The Korea Institute of Materials Science (KIMS), a government-funded research institute under the Ministry of Science and ICT, has invested in a new vacuum furnace from a manufacturer headquartered in North America.
KIMS conducts a wide range of technological R&D activities, including process improvements, application development, material enhancement, testing, and evaluation. The new Nitrex vacuum furnace will support domestic companies -- including Hanwha Aerospace, Doosan Enerbility, Sung-il Turbine, and Samjeong Turbine -- in a development project that aims to improve the cycle efficiency of industrial land-based gas turbines.
The furnace is a horizontal type 2-Bar external quench equipped with a curved molybdenum wide band heating element arranged in a circular configuration around the main hot zone. Its work area measures 15″ in width by 15″ in height by 24″ in length (381 x 381 x 610 mm).
“The Nitrex system can support a wider range of R&D projects and metals,” said Nikola Dzepina, regional manager in Asia at Nitrex. “With the ability to achieve higher vacuum levels with 10-6 Torr ultimate range, the furnace can heat treat parts at temperatures up to 1,371°C (2,500°F).”
