Vacuum Furnaces: Origin, Theory, and Parts
OC
A Brief History
Vacuum Heat Treat Theory
Jason Schulze Director of Technical Services Conrad Kacsik Instrument Systems, Inc.
Figure 1. Vacuum levels corresponding to the recommendations of the American Vacuum Society Standards Committee
Source: Jason Schulze, Conrad Kacsik Instrument Systems, Inc.
Vacuum Furnace Pumping System
Figure 2. Vacuum pumps work in conjunction with one another
Figure 3. Booster pump positions
Figure 4. Diffusion Pump
Image 1. Holding Pump
Table 1
Table 2
Figure 5.Diagram of gas quenching
Table 3
Summary
Contact Jason at jschulze@kacsik.com
website: www.kacsik.com
