Source: TAV Vacuum Furnaces Blog
Have you studied the latest AMS2750 revision? Do you know what you need to do for successful SAT sensor placement and test performance for your vacuum furnace?
On today’s Technical Tuesday, this best of the web article outlines what system accuracy tests (SATs) are and the operational procedures of performing a comparative SAT. Knowing what type of SAT sensors you are working with is just part of the equation, so read on to learn more.
An excerpt: “In the case of comparative SAT on charge thermocouples, in place of the alternate SAT, the same positioning rules previously illustrated apply (distance between the two hot joints must not exceed 76 mm). Therefore it is necessary to set up the SAT test during production by placing the SAT sensor near the charge sensor.”
Read more: AMS 2750F Pyrometric Requirements for Heat Treatments: What’s the Comparative SAT
Check out Heat Treat Today’s Expert Analysis on AMS2750F here.
All images are sourced from tav-vacuumfurnaces.com/blog.
