An East Coast manufacturer has purchased six new vacuum sintering furnaces to replace the 1980s-era sintering furnaces it has used for heat treating components.
SECO/VACUUM received the commission to transition the production line from nine 40-yr-old SECO/WARWICK sintering furnaces to the six Vector sintering vacuum furnaces with 2-bar gas cooling. The furnace hot zones will be 26″ wide, 30″ high, and 62″ deep (660 x 760 x 1575 mm), which are the same size as the retiring furnaces, allowing them to continue using their existing heat treat fixtures.
Sintering is a critical process used to fuse metals together without reaching melting temperature. It is generally used for fixing the strands of wire mesh in place, consolidating powder metals, or any application where the objective is fusing metals together while remaining below melting temperatures.
