QUENCHING NEWS
Horizontal Quench System for Automotive Industry
An East Troy, WI, heat treat systems manufacturer announced the shipment of an electrically heated horizontal quench system to a manufacturer of products for the automotive industry, specifically for aluminum solution treatment.
Wisconsin Oven manufactured the system with a maximum temperature of 1,200°F and interior chamber dimensions of 2' x 2' x 2'. The system has the capacity to heat 450 pounds of aluminum parts plus the steel basket within 60 minutes. Temperature uniformity of +/- 10°F at set points 850°F and 1,050°F was verified with a nine point profile test prior to shipment.
This horizontal quench system provides a 15-second quench delay from when the door begins to open until the load is fully submerged in the tank. The quench is manual, where the operator pulls the load out of the oven and onto the quench elevator using a hook. "This horizontal quench system was designed with a manual quench which is a cost-effective option and still ensures there are no improperly processed parts," commented Doug Christiansen, senior application engineer at Wisconsin Oven. "The system also features foldable unload wheel rails to save on floor space.”
Horizontal Quench System for Automotive Industry Read More »
Heat Treated Forging Tools Get New Quench Tank
A forging tool manufacturer will receive an agitated heated oil quench tank to be used post-heat treatment in order to set hardness. Tools such as nippers and ladles -- critical components in the foundry and in forging equipment -- are heat treated to the required hardness and then quenched in oil to set that hardness.
The L&L Special Furnace Co. small model QTO1224 heated oil quench tank holds 65 gallons of oil and can quench parts from 50 to 75 pounds. The quench tank oil is agitated by an impeller with a ½ HP explosion-proof motor and is heated with a 4.5 kW immersion heater to maintain the oil at a slightly elevated temperature to help eliminate oil flashing and fire potential.
Heat Treated Forging Tools Get New Quench Tank Read More »
Heat Treat Supplier To Provide Andritz Group With Vertical Vacuum Furnace
Maciej Korecki
SECO/WARWICK
The Andritz Group, a manufacturer of complete lines for cold-rolled strip production and processing, has ordered a vertical vacuum furnace. The furnace for gas quenching processes will help produce consistent product quality.
SECO/WARWICK Group , a manufacturer with North American  locations, equipped the Vector® furnace with a graphite chamber, gas cooling system, and a rotating hearth. The Andritz Group, with this system, adds to their heat treat capabilities in hydraulic power, pulp, and paper as well as metals processing industries.
This is the first vacuum furnace manufactured in the Tianjin facility of the SECO/WARWICK Group. “We have already worked with the Andritz Group, but this time it is the first contract with our Chinese branch. The Vector furnace is manufactured in our Chinese factory, which significantly shortens the solution’s delivery time to the customer," says Maciej Korecki, vice president of the Vacuum Products Segment at SECO/WARWICK Group.
Heat Treat Supplier To Provide Andritz Group With Vertical Vacuum Furnace Read More »
Heat Treater Expands Capabilities with Multiple Furnaces
Ben Gasbarre
Executive Vice President of Sales
Partnering with Gasbarre Thermal Processing Systems, ThermTech significantly increased their normalizing, annealing, stress relieving, tempering, and neutral hardening capacity through the acquisition of three new furnaces. These three furnaces --- now fully operational --- include: a dual zone, direct-fired box austenitizing furnace; a large batch tempering furnace; and an additional tempering furnace. These furnaces are compliant with AMS2750 at different class certifications.
ThermTech has also added two additional vacuum furnaces from Ipsen, USA. The furnaces have dimensions of 36” wide x 36” tall x 48” long with capabilities of quenching up to 6 bars of pressure utilizing nitrogen or argon gas as the quench medium. These large vacuum furnaces are AMS class 3 (+/-15°F) certified capable of AMS2750.
ThermTech added a solution annealing furnace from Williams Industrial Service to give their operational aluminum line additional heat treat capabilities. This line is capable of a sub-15 second transfer to air blast quench, a water quench range of 55°F up to boiling, a sub-7 second transfer to water quench which exceeds AMS 2770/AMS2771 specifications, as well as load thermocouple monitoring during the solution treatment, quenching, and aging.
