furnace shown in Figure 4, which offers single piece quenching where each piece falls into a water or oil quench and is “whirled-away,” a continuous furnace design which works well for small parts with a relatively small footprint. In batch, the whole load needs to be quenched together; this can present challenges that understanding the part needs and configurations can lead the process engineer to different solutions.
In a roller furnace, slow cooling means the furnace gets longer (Figure 1).
Variations in Continuous Batch – Semi-Continuous Processing
In Figure 6, an automated batch hardening line is shown. In Figure 7, the same process is shown, but with an added pre-heat chamber to allow faster processing via the pre-heat and use the single quench in a more productive manner. An oil quench is an expensive piece of equipment. The cycles are also always much shorter for quenching than heating, so we want to maximize the use of the quench. In a pure batch system, you need one quench per furnace. In the semi-continuous approach, the quench is used more frequently and there is higher productivity per capital dollar invested. In a roller hearth or rotary retort installation, the quench can be properly sized to handle all of the heating production. In an installation using pure batch systems, there might be 3 to 6 quench tanks. In a fully continuous roller furnace, there would be one quench (see Figure 5).
Case History and Take-Aways
The automated batch system referred to in Figures 2 and 3 went online in 2014 and is currently operating at full capacity, while meeting the stringent requirements of the automotive industry. It achieved the planned production goal of 1 million gears per year with 99% process reliability and 98% equipment availability. The customer previously had a continuous conventional pusher furnace. The new line achieved an 80% reduction in the consumption of ammonia from that consumed using in the pusher furnace to nitrocarburize. Endothermic gas was also eliminated by the supply of a new methanol CO generator as the carbon source in the process.[1]
The take-away from this successful project is that in order to increase production even more, automated batch systems need to exhibit two factors to compete with a continuous system like a roller hearth furnace. First, the loads need to be optimized and very densely packed. Second, the batch loads need to be larger than the continuous loads. A standard size of 40″ x 40″ x 60″ has since been created which has 50% more volume than the unit in the example above. Making the furnace a bit larger is not that difficult. Additionally, in a recent application, CFC tooling has been utilized to assure more dense loading geometry with much lighter parts, giving reliable rack geometry for a load of 1,000 pieces.
Gas Usage – Benefit Batch
The biggest advantage of batch furnaces is the lower process gas usage. In continuous furnaces, in order to keep the process safe and clean, pressure must be maintained by flowing a significant volume of gases. With the constant opening of doors during the process and the need to keep operating pressures high enough to prevent air infiltration, atmosphere gas usage is always high. To keep the costs down, gases are typically generated with the use of an endothermic generator (40% Nitrogen, 40% Hydrogen, and 20% CO) or a lean exothermic generator with a low dewpoint. In all instances, the generator is another piece of thermal equipment to maintain and purchase.
Energy Costs – Benefit Continuous
In most instances, batch processing uses more energy—or more expensive energy—such as electricity. Electricity costs can vary tremendously from location to location whereas natural gas prices are more consistent and lower. Batch nitriding furnaces are available in gas-fired heating options at an added capital cost. However, the batch process still uses more energy per pound. If electricity is available at a reasonable rate, then the difference is not as great on a per pound basis. In a recent analysis, it was estimated that an electrically heated batch system came to cost the equivalent of about $0.06 per pound of FNC operating costs, versus $0.03 per pound of FNC operating costs in a continuous gas-fired variation (energy and consumables only).
Summary
Batch or continuous in large volume scenarios is no longer a clear-cut answer. Your heat treating professional and your furnace suppliers should understand this. There are literally dozens of variables that need to be assessed, and only after a careful analysis tailored for each customer can an optimized solution be designed with either batch or continuous furnace solutions.
