AEROSPACE HEAT TREAT NEWS
Testing Underway for Innovative Gas Quenching Unit
A Cleveland-based heat treatment software and engineering firm, specializing in metallurgical process engineering and thermal/stress analysis of metal parts, recently announced that mechanical and fatigue testing is underway on an innovative gas quenching unit designed to minimize component distortion during the hardening process.
The DANTE Controlled Gas Quenching (DCGQ) unit is capable of quenching single components following a time-temperature schedule designed for a specific component and steel alloy using the DANTE software.
DANTE Solutions proposed the concept of the process and the DANTE Controlled Gas Quench (DCGQ) unit and collaborated with Milwaukee-based Atmosphere Engineering (now part of United Process Controls), which built the unit, and Akron Steel Treating. The project is funded by the US Army Defense Directorate (ADD), and the aim market is aerospace, where high hardenability steels are used for gears, bearings, and shafts.
Justin Sims, mechanical engineer, DANTE Solutions
According to Justin Sims, a mechanical engineer with DANTE Solutions, the project began with Phase 1, wherein the team had to “make sure that a relatively slow cooling rate through the martensite transformation did not degrade material properties.”
“Phase 1 showed that we had comparable results for hardness, tensile properties, Charpy impact properties, and bending fatigue to the standard quenching practice for Ferrium C64,” said Sims. “We then initiated Phase 2 and had a unit built that was capable of controlling the temperature of the incoming quench gas to within +/- 5°C.” Phase 2 will end December 2018 after two years. The Phase 1 process currently has a patent pending.
Mechanical & Fatigue testing is currently underway at Akron Steel Treating Company where the unit is installed, and samples have been processed to compare the DCGQ process to standard HPGQ of high alloy steels. The current steel under investigation is Ferrium C64. Sims noted that DANTE is overseeing the processing of the test materials, and commercial metallurgical testing companies are performing the tests.
Tensile Testing Metallurgical Laboratory completed the hardness, tensile and Charpy impact testing, and the results are similar for conventionally hardened C64 samples and DCGQ processed samples. IMR Test Labs is conducting the bending fatigue tests. The US Army at Fort Eustis will conduct the rolling contact fatigue tests.
“We have hardness, tensile, and Charpy impact results from the unit we can share with anyone who is interested,” said Sims. “Distortion, bending fatigue, and rolling contact fatigue are currently being evaluated and the results will be available before the end of 2018.”
“We believe that the DANTE Controlled Gas Quench (DCGQ) process, patent pending, has the potential to change the way heat treating is performed on high hardenability steels,” added Sims. “By controlling the temperature of the incoming quench gas, components experience a near uniform transformation to martensite. This near-uniform transformation has the potential to eliminate post-heat treatment correction operations by minimizing part distortion and allowing designers to account for the size change distortion in the initial design of a component. To date, mechanical and dynamic properties for Ferrium C64 processed using the standard hardening process and the DCGQ process has been identical. Bend fatigue and rolling contact fatigue are currently being evaluated.”
All images provided by DANTE Solutions.
Testing Underway for Innovative Gas Quenching Unit Read More »
Jason Schulze on AMS2750E: Examining Requirements That Apply to TUS Thermocouples
This is the sixth in a series of articles by AMS2750 expert, Jason Schulze (Conrad Kacsik).  Click here to see a listing of all of Jason’s articles on Heat Treat Today. In this article, Jason advances the discussion of TUSs with an examination of requirements that apply to TUS thermocouples. Please submit your AMS2750 questions for Jason to editor@heattreattoday.com.
Any technician who has performed a temperature uniformity survey understands that the assembly, use, and placement of thermocouples are imperative to the success of the TUS.
As we move through the requirements of Temperature Uniformity Surveys, in this installment we examine the requirements which apply to TUS thermocouples.
TUS Thermocouples Re-Use, Quantity, and Arrangement Requirements
TUS Thermocouple Re-Use Requirements
AMS2750E, paragraph 3.1.3, can be difficult to understand at times. To start, it’s important to understand the difference between expendable and nonexpendable thermocouples.
