Heat Treat Radio #97: Lunch & Learn, Ovens vs. Atmosphere Furnaces
Are you trying to figure out what heat treat equipment investments you need to make in-house and what is better being outsourced? This conversation marks the continuation of Lunch & Learn, a Heat Treat Radio podcast series where an expert in the industry breaks down a heat treat fundamental with Doug Glenn, publisher of Heat Treat Today and host of the podcast, and the Heat Treat Today team. This conversation with Dan Herring, The Heat Treat Doctor®, zeros in on heat treat ovens versus atmosphere furnaces.
All About Ovens (01:42)
Universal oven from Grieve
Source: Grieve
"Metal lined oven"
Source: Dan Herring
"Double door shelf oven"
Source: Dan Herring
"A larger horizontal oven . . . . a fan system sitting at back"
Source: Dan Herring
"Walk in oven"
Source: Dan Herring
"Industrial oven . . . . typical oven in typical heat treat shop"
Source: Dan Herring
"Monorail conveyor oven . . . . with u-shaped radiant tubes"
Source: Dan Herring
Q&A on Ovens (16:58)
Heat Treat Today team enjoying a Lunch & Learn session
A 14-foot long car bottom furnace
"A box furnace . . . . sometimes difficult by sight alone to tell an oven or box furnace"
Source: Dan Herring
"A box furnace with retort"
Source: Dan Herring
"A pit style furnace . . . . there is probably 4X as much furnace below the floor"
Source: Dan Herring
"An integral quench furnace, an in-out furnace"
Source: Dan Herring
"A humpback style furnace"
Source: Dan Herring
Dan Herring: Well thank you, my pleasure.
For more information:
www.heat-treat-doctor
dherring@heat-treat-doctor.com