Notes
1. Hemsath et al, “Nitrocarburizing Gears using the ZeroFlow Method in Large-Volume Production”, Thermal Processing, 10/2015
About the Author: Mark Hemsath is Director of Nitriding and Special Vacuum Furnaces at SECO/VACUUM Technologies, LLC and acting Thermal General Manager at SECO/WARWICK Corp. in Meadville, Pennsylvania. With 30 years of experience in the industrial furnace and heat treat equipment market, he is in charge of all North American atmosphere furnace sales, gas nitriding, and gas carburizing. This article originally appeared in Heat TreatToday’sJune 2019 Automotive print edition and is published here with the author’s permission.
Audio: Mark Hemsath on Nitriding & FNC
In this conversation, Heat Treat Radio host, Doug Glenn, an interview that Doug Glenn, publisher ofHeat Treat Today and host of Heat Treat Radio, conducted with Mark Hemsath, director of nitriding and special vacuum furnaces with SECO/Vacuum Technologies, which is a SECO/WARWICK group company, located in Meadville, Pennsylvania, where he oversees nitriding, including ferritic nitrocarburizing (FNC), and also other surface engineering such as carburizing. Doug talks with Mark about nitriding and FNC.
Mark recently completed his paper for the ASM Heat Treat Show 2019, titled “Nitriding, Its Growth and the Technologies That Have Cemented Its Broad Use in Surface Engineering”, to be presented at the ASM Heat Treat Show in October 2019. In this podcast, Doug and Mark discuss why nitriding has become popular, what is nitriding and what processes does it entail, the new technologies affecting the industry, and major players in processing and supply.
Transcript: Mark Hemsath on Nitriding & FNC
Are you a hard case or a case hardener? If you’re a case hardener, you might be interested in today’s episode. If you’re a hard case, well, there are other self-help podcasts you might want to consider. On today’s episode, we’re going to talk about nitride, and we’re going to talk with one of the most qualified individuals in the North American heat treat marketplace. This guy has nitriding and heat treating running in his blood.
Mark Hemsath (MH): My father was involved with a furnace manufacturer in Toledo, Ohio, and he actually brought ionitriding to the United States from Kluckner in Germany. I think, at last count, we think he had 65 patents under his name.
Doug Glenn (DG): Hi, and thank you for joining us. I’m your Heat TreatRadio host and Heat TreatToday publisher, Doug Glenn. Today on Heat TreatRadio, we’re talking nitriding with Mark Hemsath.
MH: Hi, I am Mark Hemsath with SECO/Vacuum Technologies, which is a SECO/WARWICK group company, and I am the director of nitriding and special vacuum furnaces. I am involved with everything to do with nitriding, including ferritic nitrocarburizing, and also other surface engineering such as carburized.
DG: If you have an interest in surface hardening, such as nitriding, ferritic nitrocarburizing or carburizing, you might want to take a quick cybertrip to www.heattreattoday.com where we have a substantial and growing list of resources that might be helpful to you. Heat TreatToday is one of the industry’s leading information sources for all things heat treat-related. Every Tuesday, we post a new technical article. We call it Technical Tuesday. And Heat TreatToday is the only North American-based heat treating publication offering a comprehensive list of heat treat consultants. So, if you’re a manufacturer with in-house heat treating, especially in aerospace, automotive, medical, or energy, or even general manufacturing, and you’ve lost a good bit of your organizational heat treating brains, take a look under resources on Heat TreatToday’s website, or simply Google “heat treating consultants”, and you’ll find a comprehensive list of heat treat industry consultants that can help you solve your pressing heat treating problems. Look us up on the web at www.heattreattoday.com.
Let’s get back to Mark Hemsath and our discussion on nitriding.
DG: Mark, we’ve been trying to connect for quite a while. I’m really glad we were finally able to connect.
MH: This is a perfectly opportune time to do this because I just finished my paper for the ASM Heat Treat Show, so it is all fresh in my mind.
DG: Interesting! What is the paper?
MH: My paper is “Nitriding, Its Growth and the Technologies That Have Cemented Its Broad Use in Surface Engineering”. It will be presented at the ASM Heat Treat Show in October.
DG: Hey, heat treat readers, the show Mark is referring to is being held on October 15 – 17 in Detroit. You can find out more about that show by Googling “2019 Heat Treat Show Detroit”, or by going to www.asminternational.org and searching for it there. Now, back to Mark.