Daniel Hill, PE
Sales Engineer
AFC-Holcroft
Source: AFC-Holcroft
Another recent acquisition includes a new austempering/marquenching furnace from Michigan based AFC-Holcroft. This furnace can handle a single part racked in the vertical orientation up to 56" long. The working dimension of the furnace is 36" W x 72" L x 56" H and is capable of operating with salt temperatures ranging from 350°F -- 750°F. "The UBQA system is an environmentally friendly ‘green technology,’" commented Dan Hill, sales engineer at AFC-Holcroft, "which can be used to impart resistance to distorting, cracking or warping of heat-treated components.” Applicable processes include marquenching, austempering, and carburizing with additional washing and tempering capacity accompanying the new marquenching/austempering furnace. Installation is expected in early 2023.
The heat treat service provider's long-term strategy is to increase growth in the Midwest and on a national scale. This includes adding more workers and integrating the use of a robotics handling systems, which is expected to be installed in late 2022.
Heat Treater Expands Capabilities with Multiple Furnaces Read More »
Aerospace Conversion Provider Joins “Three Second Club”
Cruz Hernández
Back-Shop Supervisor
Airborne Maintenance and Engineering Services
Source: LinkedIn
PEMCO Conversions – Airborne Maintenance and Engineering Services operators will join the "Three Second Club" with a new dual chamber heat treating system capable of quenching aviation grade aluminum aircraft parts in less than five seconds.
The modern DELTA H® Technologies, LLC Dual Chamber Aerospace Heat Treating (DCAHT®) system will replace PEMCO's previous DELTA H furnace which was installed in 2011 at PEMCO's location at Tampa International Airport.
The system, with an upper chamber convection oven operable to 500°F and a lower chamber convection furnace operable to 1200°F, includes soak time and quench delay recorded to within 1/10 of a second as well as full documentation systems for work order, part name, quality, and before/after condition. Honeywell controls and recorders are featured and include remote computer control, data entry, and process monitoring.  In addition to processing aluminum parts, the system is equipped for PH stainless steel aging and titanium ferrous alloy processes. The replacement system is fully compliant with SAE AMS2750G requirements.
Team with DCAHT® system
Source: DELTA H
To achieve SAE compliance, DELTA H provided additional training for PEMCO employees.
DCAHT® system
Source: DELTA H
“We look forward to sharing about our continued success with [DELTA H’s] great product [. . . ]. We couldn't be any happier," Cruz Hernández, Airborne Maintenance and Engineering Services Back-Shop supervisor stated,
Aerospace Conversion Provider Joins “Three Second Club” Read More »
Heat Treat IQ System for Härtewerk Chemnitz Hardening Plant
Kai Werlitz
Technical Operations Manager
Härtewerk Chemnitz GmbH
Source: Härtewerk Chemnitz
Härtewerk Chemnitz GmbH, a large German commercial hardening plant (Lohnhärterei), has purchased a horizontal, two-chamber furnace low-pressure carburizing and oil quenching system from an international heat treat solutions provider. In the German plant, the integral quench system will replace legacy atmosphere technology and expand their capabilities for mass-producing parts.
This is the first SECO/WARWICK furnace equipped with vacuum heating at the heat treater's German plant and the first Super IQ solution in Germany. The system has a heating chamber, loading and unloading vestibule, and a quenching bath. The equipment in the system enables users to perform a variety of heat treatment processes, heat, and chemical treatment, as well as low-pressure carburizing and quenching.
"The machines we have worked with so far had required time-consuming and expensive preparation, especially when the equipment was not at the right temperature," commented Kai Werlitz, technical operations manager at Härtewerk Chemnitz GmbH. "The Super IQ furnace that we have ordered eliminates not only these difficulties but also enables efficient heat treatment with very high repeatability and uniformity of the carburized layer, which with atmospheric furnaces was only possible to a limited extent."
The heat treater's Chemnitz and Chomutov plants provide a wide range of services related to metal heat treatment and focus on Germany and Europe's mechanical engineering, automotive, and metalworking industries.
Heat Treat IQ System for Härtewerk Chemnitz Hardening Plant Read More »
Western PA Heat Treat Facility VOQ Passes Startup Protocol
Source: Solar
Robert (Bob) Hill, FASM
Source: Solar Atmospheres
Solar Atmospheres of Western PA announced their newly designed vacuum oil quench furnace (VOQ) has passed startup protocol. There were zero flare and smoke-ups during the quench cycle and the transfer mechanism moved 2000 pound loads with no issues.