Expendable Thermocouples:
“Thermocouples made of fabric or plastic covered wire. The wire is provided in coils or on spools. Insulation usually consists of glass braid or ceramic fiber cloth on each conductor plus glass braid overall.”
Nonexpendable Thermocouples:
“Thermocouples that are not covered with fabric or plastic insulations. One type consists of ceramic insulators over bare thermocouple wire, sometimes inserted in a tube for stability and protection. A second type consists of a combination of thermocouple wires, mineral insulation, and a protecting metal sheath compacted into a small diameter. The thermocouple thus constructed is protected, flexible and, within the temperature limits of the sheath material, may be used many times without insulation breakdown. This type of thermocouple, conforming to ASTM E 608, is available under many trade names.”
Once these definitions are understood, we focus on paragraphs 3.1.3.3, 3.1.3.4, and 3.1.3.5 carefully to ensure you apply the correct usage allowance to the correct thermocouples.
Paragraph 3.1.3.3:
“Expendable test sensors may be reused if ‘U’ in the following formula does not exceed 30. A ‘use’ for test thermocouples is defined as one cycle of heating and cooling the thermocouple (2.2.77). U = Number of uses below 1200 °F (650 °C) + 2 times number of uses from 1200 °F (650 °C) to 1800 °F (980 °C). Expendable base metal test thermocouples shall be limited to a single use above 1800 °F (980 °C).”
Notice the paragraph begins with the term “expendable test sensors.” This prohibits the U-formula from governing the replacement frequency of nonexpendable test sensors as well as expendable sensors which are not used as a test sensor.
Paragraph 3.1.3.4:
“Any base metal TUS thermocouple that is (1) used exclusively under 1200 °F (650 °C), (2) identified, and (3) preserved/protected from damage (i.e., crimping, excessive moisture contact, corrosion, etc.) between tests or remains installed on a rack that is protected between tests,) shall be limited to no more than 90 uses or 3 years, whichever comes first and may be reused subject only to the limitations of 3.1.3.1 to 3.1.3.2.”
This paragraph begins with “Any base metal TUS thermocouple.” This would apply to any base metal thermocouple (i.e. Type K, Type N, etc.) used for a TUS, whether expendable or nonexpendable.
Paragraph 3.1.3.5:
“Nonexpendable base metal TUS thermocouples reinstalled for each TUS through ports in the furnace, used in the same location and depth of insertion for each TUS and used exclusively under 1200 °F (650 °C) shall be limited to no more than 90 uses or 3 years, whichever comes first and may be reused subject only to the limitations of 3.1.3.1 to 3.1.3.2.”
This paragraph is very specific regarding its application. For this paragraph to apply, the supplier would need to be using a) nonexpendable thermocouples that are b) base metal, which are c) reinstalled through ports in the furnace and used (non-resident) d) at the same location and e) depth of insertion.
Suppliers interpreting the usage requirements of test thermocouples should pay close attention to Figure #1 in AMS2750E. Figure #1 lays out the usage requirements of AMS2750E in an easy-to-read format that can be used as a quick reference.
Figure 1, AMS2750E
TUS Thermocouple Quantity Requirement
AMS2750E, page 27, paragraph 3.5.13.1, states that the number of TUS thermocouples shall be in accordance with Table 11. The top 2 lines reflect the most widely used. (See Figure 2.)
Figure 2
The amount of test sensors is based on the cubic foot of the qualified work zone. This should not be mistaken for the cubic foot of the heating area in the furnace, or control zone, as the full heating area is not always the size of the qualified work zone.
Table 11 begins by categorizing the options as “Workspace Volume Less Than.” Once your qualified work zone is established, you will need to apply that to the table to determine how many TUS thermocouples will be needed. As an example, if your qualified work zone is 562 cubic feet, you would need a minimum of 19 test thermocouples distributed throughout the qualified work zone during the TUS.