Why Nitriding?
Let’s jump into the nitriding market. What are you seeing? I’ve been hearing more and more about nitriding. How about you?
MH: I think the main thing is that nitriding is growing, and it is still growing rapidly. It has grown in the past number of years, and that is one of the reasons I just wrote a paper, which is very opportune to discussing why it’s growing and why it has gone up in use in the market.
There are a number of points that I probably should point out as to why nitriding is growing: I think more and more people are discovering the positive effects of nitriding. This would include the very high surface hardness that you can get. The higher temperature hardness—in other words, it resists tempering—a carburized-type surface or an induction-hardened surface if it’s used at temperatures above the tempering temperature, it would start to reduce its hardness, whereas nitriding is done at a higher temperature (it’s done above 900° or 1000° or so F), so you would resist the decrease in hardness up to those temperatures, which is pretty nice. Also, it gives you the ability to have a high fatigue strength. The nitrided layer actually will change the fatigue properties of the metal part. Another thing that everybody usually talks about is the improved corrosion resistance. This is something unique to nitriding. It is used a lot, especially ferritic nitrocarburizing, for corrosion resistance. And the final thing I wanted to talk about is the minimal process distortion. If you compare this to carburizing where you are quenching the part, because you’re coming from the austenitic region going into the quench bath and it’s cooling very rapidly, there is a chance for your part to distort, which means you may have to follow on process it to get it back into dimension. Nitriding has a lot of benefits to it.
DG: Interesting, Mark. These seem like some pretty compelling reasons to nitride, but one of the objections I hear is that nitriding is a more expensive process. Your thoughts?
MH: It is not really as expensive as you think, because you have to take into account certain things. Let’s take carburizing, for example, or just thru hardening, for instance. You’ve got to quench it, you’ve got to wash it, and you’ve got to temper it. If anything goes wrong in that process, you’ve got to do some sort of follow on processing. You probably won’t need to do any of that after nitriding. Now, you will need to change probably some of the material and the alloying properties, but we can get into that later.
DG: Yes, fine, but perhaps a little clarification is in order. We’re talking about nitriding, but we often hear the phrase “ferritic nitrocarburizing.” Can you help us understand the difference?
MH: Yes. It is a nitriding process, but it is typically done with lower carbon materials and that is why they put carbon in there, too, so that is where they get the nitrocarburizing into the process. It is typically done at a little bit higher temperature because you’re not as much worried about the thru hardness property or the tempering properties. What you’re trying to do is to take a less expensive material, whether it’s a cast iron or inexpensive steel, and you’re trying to get a nice white layer around there, or a combination of white layer, commonly known as a compound zone. It’s a combination of epsilon and gamma prime. You can create different layers, and the carbon is going to help you with that by creating it faster and creating it a little bit harder. What that’s going to do for you on that part is give you lubricity; because of the nature of the white layer, the compound zone has a lubricious nature to it. It will give you corrosion resistance and give you that wear resistance that everybody wants in those parts.
Where Is Nitriding Being Done?
DG: So where are nitriding and FNC being used today?
MH: Today nitriding thankfully is being used everywhere. It is actually being used where chrome used to be used, such as rods for hydraulic systems. This is a post-oxidized FNC that comes out black, and it is a very nice replacement for chrome. In the automotive industry, FNC is very popular because they use cheaper materials, and it prevents not only wear and denting, but it also offers corrosion resistance for a lot of the parts, which is nice on cars. This is actually how FNC got involved with the brake rotors. On brake rotors for cars, they used to paint them. The problem was, as soon as the car got moved from the truck onto the lot and the brakes were stepped on, it would wear the paint off and start rusting. People would complain there was rust on the brakes and they hadn’t even bought the car yet. What they discovered was that if they ferritic nitrocarburized the cars, they would not get that kind of rust on their brake rotors. So that was helpful. It also provides incredible wear resistance against your brake pads.
