Your parts need heat treated to herculean surface hardness but with a soft, ductile core. That is to say, you are looking at case hardening processes, most likely one of these: gas carburizing, low-pressure carburizing, carbonitriding, gas nitriding, and ferritic nitrocarburizing.
Mike Harrison at Gasbarre Thermal Processing Systems brings us a Technical Tuesday article about what case hardening is and how five of the most common processes vary by (1) comparing the specific guidelines for each temp and time, (2) identifying equipment used to perform each process, and (3) providing a chart (at the end!) to understand different process considerations.
Engineering Manager of Industrial Furnace Systems Division
Atmosphere Gas Carburizing
Low-Pressure Carburizing
Carbonitriding
Diffusion Only Processes
Gas Nitriding
Ferritic Nitrocarburizing
Considerations