TUS Thermocouple Placement Requirement
Thermocouple placement is described in AMS2750E paragraphs 3.5.13.2.1 and 3.5.13.2.2. Paragraph 3.5.13.2.1 relates to the thermocouple placement for qualified work zone volumes that are less than 3 cubic feet. Typically, this would apply to small air furnaces or laboratory furnaces used for testing, although could very well apply to smaller atmosphere or vacuum furnaces. Each paragraph describes the requirements for a rectangular qualified work zone and cylindrical qualified work zones.
“For furnace work zone volumes less than 3 cubic feet (0.085 m3), four TUS sensors shall be located at the four corners and one at the center. If the furnace work zone volume is cylindrically shaped, four TUS sensors shall be located 90 degrees apart at the periphery and one shall be located at the center. In both cases, all TUS sensors shall be located to best represent the qualified work zone.”
To better describe the requirement within this section, I’ve included a diagram of the requirement for both rectangular and cylindrical qualified work zones.
The location is a requirement, although the numbering sequence identified in these diagrams is optional and the supplier has the freedom to number the locations as they see fit.
Paragraph 3.5.13.2.2
“For furnace work zone volumes greater than 3 cubic feet (0.085 m3), eight TUS sensors shall be located at the corners and one shall be located in the center. If the work zone volume is cylindrically shaped, three TUS sensors shall be located on the periphery of each end, 120 degrees apart. One of the remaining TUS sensors shall be located at the center; the other two shall be located to best represent the qualified work zone. For furnace work zone volumes greater than 225 cubic feet (6.4 m3), the additional TUS sensors required by Table 11 shall be uniformly distributed to best represent the qualified work zone. When radiant heat from the periphery of the work zone is used to heat the product, the additional sensors shall be uniformly distributed at the periphery of the work zone.”
Again, the diagrams to the right better describe the requirements within paragraph 3.5.13.2.2.
Now that the TUS thermocouple requirements have been established, we will move on to the requirements of initial and periodic TUS requirements in the next article.
Submit Your Questions
Please feel free to submit your questions, and I will answer appropriately in future articles. Send your questions to editor@heattreattoday.com.
Jason Schulze on AMS2750E: Examining Requirements That Apply to TUS Thermocouples Read More »
“Titanium Man” Recognized for Developing Titanium Heat Treating Protocol
Source: Santa Monica Daily Press
If there’s one thing that can be determined by reading through the reasons given for nominations to Heat Treat Today‘s 40 Under 40 feature, it’s this: there are in the industry many young metallurgical and heat treating professionals with drive, intelligence, work ethics, and skill that will land them a multitude of awards, promotions, and public acknowledgements.
But as to whether any of them will match the achievements of “titanium savant” Russell Gordon Sherman remains to be seen.
“Sherman’s claim to fame is his research and development concerning alloys and heat-treating protocols for the titanium industry, expanding upon the usability of the metal during the formative years of the titanium industry.”
Dr. Frauke Hogue, a Fellow of ASM International
Recently, Dr. Sherman, 92, who is a member of ASM International, was announced as the recipient of the 2018 Lifetime Achievement Award from the International Titanium Association for “his work in developing titanium alloys, pioneering the high-volume production of titanium aerospace fasteners, and designing heat treating protocols for the titanium industry.”
The Santa Monica Daily Press noted that Sherman made possible the high-volume production of titanium aerospace fasteners during the years when the U.S. and the Soviet Union were vying for aerospace supremacy. Sherman will be presented with the award at the Titanium USA 2018 Conference and Exhibition, October 7-10, 2018, in Las Vegas.
“The entire titanium industry has benefited from his research into developing a higher-strength titanium (the workhorse Ti-6Al-4V alloy) through the heat treatment of solution treating and aging,” wrote Dr. Frauke Hogue, a Fellow of ASM International.
Sherman’s research, presented first in a paper at ASM’s convention in Philadelphia in October 1955, titled, “The Heat Treatability of Ti-6Al-4V”, went on to impact multiple industries but particularly the industrial fastener industry as it intersected with aerospace.
Still providing consulting services in the titanium industry, Sherman, though retired, is not resting on his laurels.