Nitriding is also used in gears. I mention that because you have minimal or no post grinding. In aerospace, it’s used all over. They like the wear properties and corrosion. A lot of parts stay in planes for years and years and years, so they don’t want the corrosion.
Something I learned recently in the last few years in regards to the oil and gas industry, is that oil and gas are pumping a lot of stuff. They are fracking, they are pumping water and brine, and they have a lot of slurries that cause a lot of wear in pumps and pipes. It is very caustic. Nitriding works very well to extend the life of those parts.
In a lot of large parts, they plasma nitride a lot of stamping dyes—again, because it gives you dent resistance, and it’s going to give you more life on that dye because you’re stamping metals or your hot stamping forgings, etc. There are a lot of reasons to use nitriding.
DG: Are you hearing of companies converting some of their carburizing processes to nitriding or FNC?
MH: There is a lot of effort in that area. A lot of engineers don’t know about it, but they’re starting to become more aware of it. Of course, a lot of materials and components out there are already pre-engineered, and they’re already done, and now we’ve got to thru harden it, and we’ve got to carburize it. It takes a good engineering group to understand the differences and that is part of the education process. That’s why I’m happy to do this with you today. It’s an effort to try to get more people up to speed and for the engineers and component people to say, “Yes, I can do this with nitriding,” and can understand what can be done.
You can do this with gears, for instance. We’ve done it many times, and people are starting to specify it. You can do FNC of gears, and you can do nitriding of gears, too.
DG: So, it can be done. Understood. But are you hearing of any examples of where it is actually being done?
MH: It is being done more and more in motor transmissions; [that’s] where I got word of the fact that one automaker with a ten-speed transmission was going to have three or four of the gear sets be ferritic nitrocarburized versus carburized. An offshoot of carburizing is carbonitriding. Carbonitriding is basically the same thing as carburizing except that it is usually a shallower case and they use a little ammonia in there to get a little bit harder surface. However, you’re going to get distortion on that. There are a number of parts that you can change the chemistry of the steel. Although you’re paying more for the steel, you can ferritic nitrocarburize it and get the similar properties that you’re looking for for that wear component.
DG: So you’re paying more for the base steel, but you’re paying less for the post-processing of it?
MH: Yes, potentially, because you don’t need to rework it because of distortion. A lot of parts are hard to quench and not get them to move, especially small parts or flat parts. At SECO/WARWICK, we also make rotary retort furnaces. You can do washers in there, but when that washer goes into the quench, it’s going to enter at different angles. But nobody wants to take washers and individually line them up so that the edge goes into a quench. It’s just too expensive to do that. So you’re going to put up with a certain amount of distortion on that material that you’re quenching, and then have to figure out how to deal with it afterward. With ferritic nitrocarburizing, you wouldn’t have to worry about that, because there is no quench and there is no distortion.
DG: Carburizing and carbonitriding both have quenches, whereas nitriding and FNC do not require quench.
MH: Correct. Nitriding and FNC are all done typically below 1100°F, and there is no quenching. It is always a slow cool.
DG: And, therefore, we are avoiding distortion.
MH: You’re not putting it into a liquid, whether it’s a hot oil or what have you, you’re not putting it into a liquid to cause that rapid cooling, correct.
DG: And it’s a slow cool for nitriding and FNC.
MH: Yes. Nitriding will give you some growth. We typically predict, let’s say a white layer which can be all the way up to 25 microns, usually running in 10 – 25 micron range. About 60% of that will result in growth, but it is very predictable. If the engineer is worried about the size, they can put that into their stack up in how they machine it initially. You’ll get a very small growth of the material from nitriding. I think it’s in the 10,000th range, absent the white layer.
Nitriding: Gas or Plasma
DG: When I think of nitriding, I think of several approaches such as gas or plasma nitriding. Would you explain the differences?
MH: There are four major different types of nitriding. There is gas nitriding, which is an area that I play in very heavily. There is plasma nitriding, also know as ion nitriding. There is liquid or salt bath nitriding, and there is even nitriding done with fluidized beds.
