A Pennsylvania heat treat supplier recently shipped and commissioned two power supplies used in a continuous brazing furnace for a tool manufacturing company. The new power supplies, rated 125 kW supply and 100 kW, were designed as direct replacements for a pair of existing, obsolete power supplies that continuously failed.
Magnetic Specialties, Inc's power supplies reduce furnace downtime and provide tighter regulation of the furnace temperature which delivers more consistent quality of the braze parts. The brazing furnace has silicon carbide heating elements, which increase in resistance as they age. To compensate for this, the output transformers feature a tapped secondary winding. As the elements age, the client can select a higher output voltage range via the tap switch. The client will use the metering feedback to know when the tap needs to be changed.