“. . . . If you’re lucky, you might spot the Titanium Man out in Santa Monica, relaxing after a much-accomplished life.”
Read more:
“Russell Gordon Sherman, The Titanium Man”, Santa Monica Daily Press
“ASM member Russell Sherman Receives Award from International Titanium Association”, ASM International
“Titanium Man” Recognized for Developing Titanium Heat Treating Protocol Read More »
Materials Technology Group Acquires Nadcap/ISO Accredited Lab
A global provider of a comprehensive range of materials and product qualification test, inspection and certification services recently announced the acquisition of a Nadcap and ISO 17025 accredited laboratory headquartered near Cleveland, Ohio.
Element Materials Technology (Element) acquired Orbit Industries, Inc. (Orbit) strengthening its leadership position in non-destructive testing (NDT) for the aerospace industry.
Charles Noall, president and CEO of Element
With over 30 prime approvals, Orbit, which also operates out of four other satellite inspection facilities across Ohio, Pennsylvania, and New York, specializes in ultrasonic, liquid penetrant, magnetic particle and chemical processing for raw materials, semi-finished and finished products, including landing gear components, airfoils, and aluminum wheels.
“We are delighted to welcome Orbit, a world-class inspection facility, to the Element Group,” said Charles Noall, president and CEO of Element. “In the past few years, we have invested heavily in expanding our NDT platform in order to meet the strong-ramp up in engine and structure production that the aerospace industry is experiencing. The addition of Orbit complements our existing aerospace NDT facilities in California, Connecticut, Houston, Portland and Monterrey, Mexico, strengthening our footprint, capacity, and capabilities and enabling us to deliver cost savings for our clients.’”
John Alexandrovic, CEO, Orbit
“Since our formation in 1965, we have become one of the leading providers of NDT services to aerospace primes and Tier 1 suppliers in the United States,” said John Alexandrovic, CEO, Orbit.” We see partnering with Element as an opportunity to expand our capabilities and capacity so we can continue to offer our customers testing solutions of the best quality, lead time and price in the industry.”
Element is one of the world’s leading providers of aerospace non-destructive testing services to the global aerospace sector. Its facilities across the Americas and Europe specialize in the latest state-of-the-art testing and inspection services, including high-demand services such as digital x-ray, immersion ultrasonic, and etching services.
Materials Technology Group Acquires Nadcap/ISO Accredited Lab Read More »
Aerospace Services Provider Inducts New Engines for Defense Supplier
An aerospace maintenance and repair provider recently inducted two engines in the launch of a 20-year, multi-engine MRO agreement signed earlier this year with a major manufacturer of power systems for aviation and other industries.
StandardAero inducted its first Rolls-Royce AE 1107C engine at the company’s Maryville, Tennessee, facility, and its first Rolls-Royce T56-427 engine at its San Antonio, Texas, facility.
The new AE 1107C turboshaft engine powers the Bell-Boeing V-22 Osprey tiltrotor aircraft, delivering 7,000 lbs. shaft horsepower, and is in service with the U.S. Marine Corps and the U.S. Air Force.
Russell Ford, CEO of StandardAero
The T56-427/427A is also a new engine for StandardAero, powering the Northrop Grumman E-2 Hawkeye and Advanced Hawkeye, an all-weather, carrier-capable tactical airborne early warning aircraft in service with the U.S. Navy. The T56-427 delivers 5,250 lbs. shaft horsepower. The new contract expands the company’s exclusive 8-year agreement to support T56 engine MRO services in support of the U.S. Air Force fleet of C-130H aircraft at StandardAero’s San Antonio facility.
In addition, this new multi-engine agreement will significantly grow work currently conducted by StandardAero on the Rolls-Royce AE 2100 engines, serviced at the company’s Winnipeg, Manitoba, Canada facility with capacity also being added to StandardAero’s San Antonio facility within the United States.
“Our first induction of these new engine models represents a huge milestone for our company and for our customers,” said Russell Ford, CEO of StandardAero. “This is the beginning of a new and expanded long-term relationship with Rolls-Royce along with the privilege and honor of serving the mission-critical needs of our nation’s military forces.”
