A Pennsylvania company recently heat treated and quenched a fabricated 47,000-pound gear. In addition to this gear, about a month ago, its reverse image (with the helix in the opposite direction) was also heat treated. The halves will be matched when grinding is complete to make a complete gear to drive a rolling mill for a steel plant.
