December 2015
The conversation explores various reasons why a vacuum furnace is well-suited to perform brazing because it provides:
- a controlled, consistent atmosphere cycle after cycle
- uniform heating throughout the hot zone
- a controlled rate of heating
- the elimination of air to prevent the formation of oxidation of the metal
February 2016
April 2016
Additional Notes on Titanium
February 2013
