A U.S.-based engineered knitted wire mesh solutions company and global supplier for the automotive, food service, and janitorial industries will receive a vacuum heat treat furnace. The furnace will be primarily utilized for vacuum annealing materials that are susceptible to adverse effects of their mechanical properties when exposed to any levels of oxygen or nitrogen.
This vacuum furnace features a molybdenum shielded hot zone measuring 18” wide x 18” high x 36” deep. It is capable of operating temperatures up to 2400°F and has a workload weight capacity of up to 1,000 lbs. Additionally, it includes the SolarVac® Essentials PLC-based control system. The internal gas cooling system with a 50 HP drive motor can reach quenching workloads at 2-bar positive pressure in either nitrogen or argon.
Jason Davidson, regional sales manager at Solar Manufacturing, states, “Our customer started running trials with our affiliate commercial heat treater, Solar Atmospheres. Once the trial results proved the heat treat cycle, and the [Mentor® Pro Model HFL-3036-2IQ] furnace demonstrated it could process the required quantities, the customer had confidence to place the purchase order with us.”