Aerospace Services Provider Inducts New Engines for Defense Supplier Read More »
Grant Awarded for “Super Finishing” 3D Lab, Builds on Existing Thermal Processing Technology Research
Grant Awarded for “Super Finishing” 3D Lab, Builds on Existing Thermal Processing Technology Research Read More »
Pittsburgh Metals Company Acquires Aerospace & Defense Additive Manufacturer
Rich Harshman, ATI’s chairman, president and CEO
A Pittsburgh-based specialty metals company recently announced that it has acquired a leading pro metal alloy-based additive manufacturer for the aerospace and defense industries, located in New Britain, CT.
Allegheny Technology Incorporated (ATI) purchased Addaero Manufacturing, combining “ATI’s deep knowledge and experience in commercial aerospace and our industry-leading powder metal manufacturing capabilities, including our new aerospace-qualified Bakers Powder Operations, and Addaero’s technical expertise to produce aerospace quality parts using various additive manufacturing technologies,” said Rich Harshman, ATI’s chairman, president and CEO.
Rich Merlino, president, Addaero Manufacturing
“Addaero’s competencies are a natural extension of ATI’s metallic powder expertise and will expand our capabilities to provide comprehensive customer solutions ranging from the design of parts for additive manufacturing to the production of ready-to-install components. The acquisition of Addaero is another building block in our strategy to enhance ATI’s full specialty materials capabilities to provide end customers with finished products,” Harshman added.
“The Addaero team is excited to be a part of ATI. The combination of ATI and Addaero will increase the speed to market of new and innovative additively manufactured powder metal solutions for our aerospace and defense customers and beyond,” said Rich Merlino, president, Addaero Manufacturing.
Photo credit: Addaero Manufacturing; photo caption: 1) The Addaero Manufacturing team; 2) The above rocket nozzle was fabricated in Inconel 718 with internal cooling channels to reduce wall temperature.  The engine was hot fired 10 times for up to 30 seconds in duration.
Pittsburgh Metals Company Acquires Aerospace & Defense Additive Manufacturer Read More »
Niobium C-103 Alloy Developed for Space Exploration
Judson Humphrey
A global supplier of refractory technology metals and technical ceramics for multiple industries recently launched a unique niobium C-103 alloy for rocket and jet propulsion applications utilized in spacecraft and launch vehicles.
H.C. Starck’s Fabricated Products Division developed the advanced alloy with “resistance to high-frequency vibrations at cryogenic temperatures that occur in satellites and particularly high-performance rocket nozzle applications,” said Judson Humphrey, Market Director for Aerospace, Defense and Government for the Fabricated Products Division.
Andreas Mader
“H.C. Starck‘s niobium C-103 alloy is part of our alloy development program to extend our fabricated products portfolio allowing customers to take advantage of the unique characteristics of our alloyed materials,” said Andreas Mader, CEO of the Fabricated Products Division. “We are working with customers in space exploration to design the highest quality and performance products with the prospects of more advanced space exploration in mind.”
Photo Credit: Wikimedia
Niobium C-103 Alloy Developed for Space Exploration Read More »
Vacuum Heat Treat Furnace Manufacturer Breaks Ground on New Facility, Reunites Operations
Bill Jones, CEO, Solar Manufacturing, Inc.
With the recent groundbreaking at a site in Sellersville, Pennsylvania, a leading vacuum furnace manufacturer launched its plans to reunite its manufacturing operations under one roof in order to combine its staffing and production efforts into an expanded space.
Solar Manufacturing Inc. celebrated this new chapter in its history with a groundbreaking ceremony for a new manufacturing facility at the Sellersville Business Campus in Bucks County, Pennsylvania. Due to substantial growth in recent years, Solar Manufacturing has been operating out of two separate manufacturing facilities located a few miles apart. The nearly 60,000 square-foot building will be built on 8.55 acres and is expected to be completed in early 2019.  The new building will contain a two-story office space of nearly 20,000 square feet and 40,000 square feet of crane-served, manufacturing space.