Let’s go through them quickly. I’m not going to talk much about liquid that is done in salts. It is a very old process, but not a bad process. The problem that I have always found is that people don’t want to own this equipment because of all the hazards with salts, the disposal, and everything else. It is not a bad process if you’re willing to own it and run it; you can do some great things with it.
Fluidized bed is an older technology. It’s a little different. You’ve basically got particles that are being fluidized which allow heat transfer. There is an art to running and using it, but it is certainly a process that can have very good results. A long time ago, I was involved with a company where we helped them create a new fluidized bed technology. It is still being used; it just never really has taken hold that well in this country. There are some old systems out there, however.
I actually started out my career in ion and plasma. When I was in college a long time ago, in the early 1980s, I translated German to English from the German technology which was created by Kluckner. This came to the US, and I was helping the engineers to translate what they were talking about. My paper, that I was just in the process of writing, talks about some of this, and I plan on doing a webinar in the near future and talking more about this. There are some really nice benefits to plasma. This is well-documented in the literature, but there are ones that I point out that are different than some of the other processes. You have what they call sputtering. The effect of the plasma can help clean up the surface of the material. If you have some oxides, this is very beneficial if you’re doing some type of stainless which can have some problems.
Another thing that plasma is very good at is masking. A lot of times, there are parts that have a lot of threaded holes or areas where they don’t want nitriding. They might weld on it. It is very easy to mask with plasma nitriding because you can mechanically mask it. What that means is that if you have threads, you can just put a little bolt in there and they won’t get nitrided. If you have a surface, let’s say a piece of pipe, you can take some shim stalk of metal, wrap it around there, and you won’t get any nitriding where that metal is. It will nitride the metal piece that you put on there, but it won’t nitride what’s below there. So it is excellent for masking.
The other thing with ion nitriding [is] why it was popular. It’s still popular, but gas nitriding has overcome some of the negatives that it had in the past. But ion nitriding is what’s known as a low potential process, so by nature, it has a low nitriding potential. What that means is, it is difficult to get thick compound zones or white layers because the potential is fairly low. So people that wanted to nitride parts would use ion nitriding if they didn’t want the white layer to come with it. At the same time, FNC is harder in the plasma and post oxidation is a little more difficult. The equipment is not really designed to do those processes. The other thing is that the parts need to be individually placed and very nicely placed within the furnace proper, so there is more set-up work involved. But, in general, it does a wonderful job. One thing I say in my paper is once you own the equipment and you have some loads that you’re doing, you can get very repeatable results if you do the same thing every time.
The last one is gas nitriding. We actually have a process called zero flow, but it is just ammonia. Like any other process, it is a control method. What is happening with the gas nitriding today is that the advance of controls has allowed you to do a lot more with nitriding to get you similar properties than what you can get in ion. Plasma has come a long way, too, because the controls took forever to catch up with the technology. There were a lot of issues, which I discussed in my paper. Gas nitriding has seen the same type of issues. When I was in college, the computer chip was called an 8080/8086. They weren’t very advanced and they were just getting microprocessor technology and it took decades before all of this stuff got into the industrial equipment where it needs to be.
Fast-forward to this decade, 2010 to 2019, there have been tremendous advancements in the microprocessor and in electronics. For gas nitriding, we need to measure hydrogen because it’s a way for us to estimate nitriding potential. Today, that is very reliable and you can do it in situ, which means you can do it right in the furnace and get very accurate readings and you know where your nitriding potential is. The trick to gas nitriding and to doing precision gas nitriding [is] being able to craft a layer that you want. The layers are a combination of epsilon, gamma prime, and alpha. In order to get the layer that you want, first of all, you have to look at the literature and know what you’re doing. But you have to have equipment that can get you there. Today’s control systems can get you there and craft the layer that you want.
Quite frankly, the nice thing about gas nitriding is the loading can be ugly. In other words, it doesn’t have to be prim and proper like it is with ion nitriding. You can put a bunch of things into a basket, then put another basket on top of that and another one on top of that, put a lot of weight in it, and you don’t have to worry about the parts necessarily touching each other or the wire mesh that they’re sitting on or the basket. It’s going to get very well nitrided. That is not the case with ion. It’s much easier to own the equipment once you have it. Obviously the negative is that you’re using a gas (ammonia), it costs money and you have to store it and use it.
