FOUNDRY CASTING NEWS
Box Furnace Increases Tempering Capabilities for Castings Company
Tom Schulz Sales Manager L&L Special Furnace Source: L&L
An investment castings manufacturer's heat treat department received a large floor-standing box furnace from a North American specialty furnace company. The furnace will be used as support in the client's tool and die production along with tempering of finished castings.
The L&L model XLE3436 box furnace from L&L Special Furnace has an effective work zone of 34” wide by 22” high by 32” deep. It is equipped with a direct-lift vertical door with a floor switch to activate. The cantilevered vertical door eliminates the need for the upright structure to reduce the overall height of the equipment.
Tom Schulz, sales manager at L&L, highlights the key role this will play for the heat treat department, saying that this type of furnace is the company's “workhorse when it comes to thermal processing.”
The inert blanketing gas enables the part to be heat-treated with minimal surface de-carb. A stack light indicates the furnace status via an audible and visual indicator light mounted on top of the control.
Additionally, the furnace is equipped with a pyrometry package that has reference control thermocouple ports along with corner locations to record the high and low points within the unit as indicated by the latest temperature uniformity survey.
The original press release from L&L Special Furnace is available upon request.
Find Heat Treating Products And Services When You Search On Heat Treat Buyers Guide.Com
Box Furnace Increases Tempering Capabilities for Castings Company Read More »
Skuld Expanding by Opening New Foundry & Manufacturing Facility
Skuld LLC announced that they had purchased the site belonging to the former Champion Foundry in Piqua, Ohio, a gray and iron foundry that had closed in March 2017. The company will continue to be focused on innovation in the metals industry, serving their clients through a number of innovations related to novel materials and manufacturing technologies.
The four buildings with nearly 32,000 square feet of space are being refurbished to be capable of casting a wide range of ferrous metals (gray, ductile iron, steels) and nonferrous metals (aluminum, brass, bronze, copper, nickel alloys). The plant will initially have 3,000 tons of capacity but plans are in place to expand to ten times that capacity in the next few years.
Skuld will be installing machining, foam blowing, a printer farm, and heat treating, adding to their current 5 small heat treat furnaces and adding to their operations, which primarily consist of lost foam casting. The new installations will aid the company as they serve the defense, tooling, and heavy equipment industries. They are also beginning to target production of heat treat fixtures and baskets.
Sarah Jordan, CEO, Skuld LLC
Production at the new site is scheduled to begin in April 2024. Sarah Jordan, CEO of Skuld LLC, commented, "Skuld is looking forward to getting our induction melting furnaces installed so that we can produce higher temperature iron, steel, and nickel alloy castings." She continued, "many [heat treaters] have custom furnace components and fixtures that require high temperature metals. These parts can have extremely long lead times, sometimes over a year, which is a problem if they are stocked out." By using their new tooling free processes, Jordan says that they can help clients drive lead times down to less than a month, if not a day for emergency spares.
Skuld is a company founded by two metallurgical engineers, Mark DeBruin and Sarah Jordan, with ties to the heat treat industry. DeBruin is the former CTO of Thermal Process Holdings. Jordan formerly worked in heat treating at Timken and Commercial Metals and was a staff engineer for Nadcap heat treat.
The full press release from Skuld LLC is available upon request.
Find Heat Treating Products And Services When You Search On Heat Treat Buyer's Guide.com
Skuld Expanding by Opening New Foundry & Manufacturing Facility Read More »
Second HIP Contracted For Wallwork
Bringing forward plans by two years, Wallwork Group have signed for a second hot isostatic press. Following hot on the heels of opening their £10 million Wallwork HIP Centre, Wallwork Group is installing this HIP to meet and serve increasing demand from various manufacturers.
David Loughlin
Business Manager Wallwork HIP Centre
This second HIP from Quintus Technologies, a high pressure manufacturer with North American locations, has been contracted following Quintus completing the commissioning of the first HIP in the third quarter of 2023.
“We expected strong demand from UK castings, 3D printing, powder fabrication, and near-net-shape manufacturers. Especially, as the UK is currently under-served with hot isostatic pressing capacity,” says Wallwork HIP Centre, business manager, David Loughlin.
Adds Simeon Collins, group director of Wallwork, “Demand from customers for processing components in our first hot isostatic press has been astonishing. It is prudent to bring forward planned investment for the next HIP, knowing it will take most of 2024 to build and install. We hope to have it up and running by early 2025. Deciding to prepare pits for expansion during the first installation has proved right.”