"[Recently]," Bob Hill, president of Solar Atmospheres of Western PA, says, "insurance companies are reluctant to write policies for commercial heat treaters simply because they see a single flame or evidence of smoke. In the past, unfortunate accidents have occurred with explosive endothermic atmospheres and flammable oils. I am convinced that this new Solar Manufacturing furnace is a much safer and greener way to oil quench parts."
Watch internal and external camera footage during a quench operation.
The design of the furnace allows for reading work temperatures within the 36" x 36" x 48" hot zone. No oxygen probes are necessary, since the furnace operates with an atmosphere devoid of oxygen. Alloys of dissimilar carbon contents and similar cross sections and austenitizing temperatures can be treated in the same load.
To read about the installation of this VOQ, or to watch a video of the largest component of that installation, click here.
Western PA Heat Treat Facility VOQ Passes Startup Protocol Read More »
Vacuum Oil Quench Being Installed at Western PA Facility
HTD Size-PR LogoSolar Atmospheres of Western PA received delivery of their vacuum oil quench (VOQ) furnace last week.
This 36” x 36″ x 48” furnace from Solar Manufacturing will be fully installed, tested and operational in early April. See the largest component, a 40,000 pound vestibule/oil quench tank, being transferred and inverted into its pit. This will be the first vacuum oil quench furnace to employ work thermocouples in the actual load!
Solar Atmospheres indicates that they will be releasing updates on this furnace in the future.
Vacuum Oil Quench Being Installed at Western PA Facility Read More »
News From Heat Treat Today’s European Media Partner
Today, we cast our sights overseas to our European information partner, heatprocessing, to find out what’s new internationally. Major movements in steel and implementations of new furnace tech are the themes.
Steel Wire Plant Needs New Bell Annealer System
“After detailed technological analysis, Italy’s Trafilerie San Paolo, srl. has selected a Hicon/N2 bell annealer facility for steel wire by Ebner Industrieofenbau.
“The facility will be installed in TSP’s newly-remodeled steel wire plant in Molteno (LC). Initial installation will comprise two Hicon/N2 workbases, one heating bell and one cooling bell, as well as all required peripheral equipment. The scope of supply includes all required supplementary equipment such as hydraulic power supply equipment, a pressure control station, analysing systems, state-of-the-art electrical systems with automation technology and a central visualisation system terminal.”
Read More: “Trafilerie San Paolo orders bell annealer facility for steel wire from Ebner”
Special Quench for Razor Thin Plates
Wuhan Iron & Steel Co. Ltd. (WISCO) has awarded Tenova LOI Thermprocess another order for the installation of a continuous quench for efficient cooling of thin steel plates.
“The quench is specially designed for efficient cooling of thin and very thin plates of high strength and wear resistant material. The quenches adopted for this application ensure maximum hardness and outstanding flatness combined with unique and powerful models and overall automation.”
Read More: “Wuhan Iron & Steel orders thin plate quench from Tenova LOI Thermprocess
News From Heat Treat Today’s European Media Partner Read More »
US Defense Contractor to Receive Vacuum Oil Quenching Furnace
Piotr Zawistowski
Managing Director
SECO/VACUUM TECHNOLOGIES, USA
Source: secowarwick.com
A new vacuum furnace for a division of the US Department of Defense will bolster its capability to ensure supply chain reliability. The furnace is equipped to handle steel hardening, surface engineering, vacuum annealing, nickel alloy processing, and titanium heat treatment.
As a critical supplier of aerospace components to the US Department of Defense, this division will use the new vacuum oil quenching furnace, provided by SECO/WARWICK, Group, to handle functions of the department’s existing heat treatment furnaces and expand their capabilities. The addition of low pressure carburizing (LPC) and high pressure gas quenching (HPGQ) is new to this location.
“Assuring redundancy in heating needs of this location was critical,” said Piotr Zawistowski, Managing Director of SECO/VACUUM.
US Defense Contractor to Receive Vacuum Oil Quenching Furnace Read More »
