Lindberg/MPH announced the shipment of four (4) heavy duty tube furnaces to a leading manufacturer of thermocouples for use in a laboratory to heat treat parts inside tubes. The tube furnaces are easy to operate, utilize an energy efficient design, and provide rapid heat-up rates along with fast cooling and response time. They offer superior radial and linear temperature uniformity and require little or no maintenance.
The four (4) heavy duty tube furnaces have a maximum temperature rating of 1500°C and work chamber of 3” in diameter and 34” in length with removable side panels. Double-end silicon carbide heating elements are mounted above and below the furnace chamber for uniform heating. The chambers are constructed of high-temperature graded insulation. The insulating vestibules at the ends of the heated chambers keep the heat loss to a minimum ensuring even greater temperature uniformity. These tube furnaces provide easy element installation, electrical hook-up, and adjustment.
“These compact tube furnaces offer customers a number of benefits. With a design that is easy to operate while at the same time provides energy efficiency and premium performance, they are the ideal solution for many customers.” –Jason Dobberstein, Inside Sales Manager