New Tech in Nitriding
DG: I want to cover two other major areas. The first one is new technologies in this field, and the second is a brief conversation of the major players. What can you tell us about the new and/or interesting technologies in this field?
MH: With plasma nitriding, they’ve been able to do a few things there. Mainly, they’ve been able to get better power supplies, pulse plasma, and they also obviously have gone to hot wall heating. That means they don’t have to heat with the plasma anymore. On the power supplies, they always had problems with arcing and a chance to burn some holes in it or pit some surfaces if you didn’t have the right power. And again, the microprocessor control that I talked about before had gotten so good, that they now have DC pulse plasma that is very fast-acting and can sense any problems within the process, and you can control it very closely. I think most people in the plasma arena have found that technology and are using it.
Gas is a little bit different. There are a lot of things going on in gas. Many, many years ago there was a process of controlling nitriding potential only by diluting with nitrogen and that was done by one of our competitors. We have a process called “zero flow” where we don’t use nitrogen. Other people will dilute with disassociated ammonia. The problem with that is that you have to buy an ammonia disassociator in order to introduce the disassociated ammonia. The reason you introduce disassociated ammonia instead of nitrogen is you’re able to much better calculate and measure nitriding potential. With a nitrogen dilution, the calculations are different, they are much more complex, and you need a lot of experience to get similar or same results that you would get with either zero flow process or with disassociated ammonia dilution.
There is some other neat stuff going on out there that I’ve gotten involved in and that we’re trying to get moving at our company, and there is a lot of stuff out there in the literature; it’s called oxi-nitriding. I’ve heard it used both for post-oxidation and for a part of the nitriding process. Oxi-nitriding to me is not post-oxidation. Oxi-nitriding is the injection of some sort of oxygen source early in the nitriding process with ammonia so that you can do some things to the surface of the steels. Let’s say with a 300 series stainless, what you’re trying to do is break apart oxygen bonds. That is pretty well proven in the literature that you can do that. It’s probably a little cleaner way of doing it than what other people do for those stainlesses and which we also do is put some sort of a chloride in there to break the bond so that you can nitride some of those more difficult stainless steels.
The other thing that people are doing and they’re doing it differently is-post oxidation. This is giving that black color. You can do that with water or you can do it with nitrous oxide which is laughing gas. And there are different temperatures you can do it at and different depths of it. We talked before about having the effect of a white layer compound zone and that helps with corrosion resistance, but we’ve also found out that putting a post oxide on it not only gives it a nice color, being a darker, near-black color, but it also helps with the corrosion resistance. On top of that, you can develop a layer that has a certain amount of porosity, and you can impregnate that with oils and that will give it even more corrosion resistance. In industries where this is very common is hydrolic cylinders, a typical front-end loader, agriculture equipment, snow plows, etc. These are usually chromed. But a lot of manufacturers are finding that a black ferritic nitrocarburized surface with post oxidation—and then they’re using oils in the cylinders anyway—will give you better wear property from the chrome and will give you very nice corrosion resistant properties. And I think it is probably a little less expensive. A lot of people are moving to that. If you see cylinders with black instead of chrome, that’s what’s happening.
Players: Processors and Suppliers
DG: Let’s move on to major players in the industry. First, who are the major players that are actually doing the nitriding?
MH: I probably can’t list them all, but as you mentioned I used to work for Advanced Heat Treat Corp. They are a very large commercial nitridor in the Midwest, and they get work from all over the country. Obviously, another big heat treater out there is Bodycote. By definition, they do quite a bit of nitriding. Nitrex Inc. makes competing furnaces against us, but they’re actually a very big nitriding house out there, and they’re probably much bigger in the nitriding than they are in the equipment business, so they’re very well versed in doing the nitriding. There is another company in Indiana that’s been growing greatly, and it’s called Advanced Nitriding Solutions. There is Ionic Technologies Inc. in South Carolina that do quite a bit of nitriding that would also be ion and gas. What we’re seeing a lot more of is that people that really are in nitriding are doing gas nitriding and they’re doing ion nitriding. They understand that nitriding is a great process and they’re trying to offer that to everybody.
