10 Steps To Troubleshoot Your Induction System
OC
This original content article was first written by Alberto Ramirez, engineer of Power Supply and Automation at Contour Hardening, Inc. and an honoree from Heat Treat Today’s 40 Under 40 Class of 2021, for Heat Treat Today's May 2023 Sustainable Heat Treat Technologies print edition.
Alberto Ramirez
Power Supply and Automation Engineer
Figure 1. Induction hardening process
Figure 2. Induction system components
Figure 3. Capacitors
  • Oscilloscope
  • Function generator
  • Ammeter
  • Digital and analog multimeter
  • High voltage probes
Figure 4. Energy parameters example
Figure 5. Before and after of an arc at the transmission line
Figure 6. Flow diagram of the energy process at the power supply
Figure 7. Coil damage
Figure 8. Possible examples of measurements
  • Temperature
  • Voltage
  • Current
  • Resistance and capacitance
  • Waveforms
Summary
About the Author: Alberto C. Ramirez graduated from the National Technical Institute of Mexico as a mechatronics engineer. He earned his master’s degree in information technology administration from Monterrey Institute of Technology. With more than eight years of experience in power supplies, project management, maintenance, and automation, he currently works as a Power Supply and Automation Engineer at Contour Indianapolis. Alberto began his career at the Contour subsidiary in Mexico and due to his dedication, he is part of the staff in the United States. He is also an honoree from Heat Treat Today's 40 Under 40 Class of 2021.
For more information:
Contact Alberto at Contact Alberto at aramirez@contourhardening.com.