The second HIP will be identical to the first, operating at pressures from 40 to 207 MPa (5,800 to 30,000 psi) and temperatures up to 2282°F (1250°C). It will also have the latest rapid cooling technology, as well as the capability to offer increased cycle pressures at elevated temperatures, complements engineering advances in metal 3D printing and more.
This press release from Wallwork Group can be found in its original form here.
Second HIP Contracted For Wallwork Read More »
ECOACERO Expands Rebar Potential with New Mill
ECOACERO, an ESTRELLA Group company, has placed an order for a new rebar mill with a heat treater with North American locations. It will be located nearby Santo Domingo, in Dominican Republic, for serving the growing local and regional construction industry.
The upcoming ECOACERO facility with a rebar mill from SMS group will introduce a versatile range of rebar to the market, tailored to meet the demands of different construction industry segments, manufactured with state-of-the-art technology from SMS, and adhering to rigorous international quality standards.
The complete project, conceptualized with a sustainability philosophy, consists of two phases, with the forthcoming integration of a steel production, involving a melt shop with a continuous casting machine, from the scrap processing.
The scope of delivery of the SMS includes a reheating furnace for billets, feeding a continuous single-strand rolling mill. Products are finished on a MEERdrive® finishing block, a machine that reduces CO₂ emissions and boots plant efficiency. Water boxes in the production process enable steel with improved mechanical properties through quenching and self-tempering of the bars, minimizing the use of expensive alloying elements in the melt shop.
From left to right: Pedro Estrella, Director of ECOACERO; Giuseppe Maniscalco, CEO of industrial division Grupo Estrella; Filippo Verlezza, SMS group and Nicola Redolfi, SMS group (Source: SMS group)
The second phase involves a modern electric arc furnace (EAF), high electrical efficient and designed with burner and oxygen injector technology to reduce CO₂ emissions and operating costs.
The scrap charging-based electric arc furnace will be equipped with the latest SMS technologies for safe and automatic operation aimed at reducing the carbon footprint. The entire melting-refining-casting process line is monitored by X-Pact® Level 2 system.
The plant commissioning is scheduled for the beginning of 2025, pointing to ECOACERO as the one of the largest and modern steel companies in the Caribbean and Central America.
This SMS group press release can be found in its original form here.
ECOACERO Expands Rebar Potential with New Mill Read More »
North American Heat Treater Welcomes New Ownership
Effective November 30, 2023, Joe A. Powell has sold his remaining shares in Akron Steel Treating Company, his family’s commercial heat treating business for over 80 years in Akron, Ohio, USA, to a fourth generation of new “family” ownership.
The team at AST will continue to deliver ISO and Nadcap aerospace heat treating and related metallurgical services to part making customers.
Joe A. Powell, AST’s Chairman of the Board, will remain active in the heat treating and metallurgical services community as president of Integrated Heat Treating Solutions, LLC. (IHTS). IHTS is a “heat transfer” consulting company for product development teams to enable more sustainable heat treating equipment and practices to be integrated into their new product designs. IHTS and its team of part making consultants enable their part making clients to deliver more “total added value” from heat treating and forging per BTU expended in making their products for their end users; including the design of the associated heating and quench cooling equipment for "leaner + greener, more sustainable, manufacturing" and for greater recyclability of metal alloys.
Pictured in the image above: AST’s new shareholder team, and Joe A. Powell, Chairman of the Board, are pictured from left to right: Matt Moldvay, President; Steve Powell, Vice President of Quality, Christina Powell Somogye, Vice President of Administration; Joe A. Powell, Chairman; and Joe N. Powell, Vice President of Sales. (Source: AST)
Find Heat Treating Products and Services When You Search On Heat Treat Buyers Guide.Com
North American Heat Treater Welcomes New Ownership Read More »
Foundry Expands 3D Printing Capabilities
A Louisiana-based foundry — a supplier of iron, stainless, and specialty alloy castings for paper/pulp, energy, mining, and petrochemical customers — is getting financial support for infrastructure investments from the state as part of a three-phase effort to expand its 3D printing operation for sand molds.
JB Shoaf
Howell Foundry
Howell Foundry plans to expand its 3D-printing capabilities following a $7.4 million update to its operation in St. Francisville, LA. This expansion is expected to create 26 new jobs and retain 22 current, according to an announcement by the Louisiana Economic Development agency. Work was scheduled to start in December for completion by the end of 2027, LED said.