The other thing is a lot of heat treat shops do just ferritic nitrocarburizing, which I call the “poor man’s nitriding.” It’s hard to screw up ferritic nitrocarburizing. If you get enough ammonia in there and you put some carbon in there, you’re going to get some sort of a layer.
DG: And how about the nitriding equipment suppliers?
MH: There are a number. There is Ion Heat. I know those guys pretty well and they are a nice little company and have some new technology. There is RUBIG, which is a big company. I’m sure there are other ones out there, but those are the main ones right now playing in the US market for plasma nitriding. RUBIG has gotten into gas nitriding, so they do offer some designs there. I think what they do is mostly pit nitriders. I break the gas nitriders into guys doing front-loading (which looks more like a regular batch furnace) versus pit. There is nothing wrong with doing pit furnaces. Both furnaces, front-loading or pit, work very much the same. They have a fan, they’ve got a retort typically, and they try to keep the parts uniform that they put the gases in. The thing with the pit is, you’ve got to have a pit. What’s nice with the pit is you can usually load it heavier. So for people who really want to have high production, like when I was at the commercial heat treater where I was, they liked the pit design because you could load them up a lot heavier. Guys doing more precision nitriding typically want the front load. It’s more like a vacuum furnace or a batch furnace within the building, etc. Companies out there for this, as I mentioned before, are Nitrex—long ago we actually used to build their equipment, so our equipment looks very similar to theirs because we designed it; SECO/WARWICK, as I mentioned makes zero flow; Lindberg/MPH makes a pit design. I think they have not gone too much into the advanced controls. They do a lot of single-stage nitriding. Other companies out there like ALD Thermal Treatment Inc. have come out with a front load. There is KGO which has a front load. And there are a lot of new entrants in the market. It’s getting kind of crowded out there. A lot of people with not a lot of experience, but I guess they have a hammer, a welding wire, and some duct tape and they’re making furnaces.
DG: Hey readers, you can hardly blame Mark for that answer. It really wasn’t a very fair question to ask him to list all of his competitors, but he did a pretty good job. But since a good solid list of suppliers might really be helpful to you, we’re going to do two things. First, I’m going to briefly round out the list here and now. I’m sure I won’t get everyone, but we do know for sure that companies like Surface Combustion, Gasbarre, and Tenova are also making nitriding furnaces.
And since I’m sure there are others, we’ll provide a more complete list of nitriding furnace manufacturers in the transcript of this episode. You can find that transcript by Googling “heat treat radio mark hemsath”, and we’ll keep an updated list of manufacturers listed there.
DG: Final question, Mark. If someone wants to learn more about nitriding, what resources would you recommend?
MH: There are a lot of good resources online. There are a few people in the industry that are extremely well versed. A good friend and associate, Daniel Herring, is called “The Heat Treat Doctor®,” and he knows all about heat treating. There is also my friend, Edward Rolinski, who is still at Advanced Heat Treat who’s very well published and you can look for his papers. A general flow developer and also fairly well published is Leszek Maldzinski.
There are a couple of guys that have been working in nitriding their whole lives and they are prolific writers, and that would be Marcel Somers and E.J. Mittenmeijer. There is actually a book that they put out in 2014 called Thermochemical Surface Engineering of Steels. That book contains articles by Maldzinski, Rolinski, and other people that I mentioned, but it talks about carburizing, ferritic nitrocarburizing, plasma, and gas. It’s a really great resource. It cost a few dollars, but you can also get it electronically. It is highly technical.
You can go to some of the magazines out there—Heat Treat Today, Industrial Heating continually does some small articles, and the gear guys out there publish some articles. There is a lot of stuff out there and you can find most of it on the internet.