"Solar Manufacturing has been very fortunate to experience steady growth over the past 15 years," said Bill Jones, CEO. "We needed more manufacturing space to expand and grow our business. Bucks County and Sellersville Borough have been very supportive and welcoming. It is an ideal location for us."
Solar Manufacturing is a member of the Solar Atmospheres family of companies, which is based with headquarters in Souderton, Pennsylvania, has four US commercial heat treating facilities with over 60 vacuum furnaces in operation, and services the aerospace, medical, automotive, defense, and other industries with heat treating equipment. This move to the Sellersville location will free up space for Solar Atmospheres' growing operations.
Pictured left to right: Jim Nagy, President; Bob Wilson, VP of Engineering; Scott Jacoby, Corporate Controller; Myrtle Jones, Owner; Bill Jones, CEO/Owner; Trevor Jones, CEO; Nick Cordisco, Service Manager; Pete Reh, VP of Sales; Rick Jones, International Sales Manager
Main image photo credit: Madeleine Cook, The Morning Call. Caption:  CEO of Solar Manufacturing Inc., Trevor Jones, receives a certificate from his grandfather, owner William Jones, during the groundbreaking ceremony for a new manufacturing facility on June 21, 2018, in Upper Bucks County.
Read more here: "Construction starts for Bucks County manufacturer’s new $8M HQ" (Lehigh Valley Business); "Upper Bucks' Solar Manufacturing breaks ground on new headquarters at reclaimed brownfield industrial site" (The Morning Call); "Manufacturer breaks ground on new $8.5 million Sellersville plant" (The Intelligencer)
Vacuum Heat Treat Furnace Manufacturer Breaks Ground on New Facility, Reunites Operations Read More »
The Search for New Materials, Methods for “Large Landing Gear of the Future”
A U.K.-based company that designs and manufactures aluminum matrix composites (AMCs) components has been appointed to work on a two-year, $40.5 million (£28m) project titled “Large Landing Gear of the Future.”
Alvant, located in Basingstoke, United Kingdom, is participating in this project at the invitation of project-leader Safran Landing Systems, the international high-technology group and Tier 1 supplier of systems and equipment to the aerospace and defense industries. The project aims to make use of new materials and manufacturing methods to develop and demonstrate technologies that will reduce landing gear weight, fuel burn and noise, at the same time as improving reliability and lowering ownership costs.
Current landing gear systems are typically stronger and heavier than necessary because an outstanding safety record has resulted in proven techniques being perpetuated. However, they account for approximately three per cent of aircraft weight, with a corresponding effect on fuel consumption. Safran believes it is possible to reduce this without diminishing the gear’s capabilities or safety.
Richard Thompson, commercial director of Alvant
Alvant’s work on this project will be funded by a $675,000 (£513,000) grant from Innovate UK. This will enable the design, manufacture and testing of an AMC brake rod, targeting a 30 per cent weight reduction over an equivalent titanium component whilst maintaining the same strength as steel.
AMCs are advanced composite materials in which the aluminum is reinforced with a secondary high-performance material, typically a long fibre, short fibre, or particulates. Compared to unreinforced metals, AMCs have higher strength, greater stiffness, lower weight, superior wear resistance, and lower coefficients of thermal and electrical conductivity. AMCs also offer advantages over polymer fibre reinforced materials, such as carbon composites, including higher transverse strength and stiffness, a higher thermal operating range, better wear resistance, superior damage tolerance, and easier reparability.
“A key objective of the Large Landing Gear project is to test and demonstrate as many technology advances as possible,” said Richard Thompson, commercial director of Alvant. “Alvant’s AMCs are a sustainable solution that enhance product capabilities. This is a very attractive proposition for many industries, in particular, aerospace. Alvant looks forward to demonstrating this while working in conjunction with Safran. This landing gear component is just one of the many ways in which AMCs can help aerospace firms retain strength while reducing weight.”
The Search for New Materials, Methods for “Large Landing Gear of the Future” Read More »