The state will provide a $400,000 performance-based forgivable loan for infrastructure work, contingent upon Howell Foundry meeting investment and payroll targets. Also, the foundry is expected to participate in the state’s Quality Jobs and Industrial Tax Exemption programs.
The foundry emphasizes its ability to deliver complex parts with quick turnaround, using 3D-scanning to convert parts or patterns into reproducible programs, casting process simulation to plan and set-up production, and 3D-sand printing of molds and cores.
“Howell Foundry combines modern-day 3D innovations with proven craftsmanship in one of the oldest known trades to produce rapid and reliable solutions to its valued customers who are primarily located on the Gulf Coast,” stated company president JB Shoaf said. “We take great pride in being a local business that serves local businesses.”
Foundry Expands 3D Printing Capabilities Read More »
Fringe Friday: Desirability of the Deoxidation of Ductile Base Iron
What is deoxidation and how can it be useful for energy savings? In fact, can the process really save money and improve the quality of iron?
Sometimes our editors find items that are not exactly “heat treat” but do deal with interesting developments in one of our key markets: aerospace, automotive, medical, energy, or general manufacturing. To celebrate getting to the “fringe” of the weekend, Heat Treat Today presents today’s Heat Treat Fringe Friday article that answers these questions. Hint: Deoxidation is helpful, and the article points to how annealing heat treatment may not be necessary in order to meet the ferritic ductile iron elongation specification levels.
Ductile iron producers typically add copper to the melt to enhance the material’s tensile strength. That becomes unnecessary when base iron is deoxidized prior to magnesium conversion treatment. The deoxidized iron’s strength rises to near 100,000 psi after deoxidation, without copper addition. Deoxidation removes the suspended MgO oxide particles that reduce strength and elongation in ductile iron.
Read more: “Deoxidation Saves Alloying Cost and Improves Iron Castability
Fringe Friday: Desirability of the Deoxidation of Ductile Base Iron Read More »
Fringe Friday: Nippon Steel Corporation To Acquire U. S. Steel
To celebrate getting to the “fringe” of the weekend, Heat Treat Today presents today’s Heat Treat Fringe Friday: the recent acquisition of U.S. Steel by Japan’s Nippon Steel Corporation and some coverage on what may derail the sale.
Nippon Steel Corporation (NSC), Japan’s largest steelmaker and one of the world’s leading steel manufacturers, and United States Steel Corporation (U. S. Steel), a leading steel producer with competitive advantages in low-cost iron ore, mini mill steelmaking, and best-in-class finishing capabilities, announced that they have entered into a definitive agreement pursuant to which NSC will acquire U. S. Steel for a total enterprise value of $14.9 billion. The transaction has been unanimously approved by the Board of Directors of both NSC and U. S. Steel.
NSC’s acquisition of U. S. Steel will enhance its world-leading manufacturing and technology capabilities and enable it to expand the geographic areas in which NSC can better serve all of its stakeholders. The transaction will further diversify NSC’s global footprint by significantly expanding its current production in the United States, adding to its primary geographies of Japan, ASEAN, and India. As a result of NSC’s acquisition of U. S. Steel, its expected total annual crude steel capacity will reach 86 million tonnes – accelerating progress towards NSC’s strategic goal of 100 million tonnes of global crude steel capacity annually.
NSC President Eiji Hashimoto said, “We are excited that this transaction brings together two companies with world-leading technologies and manufacturing capabilities, demonstrating our mission to serve customers worldwide, as well as our commitment to building a more environmentally friendly society through the decarbonization of steel.”
President and Chief Executive Officer of U. S. Steel, David B. Burritt, said, “For our U. S. Steel employees, who I continue to be thankful for, the transaction combines like-minded steel companies with an unwavering focus on safety, shared goals, values, and strategies underpinned by rich histories. For customers, U. S. Steel and NSC create a truly global steel company with combined capabilities and innovation capable of meeting our customers’ evolving needs. [December  18’s] announcement also benefits the United States – ensuring a competitive, domestic steel industry, while strengthening our presence globally. Our shared decarbonization focus is expected to enhance and accelerate our ability to provide customers with innovative steel solutions to meet sustainability goals.”
Read more about this press release here.
