THERMOCOUPLES NEWS
Heat Treat Supplier Receives Patent for Vacuum Furnace Control Thermocouple
Solar Manufacturing has received a patent for an improved vacuum furnace control thermocouple design. The new thermocouple design offers an advantage when controlling at operating temperatures from ambient up to 1200°F (649°C) especially in smaller diameter hot zones of 36” (91.44 cm) or less.
William Jones CEO and Founder/Owner, Solar Atmospheres
The new thermocouple configuration was developed to lessen the undesirable thermal conduction losses of the thermocouple assembly. This thermocouple design has also demonstrated to improve temperature uniformity survey results. To satisfy AMS 2750 standard temperature uniformity specifications, it is critical to have the control thermocouples in the proper location of the hot zone for satisfactory survey thermocouple measurements without correction factors.
The patent inventor is William R. Jones, owner of Solar Manufacturing, Inc.
Under these conditions, the outer ceramic protection tube of the conventional control thermocouple design acts as a heat sink. This thermal conduction, or the heat loss, is compounded by the shorter length of the thermocouple assembly and causes the control thermocouple to operate at a lower temperature, thus increasing the power output to the furnace heating elements to maintain set-point temperature. The result is the workload temperature hotter than the furnace temperature. The phenomenon is more pronounced at lower processing temperatures (<1200°F/649°C).
Heat Treat Supplier Receives Patent for Vacuum Furnace Control Thermocouple Read More »
Heat Treat Tips: Atmospheres, Thermocouples, and Flow Power
Heat Treat Today’s 101 Heat Treat Tips provides an opportunity to learn the tips, tricks, and hacks shared by some of the industry’s foremost experts.
For Heat Treat Today’s latest round of 101 Heat Treat Tipsclick here for the digital edition of the 2019 Heat Treat Today fall issue (also featuring the popular 40 Under 40).
Today’s tips come to us from AFC-Holcroft, covering Thermocouples, Atmospheres, and Flow Power.
Heat Treat Tip #4
Pack Your Thermocouples
When a thermocouple is used with an open-ended protection tube, pack rope or fiber between the thermocouple and the protection tube to prevent cold air infiltration from influencing the reading.
Photo Credit: Super Systems, Inc. (SSi)
Heat Treat Tip #7
A Good Fit
Heat Treat Tip #25
Heat Treat Tip #26
Flow Power
Pressure varies as the square of the flow. This means that to double the flow, with all else being constant, pressure must increase by a factor of 4. Also, power increases as the cube of the flow. Doubling the flow produced by a fan or blower requires an 8-fold increase in horsepower.
Heat Treat Tip #77
Puzzling Polarity?
If unsure of the polarity of a type K thermocouple, remember that the negative (red) leg is magnetic; the positive (yellow) is not.
Heat Treat Tip #94
Copper as a Leak Check
Heat Treat Tip #97
Optimum Dew Point
It is much easier to produce low dew point gas in a generator (within reason) than it is to lower the dew point after the atmosphere is in the furnace using enriching gas.
Heat Treat Tips: Atmospheres, Thermocouples, and Flow Power Read More »
Reader Feedback: Reusing Non-expendable Base Metal Thermocouples
Jason Schulze has written numerous articles for HTT about AMS2750E. Check them out by searching “Jason Schulze” at www.heattreattoday.com
Jason Schulze, Aerospace Heat Treating
Jason Schulze, Conrad Kacsik
READER QUESTION: As per AMS2750E, what is the number of reuses for nonexpendable base metal thermocouples (N type MIMS TCS) above 980°C? Our application is TUS and SAT from 700°C  to 1250°C. We would like to use N type MIMS thermocouples for both TUS and SAT. Recalibration period is specified as 3 months for N type thermocouples in AMS2750E. But no details are provided for the number of reuses above 650°C.
Jason Schulze (Conrad Kasik) for HTT: The number of permitted uses depends on the intended use of the thermocouple. For example, if the Type N thermocouples are used at 980°C (1796°F) as load thermocouple, the maximum permitted use would be 3 months or 180 uses, whichever comes first. If the thermocouple is used as a resident SAT thermocouple, it would need to be replaced every three months. In this case, the usage limit would be limited to 3 months. This will not be changing when the new version of AMS2750F is released.
We welcome your inquiries to and feedback on Heat Treat Today articles. Submit your questions/comments to editor@heattreattoday.com.
Reader Feedback: Reusing Non-expendable Base Metal Thermocouples Read More »
Thermocouple Wire Manufacturing Line Changes Hands
Ted Bill, president, Pelican Wire
A Florida-based manufacturer of thermocouple, resistance, and custom wire recently acquired a portion of the insulated thermocouple manufacturing business from a  technology and manufacturing company that provides thermal products and systems to heat treating operations within the automotive, aerospace, defense, and medical industries worldwide.
Pelican Wire has completed the purchase of a portion of the SERV-RITE business from Watlow Electric, based in St. Louis, Missouri. The agreement includes equipment, design and manufacturing process information and customer account data.
“I’m excited to work with our long-time partner, Watlow Electric, to provide their customers continued superior service for these high-temperature thermocouple products,” said Ted Bill, president, Pelican Wire. “This is a great example of Pelican Wire’s ongoing commitment to the thermocouple wire industry.”
“This is a very natural transition for both companies. Watlow and Pelican Wire have a long history of cooperation to ensure customers can leverage the core capabilities of both to get the best solution,” said Randy Brown, Chief System Designer, Watlow.
As quoted from the August 31, 2018 “End of Life” (EOL) statement, “Watlow has already begun transferring both design and manufacturing knowledge of the product line to Pelican Wire. Pelican Wire already manufactures these constructions, so the transition is expected to be seamless.”
Pelican Wire will begin quoting and accepting orders on new and existing wire designs on September 17, 2018, and will begin manufacturing operations on or before October 15, 2018.
Thermocouple Wire Manufacturing Line Changes Hands Read More »
3D TUS Software Released to Heat Treat Market
Photography by Quang Nguyen
Long-time heat treating expert, Peter Huskek of Phoenix Heat Treating, a fourth generation commercial heat treating institution, is branching out into the computer simulation arena with a very impressive, 3D temperature uniformity survey (TUS) reporting tool called Virtual Visual Surveys (www.virtualvisualsurveys.com). What Mr. Hushek and his team, including key developer Jeff Murch, have developed under the company name of Thermal Innovation Technologies, Inc., is a 3D visualization tool capable of showing furnace operators what their furnace uniformity looks like. This 3D visualization software helps quality personnel know if a furnace will pass a TUS, and if not why. It also allows maintenance personnel the opportunity to isolate and diagnose problem areas within the work area of the furnace. The 3D visualization package is offered as a service. For more information, visit www.virtualvisualsurveys.com.
3D TUS Software Released to Heat Treat Market Read More »