U.S. Response: Pushing Back
There has been some push-back from various effected entities. The United Steelworkers International Union has vocalized concerns for the deal, claiming that this acquisition would be bad for America and the steelworkers. David McCall, president of the United Steelworkers Union, has indicated that there may be legal reasons to make the deal void. U.S. President Joe Biden also has weighed in on the matter, believing that this deal requires scrutiny from a national security and supply chain perspective; comments on how the upcoming presidential election and the significance of Pennsylvania’s support have arisen.
But this pushback is not at all unexpected from a Japanese perspective. In the perspective of Kyodo News, the regulatory authorities in America and “strict antitrust laws” could continue to prove to be an impediment to the full acquisition.
Fringe Friday: Nippon Steel Corporation To Acquire U. S. Steel Read More »
Jet Engine Manufacturer Modernizes with Updated Casting Furnace
Sławomir Tomaszewski
Vacuum Melting Team Director
SECO/WARWICK
Source: LinkedIn
One of the world’s largest producers of jet engines has modernized their casting furnace, which was last updated two decades ago.
This company has two casting units supplied two decades ago by RETECH, a North America-based company belonging to the SECO/WARWICK Group. The modernization project was for the VIM EQ furnace - a system for the production of castings in equiaxed crystallization. It will involve replacing almost all the furnace components except the power supply, melting chambers and mold. The platforms will also remain unchanged. The remaining components will be replaced with more modern, ergonomic, and user-friendly parts and assemblies.
Says Sławomir Tomaszewski, vacuum melting team director at SECO/WARWICK, “This order includes the complete elimination of hydraulic components by replacing them with electrical components such as an elevator drive or crucible rotation drive. In addition, two old feeders: one for loading crucibles, the other for removing disposable crucibles, will be replaced with a modern system that can perform both activities."
He added, "An additional advantage of the operation will be the fact that the furnace operator will not have to come into physical contact with hot used crucibles, because they will be removed automatically without human intervention."
Jet Engine Manufacturer Modernizes with Updated Casting Furnace Read More »
News from Abroad: Furnace Updates and Lowered Emissions
In this article, international companies scale up their equipment and scale down their carbon emission.
German Steelmaker Dillinger Completes Slab Pusher Furnace in Rolling Mill
"The stock corporation of Dillinger Hüttenwerke (Dillinger) has successfully converted its slab pusher furnace 2 in the rolling mill." (Source: Furnaces International)
"For the customer, this means that the availability of large, heavy sheets increases. With these, weld seams can be saved and, thanks to more efficient production, more offshore foundations can ultimately be produced and installed. The modernization of the slab impact furnace, as well as the new edge milling machine for the delivery of “fabricated” offshore wind sheets, is one of a number of investments in the offshore wind market that are currently being planned and implemented at Dillinger."
Read More: “Dillinger: Investment in slab pusher furnace successfully completed" at heat processing
Global Steel Producers Partner To Cut Carbon Emissions
Heat transfer supplier Alfa Laval has created a partnership with Finnish steelmaker Outokumpu to cut carbon emissions. (Source: Furnaces International)
“Most of the Alfa Laval steel purchased from Outokumpu, a global steel manufacturer, will now be the low carbon stainless steel variety. This change applies to heat exchangers used in the energy transition towards a more sustainable energy supply, including energy efficiency, waste heat recovery, and heat pumps. These heat exchangers are currently produced in large quantities with the potential for future growth, says Alfa Laval.”
Read More: “"Outokumpu and Alfa Laval partner to cut emissions"  at furnaces-international.com
Japanese Steelmaker JFE Steel Plans To Build New EAF To Replace Blast Furnace
JFE's plans for an electric arc furnace will be used for the automotive industry and will reduce carbon emissions. (Source: heat processing)
“The steelmaker is considering building an EAF that can produce 2Mt of high-grade steel when the No.2 unit is due for refurbishment, JFE president Yoshihisa Kitano said. He added that the EAF would reduce CO2 emissions by 2.6Mt/yr from current levels emitted by the blast furnace."
Read More: "JFE mulls building 'one of the world's largest' EAFs" at furnaces-international.com
Indian Manufacturer Refratechnik Group Opens New Factory for Metals Industry
"The Refratechnik Group opens its new factory in India." (Source: heat processing)
"The state-of-the-art greenfield factory was built to produce MgO-C refractory products, high-alumina bricks, as well as monolithic products for the steel, cement and non-ferrous metal industries. The plant will employ more than 300 people in the short term and more than 400 people in the long term."
Read More: "The Refratechnik Group opens a modern factory in India" at heat-processing.com
News from Abroad: Furnace Updates and Lowered Emissions Read More »
